  1. Aug 16, 2025 at 10:35 AM
    Cerj12
    Cerj12 Feeesh!!
    Cj
    2017 Platnum 4x4, 2017 Tacoma 4x4(rip),1997 Tacoma 4x4
    I’ll say my biggest gripe is I’d much prefer extruded bars, much like they’ve done on their “Beast” they just announced. They said those bars aren’t compatible with the original cap. However I’d like to think they’ll release some eventually.
    So far I’ve been having to make my own brackets to avoid from drilling the bars.
  2. Aug 16, 2025 at 10:51 AM
    Morebouldersplease
    Morebouldersplease New Member
    G
    Brushy Creek, Texas
    2017 Super White DC TRD Pro
    WKOR Sliders Valhalla shield front and rear plates Falken AT3W 295's Snugtop Highliner Sport
    I missed the July 4th deal from Sparks and ended up ordering them from https://hidkitpros.com/shop/2007-2018-toyota-tundra-oem-led-headlight-upgrade-kit/ for the price currently listed.
    I used the @iHacker harness with no auto dim DRL. OEM-like harness. He was super easy to deal with and has great instructions on his main forum post for the harness.
    Easy install for somebody relatively unfamiliar with turning a wrench. I highly recommend both the harness and the upgrade. The new lights are transformational. The stock halogen lights are a joke compared to the LEDs.
    For when it comes time to adjust them. Do not use a Phillips screwdriver. Get an 8mm wrench for adjusting and take out your washer fluid resivour to make room to get your hand in there for the passenger side. Makes it a 100x faster and less frustrating.
    Beesta[QUOTED] likes this.
  3. Aug 16, 2025 at 11:00 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    That’s insane.
    HulkSmurf14 likes this.
  4. Aug 16, 2025 at 11:06 AM
    elembemedia
    elembemedia New Member
    Luke
    2019 Blacked Out SR5 Tundra
    Just ordered 2 Nilight 41 LED bars, 1 for the hood bulge and 1 for somewhere in the grill/bumper. Anyone have a good mount setup for somewhere in there?
    bulldog93 and BR73 like this.
  5. Aug 16, 2025 at 12:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If you haven't read the stock engine mounts can't be used with the solid trans mount. The solid engine mounts need to be installed with the trans mount. Good luck with the mods!
    joseph_womack and Boneskull420 like this.
  6. Aug 16, 2025 at 12:36 PM
    Boneskull420
    Boneskull420 God loving,Tundra driving,rednek custom joker!
    Mark
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Nice, got mind done about a month ago also, what settings did you go with?
    Edit..... sorry I didn't read down far enough before commenting :anonymous:
    BR73 likes this.
  7. Aug 16, 2025 at 12:38 PM
    Boneskull420
    Mark
    Tn
    Im happy with mine, I went medium spicy. Worth it in my opinion driving wise. Haven't checked fuel mileage yet but drives smoother in my opinion
    Tripleconpanna and BR73[QUOTED] like this.
  8. Aug 16, 2025 at 12:40 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    Truck sat in the carport for three weeks while I used the work van. Went to drive it and got hit in the face with mouse piss smell in the cab that would gag a maggot. Finally did the rodent screen bs I had been procrastinating for five years. Air filter was being used as their restroom and vacuumed about a quart of acorns out of the blower and dash. Ran the inspection camera everywhere I could and didnt see any further-in condos. Little destructive bastards.
  9. Aug 16, 2025 at 12:45 PM
    Boneskull420
    Mark
    Tn
    One of those things that make you wonder why it didn't come that way from the factory......:monocle:
  10. Aug 16, 2025 at 1:04 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It's a pain. Did you remove the wiper assembly? On the 2nd Gen there are 2 ports behind them. Not sure if on 2.5 gen?? I chased a chipmunk only to disappear behind there. I also had chipmunk in my intake under the filter filled with moss. On stock intake you'll have a smaller opening in fender well.
  11. Aug 16, 2025 at 1:08 PM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Sweated my ass off!!!
    Was gonna flush brake fluid, but looked good and pads need to be done in about 6 months give or take, so I'll do the fluid then.
    Rotated tires/reset air pressure/torque lugs
    Cleaned inner fenders with simple green
    Wiped down inner fender plastics with alcohol
    Ceramic coated the inner fender plastics
    While rims/tires off used Adams wheel cleaner
    Still have oil/filter to do, trans drain/refill to do, skid plate arrangement to do (engine is under trans, and would catch, need to reverse that) RainX all windows, retorque drive shaft bolts, general inspection of boots, seals, etc, tap out the damn 12mm bolt under the front bumper caps and replace, check air/cabin filters.
    Ya know, general ~53k maintenance when you wanna keep it a while
  12. Aug 16, 2025 at 1:23 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    I put a 42" LED bar in the lower bumper and used brackets from Diode Dynamics.Rewired the switch to accept an OEM style push button switch.Getting the wire through the big grey grommet in the firewall was a PITA.IMG_20250318_200208.jpg PXL_20250301_184111162.jpg PXL_20250301_183951236.MP.jpg PXL_20250301_184043981.jpg PXL_20250301_191225208.jpg
  13. Aug 16, 2025 at 1:31 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
  14. Aug 16, 2025 at 1:37 PM
    Boneskull420
    Mark
    Tn
    That will work as long as you dont forget and it gets into your fan or falls between your manifold and gets cooked:goingcrazy:
  15. Aug 16, 2025 at 2:28 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    Killed ten of em with snap traps but got lazy and stopped. They moved right tf in.
    Had one run up my leg from under the damned tractor while I was grading the road a couple weeks ago. Graded for an hour before it skittered out. Yeeted her ass into a tree (wouldve fed to my chickens but I was a mile from the house).
  16. Aug 16, 2025 at 2:37 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    Had the round hole on the drivers side like yours but it had a factory plug over it, didnt look for the other one. Need to do a run for stainless hardware tomorrow and huck that in so will check for the other entry points just incase. All the interweb shit said passenger side with no mention of drivers side but im not letting those little asshats back in. The cab smells so fn bad. Had the doors open all day airing it out. Need to check inside/under all the seats to make sure they didnt set up another hotel somewhere. Snap traps deployed in the footwells just in case.
  17. Aug 16, 2025 at 3:33 PM
    TundyManFL
    TundyManFL New Member
    2021 MGM TRD Pro CrewMax
    My 2021 doesn't have the outline of the stake pockets - I assume they are still under there and they'll fit just the same? Bullring's product info seems to spec up to only 2019. Could have used these today.
    It seems like these don't interfere with operation of tonneau covers but wondering if they impact water tightness.
    Boneskull420 and BR73 like this.
  18. Aug 16, 2025 at 3:38 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Race truck stuff
  19. Aug 16, 2025 at 5:10 PM
    biebs96
    PA
    I believe it was mentioned a longggg time ago in this thread that they do indeed work all the up to the end run in 2021.
  20. Aug 16, 2025 at 5:51 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    Their site says they don't fit 2020-21
  21. Aug 16, 2025 at 6:04 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  22. Aug 16, 2025 at 9:22 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
  23. Aug 16, 2025 at 9:36 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Did you get it in, or just in the... 'here we go again' phase??
    sbxx312[QUOTED], OHwendTrd and woods like this.
  24. Aug 16, 2025 at 9:44 PM
    sbxx312
    sbxx312 New Member
    Delivered today with the hope that it can fit some small gauges.
    Tripleconpanna likes this.
  25. Aug 16, 2025 at 10:15 PM
    NWPirate
    Zach
    WA
    TWSS?
    :monocle:
  26. Aug 16, 2025 at 10:31 PM
    Tripleconpanna
    :monocle:
    Trying get a little PSI and AFR display on trim piece, huh???
    sbxx312[QUOTED] likes this.
  27. Aug 16, 2025 at 10:31 PM
    Tripleconpanna
    Don't be a perv :boink:
    sbxx312, woods and NWPirate[QUOTED] like this.
  28. Aug 17, 2025 at 1:59 AM
    Boneskull420
    Mark
    Tn
    I was just contemplating doing something similar, was it a pain to get out and put back?
  29. Aug 17, 2025 at 3:32 AM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    Nice. Mine should be here tomorrow.
  30. Aug 17, 2025 at 3:59 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Anyone who wants to come instal mine after they get theirs in let me know:rofl: I really want to get mine in, but I am just not into pulling the whole dash apart right now. Wife and kids are gone this upcomming week, maybe time to bite the bullet.
