2022+ Gen 3 Turbocharger Failure List.
Discussion in '3rd Gen Tundras (2022+)' started by Coal Dragger, Feb 9, 2022.
  1. Aug 15, 2025 at 2:04 PM
    #301
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR5
    thanks borla I thought I was the only one
  2. Aug 15, 2025 at 2:08 PM
    #302
    TreezRule
    TreezRule New Member
    2018 Tundra SR5 TRD DblCab 8ft Bed 4WD
    This is what has been reported
    Common Issues with Toyota's 10-Speed Transmission
    General Performance Concerns
    • Delayed Shifting: Some drivers report experiencing delays when shifting gears, particularly when trying to engage higher gears like 10th.
    • Harsh Shifting: There are complaints about rough or harsh shifts, which can affect driving comfort.
    • Gear Engagement: Users have noted that the transmission may not always engage the higher gears as expected, even at highway speeds.
    Specific User Experiences
    • Sequential Shifting: In some cases, drivers have found that when using manual mode, the transmission may not display the current gear accurately. For example, it may show 8th gear while the vehicle is capable of shifting to 9th or 10th.
    • RPM Changes: Some users have observed that shifting to 10th gear does not result in a noticeable change in RPM, indicating potential issues with gear engagement.
    Reliability and Long-Term Concerns
    • Initial Model Issues: Newer models often face teething problems, as manufacturers may rush to implement new technologies without extensive testing.
    • Repair Challenges: Repair options for multi-speed transmissions can be limited, and costs may be higher due to the complexity of the systems.
    Conclusion
    While many Toyota vehicles equipped with the 10-speed transmission perform well, some users have reported issues that could affect driving experience. If you encounter persistent problems, it may be advisable to consult a professional for diagnosis and potential repairs.
  3. Aug 15, 2025 at 2:11 PM
    #303
    TreezRule
    Ford and GM have major problems with their 10 spd trannys
    i believe i read that Toyota borrowed their design = will have to find that article
  4. Aug 15, 2025 at 2:18 PM
    #304
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR5
    come on Trez give us a break for goodness sakes. what you believe and what I drive are IMO two different things
    75tranzam and Breathing Borla like this.
  5. Aug 15, 2025 at 2:30 PM
    #305
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    Are those, or at least the majority of those issues, not software issues?
  6. Aug 15, 2025 at 2:43 PM
    #306
    Breathing Borla
    AZ
    lol, Aisin did not borrow GM and Fords design.
    the 10 speed in the tundra is a spot on and does awesome keeping it in the power band given the low torque peak, especially while towing
    is it 100% perfect with 0 problems ever, no, nothing is , but its not the class action POS GM/Ford collaborated on.
  7. Aug 15, 2025 at 2:50 PM
    #307
    Breathing Borla
    AZ
    just one example of the bad information in that "information" you came across.
    thats not even how that system works, lol, its not displaying what gear your in, its displaying what top gear you select for the top gear lock out
    so if you have it set to 7th, that means the top gear it can use is 7th gear, that does not mean your are IN 7th gear.
    anyways, the tundra has some issues that needs sorting out for sure, the Aisin 10 is not one of them.
    boost on...
    Kap1, MTRock, NimbusDog and 3 others like this.
  8. Aug 15, 2025 at 2:56 PM
    #308
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    The Aisin 10 speed is also not the 10R/10L trans that was a joint Ford/GM venture
  9. Aug 15, 2025 at 2:57 PM
    #309
    Breathing Borla
    AZ
    no, not at all.
    those are shit compared to the aisin , I tested both
    my Ram ZF8, I had one of the first one still built in Germany was awesome however.
    TreezRule likes this.
  10. Aug 15, 2025 at 3:09 PM
    #310
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Is this an AI summary? lol. The difference in gear ratio between 9th and 10th is 0.5. If you’re going 80, which is the speed it jumps to 10th, it’s gonna drop from about 1800 rpm to 1600 - that’s because the gear ratios are so close, not because gears aren’t engaging.
    Kap1 likes this.
  11. Aug 15, 2025 at 3:11 PM
    #311
    Breathing Borla
    AZ
    yes, otherwise known as total shit information, lol.
  12. Aug 15, 2025 at 4:29 PM
    #312
    The ZF 8 speed is THE tried and true market leader for 8 speeds, the best of the batch being the German built ones. The American built ones for RAM and Jeep have smoothed out and are nearly as good, and far and away better than the other 8 speeds from GM for example. My 2015 JGC has the German version and it’s butter. The Aisin 10 speed has come out of the gate with only a few glitches, but solid so far.
  13. Aug 15, 2025 at 5:12 PM
    #313
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    Coming from driving my Grenadier with the ZF 8HP in every scenario imaginable and working the prototype tour for the vehicle; I can confirm, it absolutely is the market leader for 8 speeds
  14. Aug 15, 2025 at 6:06 PM
    #314
    Breathing Borla
    AZ
    100%
    especially the early ones made in Germany , like I had , silky smooth
    TreezRule and Mallcrl like this.
  15. Aug 16, 2025 at 3:16 AM
    #315
    NimbusDog
    NimbusDog New Member
    Tampa, FL
    2022 Tundra
    This reads like some AI summarization... AKA a steaming pile of horseshit. And we can all smell it a mile away.
    JimboSlice413 and chrisgibbs707 like this.
  16. Aug 16, 2025 at 3:17 AM
    #316
    NimbusDog
    Tampa, FL
    2022 Tundra
    Yep.
    chrisgibbs707[QUOTED] likes this.
  17. Aug 17, 2025 at 6:13 AM
    #317
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    Come on guys, you’re being to hard on treez, you know he drove a 3rd generation for a day so he knows what he’s talking about!
  18. Aug 17, 2025 at 7:24 AM
    #318
    TreezRule
    lol = ty
    Well, i know what a reliable truck actually is since i had five = 2 Tacomas and 3 Tundras and other pre 22 Toyos
    KNABORES likes this.
  19. Aug 17, 2025 at 1:25 PM
    #319
    Now Treez is spitting facts!!
  20. Aug 21, 2025 at 7:13 PM
    #320
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    I thought I was safe but it finally happened. Just as I’m waiting for my recall engine to come in. The turbo wastegate decided to go first.
    1.) Build date - 01/07/2022
    2.) In service date - 02/05/2022
    3.) Mileage and date of failure - 39,625 and 08/06/2025
    4.) Description of problem and resolution -
    Check engine light came on when I was waiting at the red light. Scanned code with GTS+ when I got to work and it came up P25B473 Turbocharger/Supercharger Wastegate "A" Actuator Stuck Closed. Cleared DTC and it was good for about a week. Came back on again waiting at a red light last week, cleared the DTC again. Now it comes back almost instantly. Still drivable but definitely lacking boost in limp mode. Nothing I can do but wait for my new engine. Won’t be able to install the new engine till October.
