WSDMetal's 2021 Prototyping Rig
Discussion in '2.5 Gen Builds (2014-2021)' started by WSDMetal, Aug 22, 2023.
  1. Feb 20, 2024 at 3:32 PM
    WSDMetal
    WSDMetal [OP] Motorsports Fabrication & Design
    Huntington Beach
    Thank you! Will do
  2. May 10, 2024 at 1:47 PM
    WSDMetal
    Huntington Beach
    Couple more shots from KOH
  3. May 10, 2024 at 2:37 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Great looking truck! How are the Wildpeak RT's holding up? Those look like a really good option for our trucks
  4. May 13, 2024 at 2:21 PM
    WSDMetal
    Huntington Beach
    I really like them! Really solid tire and seem to be wearing exceptionally well.
    If you look at my past builds, you'll see that I was super loyal to the BFGoodrich brand in the past. I ONLY ran BFG on multiple vehicles for 10+ years in fact!
    I've put about 25K miles on these Falken Wildpeak R/T's and they are far exceeding my expectations.
    BreyTundy[QUOTED] likes this.
  5. May 14, 2024 at 8:45 PM
    Qbert
    Qbert New Member
    Nice build, looking at the same suspension setup. Did you have to do a body mount chop. I don’t see it listed. Where in the OC are you located. I am in LBC.
  6. May 15, 2024 at 4:39 PM
    WSDMetal
    Huntington Beach
    Thank you. I recently did a mild body mount chop, it was needed in order to get full steering back. I'm in Irvine now.
  7. May 15, 2024 at 5:10 PM
    Qbert
    Qbert New Member
    Thanks for the info. If you changed the offset on your wheels would you still need the BMC?
  8. May 17, 2024 at 6:27 AM
    WSDMetal
    Huntington Beach
    You would need a highly positive offset to fully clear 35" tires at this lift without a BMC. Something in the range of +18 to +30
  9. May 17, 2024 at 6:51 AM
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    nice build!
    WSDMetal[OP] likes this.
  10. May 20, 2024 at 7:43 AM
    jmladdy
    jmladdy New Member
    Oklahoma
    2020 Tundra TRD Pro
    Do you like your linkable XL light bar? Is the output good?
  11. May 20, 2024 at 4:37 PM
    WSDMetal
    Huntington Beach
    Thank you! Got a few more updates and some other goodies in the works
    5.7TRDProm[QUOTED] and reywcms like this.
  12. May 20, 2024 at 4:43 PM
    WSDMetal
    Huntington Beach
    I love it! It's very bright!
    @Baja Designs lights are the best in my opinion. I've had all of the top 3 light brands and these are my favorite by far. The quality, performance and serviceability are unmatched.
    jmladdy[QUOTED] likes this.
  13. Jun 19, 2024 at 7:12 AM
    WSDMetal
    Huntington Beach
    Picked up a Rugged Radios M1 Chase Radio, but wasn't very happy with the available mounts so I developed my own solution.
    This is a lasercut & CNC bent powdercoated steel bracket that positions the radio in the center recess on the dash. It's offset to bring the radio towards the driver for easy access to all the controls. It also has a pass-through slot in the base to keep all the wires tidy and maintain airflow for effective cooling. When used with a mic cord extension, this will keep the front of the dash completely clutter-free with flexible mic mounting on either side of the center console.
    Mounts with four M6 screws and requires drilling a 3/4" hole for the wires and connectors. The 3/4" hole is covered up by the pass-through slot. Radio is mounted super solid and works perfectly.
  14. Jun 20, 2024 at 12:23 PM
    WSDMetal
    Huntington Beach
    Completed install of the M1, with the WSDMetal mounting bracket.
    Used a 90° mic cord extension and routed everything through the wire pass-through slot. The mic cord now comes out through a factory opening under the dash/center console, so it doesn't flop around and interfere with multimedia/HVAC controls.
    The mic is secured to the dash using the supplied Scosche mag mount.
    Super solid and clean with full accessibility on the go.
  15. Jun 20, 2024 at 12:30 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Baller! Fit and finish is perfection! nice work!
  16. Jun 21, 2024 at 9:39 AM
    WSDMetal
    Huntington Beach
    Thank you sir
    HulkSmurf14[QUOTED] likes this.
  17. Jun 22, 2024 at 8:34 PM
    JackE5.7
    JackE5.7 New Member
    Jack
    San Antonio, TX
    Cavalry Blue 2020 tundra
    Icon 2.5 Resi Coilover, Icon 2.5 resi rear, Total Chaos UCA, Morimoto XB headlights, Alpharex Luxx Tailights, SS Built front bumper, Baja Designs squadron fog lights, Fittipaldi 17" wheels, Mickey Thompson 35x12.5 baja legend, 5% tint all around with 5% brow, DD budget exhaust, OTT Tune
    How do you like the Fittipaldi's? Thinking of getting a set of the FT101
  18. Jun 24, 2024 at 6:26 PM
    WSDMetal
    Huntington Beach
    I love them! I've had every wheel brand under the sun and it's nice to have a wheel that not everybody else has.
    **full disclosure, I do work for the parent company that owns Fittipaldi Off Road so there is a slight bias lol**
    JackE5.7[QUOTED] likes this.
  19. Jan 26, 2025 at 1:59 PM
    WSDMetal
    Huntington Beach
    Upgraded wheels and tires.
    Wheels: 17x9 +18 Fittipaldi Off Road FBF804 forged beadlocks
    Tires: 37x12.50R17 Falken Wildpeak R/T
    Didn't even need to balance a single wheel/tire!
    IMG_4732.jpg IMG_4726.jpg IMG_4731.jpg IMG_4680.jpg IMG_4683.jpg IMG_4692.jpg IMG_4696.jpg
  20. Jan 26, 2025 at 2:08 PM
    #50
    WSDMetal
    Huntington Beach
  21. Feb 13, 2025 at 2:32 PM
    #51
    WSDMetal
    Huntington Beach
    Took her out to Johnson Valley for shakedown with the new wheels and tires. Fender liners survived, but it's clear that the 37's are trying to rip them out at bump. I have some bumpstop spacers that will limit uptravel and help the liners last a bit longer.
  22. Feb 13, 2025 at 2:35 PM
    #52
    WSDMetal
    Huntington Beach
    No carnage, other than some minor scuffs and pinstripes. Really happy with the new wheels and tires!
    n0rth, Ghosty, BlueRibbon4x4 and 6 others like this.
  23. Aug 14, 2025 at 2:27 PM
    #53
    WSDMetal
    Huntington Beach
    Just received this Alpine iLX-F511 from Trail Grid Pro
    I went with them because they are Toyota people that own and understand Tundras. They also offer a preassembled Plug & Play bundle, custom tailored to your specific vehicle and use needs.
    My Alpine unit arrived super fast and everything is very clearly marked for the easiest install possible. All the wires/harnesses are preassembled and plugged into the unit, ready to plug into the truck. The dash trim plate also came preinstalled which is really convenient. They also include a 3D printed bracket to install the upgraded Alpine mic in the factory location!
    I'm going to install this shortly, seems like a no-brainer. Shouldn't take me more than a few minutes.
    HulkSmurf14 likes this.
  24. Aug 14, 2025 at 2:39 PM
    #54
    HulkSmurf14
    2014 Tundra Limited
    Ballin! You're truck just became updated! Good choice and great package deal!
