2006 Tundra Lucchese #42 (I've got issues)
Discussion in '1st Gen Tundras (2000-2006)' started by Lexmunk, Jun 2, 2024.
  1. Aug 30, 2024 at 7:22 AM
    #151
    Lexmunk
    Lexmunk [OP] New Member
    2006 Tundra Limited DC 4.7 4WD
    I did the neutral thing and yeah it made a huge difference, the system has never been serviced and the condenser is a little beat up, figured it was a good time to swap it all out. I'll check to refrigerant, if it just needs a recharge, I'll do that while I want for parts.
    Ahhh, I see.. I've seen roof replacements done, so I assumed it was just bolted on from inside.
  2. Aug 30, 2024 at 8:34 AM
    #152
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    +1 for checking the freon charge. There are lots of videos and writeups on this but basically can get gauges / vacuum pump as loaners for 0 net cost upon return from LAPS and as low as like $11 can for R134. Can check fan clutch with truck off and cold thst it doesn't spin on its own more than like 1/2 turn. Videos on this too.
  3. Aug 30, 2024 at 8:42 AM
    #153
    ToyotaDude
    ToyotaDude Member
    Have cleaned dirty radiator and condenser fins with a variety of things including a hose and gentle toothbrush and even tweezers when needed to remove debris. They even sell little condensor fin straightening tools but usually use a combination of tweezers or tiny needlenose or a little screwdriver or even dental pick to straighten them out one at a time and increase airflow. At 250k miles on original condensor and evaporator FWIW and produces cold air on 113 degree days. I personally wouldn't proactively replace all the OE parts with aftermarket until they failed. The OE is good sfuff. However I have swapped in a Denso compressor in a Taco because clutch failed and it is still going strong after like a decade.
  4. Aug 30, 2024 at 9:33 AM
    #154
    Lexmunk
    I did the fan clutch when I did the timing belt a couple of weeks ago, there was significant play in the original clutch where I could freely spin it, so I got one from Toyota. I'll see where I can rent the vacuum stuff from, seems like a straight forward process.
    I avoid aftermarket where I can, I usually just order OEM from the dealer, I'll look into repairing, but honestly replacing just sounds better to me. Denso has the whole system for around $400 give or take and its not a terrible price to pay for not suffering in this heat.
    ToyotaDude[QUOTED] likes this.
  5. Aug 30, 2024 at 9:44 AM
    #155
    bfunke
    bfunke Tundra Curmudgeon
    The FGT Tundra AC works well as designed. Mine will freeze me even on summer days in the south. A mod to electric fan requires you to wire it such that the fan come on either when AC activated or coolant reaches a specified temperature - not worth it. Agree you should check to be sure yours condensor and radiator fins are clean and straight. Make sure you check that your shroud is present properly attached. Based on all the questions in this thread, I suspect you lack the skills/tools to adequately service the AC unit. Take it to a reliable AC shop, preferably a local independent that’s been around a long time.
    ToyotaDude and Lexmunk[OP] like this.
  6. Aug 30, 2024 at 5:06 PM
    #156
    ToyotaDude
    ToyotaDude Member
    Agreed $400 is not bad for a full AC system swap (hoses, evaporator, and EV too?)
    Is there something that is broken and needs repaired or is that YTBD? Replacing condenser and compressor and dryer may not fix the leak if it is at an o-ring elsewhere. That's usually tracked with R134 with dye. A recharge might be under $15, last a long time, and if not help pinpoint a leak.
  7. Aug 30, 2024 at 5:56 PM
    #157
    Lexmunk
    If it is leaking, it's the slowest in the world, it still cools as long as its below 95 outside while idle, but above that the idle is cooling at 77. It's YTBD, I made an appointment with a reputable A/C mechanic to have them leak test and then evac/recharge for $200. So I'm going to hold off on buying parts since I was told by so many people (here and elsewhere) to wait on parts.
    Loud and clear on that, from my visual inspection, everything is good and the condenser is just looks like hell, I straightened out all the bent fins and didn't notice any difference in the cooling. You would be correct on the lacking skills/tools to do the A/C, I've made an appointment with someone with both.
  8. Aug 30, 2024 at 6:34 PM
    #158
    ToyotaDude
    ToyotaDude Member
    I thought this guy gives a good quick description on how an HVAC system works including what the high/low readings mean, and this guy gives a very in depth overview of more components like diagnosing electrical and compressor clutch issues. It sounds like your compressor/clutch is engaging and hence you don't have a blown fuse/relay or have a system that is completely empty. Gauges are a free loan and a can of R134 is like $12 at LAPS but can get one with dye for a few $ more.
  9. Aug 30, 2024 at 7:10 PM
    #159
    Burgmane
    Burgmane New Member
    Apollo Beach, FL
    2005 Limited DC 4WD
    Lexmunk[OP] likes this.
  10. Sep 13, 2024 at 6:18 AM
    #160
    Lexmunk
    I just did my rear diff, transfer case, and front diff (holy over torqued bolts), I put 75-90 in the front/transfer, and 80-90 in the rear. I have the LSD sticker and decided to follow shifty's advice in another thread about fluids. After about 100miles the truck is starting to feel really sluggish and I'm hearing a very light whine in the rear diff at 30-40mph, should I just drain it and put 75-90 in it? Just in case when I did the fluids, I did all the zerks on the drive shaft (again) and did an oil/filter change. (appointment for A/C is on the 23rd).
  11. Sep 13, 2024 at 6:43 AM
    #161
    When the truck is cold, if you throw it in reverse and kick the wheel hard to turn while in reverse going less than 2-3 mph is it choppy at all? (chatter)
    At 30-40 if it's a whine, I'd expect pinion bearing more than rear-end.
    ToyotaDude likes this.
  12. Sep 13, 2024 at 6:52 AM
    #162
    Lexmunk
    I haven't noticed anything choppy, it feels smooth as butter.. maybe I'm describing the sound wrong, it's not high pitched, it sounds like a deeper mechanical sound like a sedan engine (but extremely faint), but in the rear of the truck. I had my wife drive it and I hung onto the tailgate to listen to it, but other than the sluggish feeling, and by that I mean the pedal feels heavier and I'm not getting the same acceleration as I was before, it feels fine.
  13. Sep 13, 2024 at 6:57 AM
    #163
    ToyotaDude
    ToyotaDude Member
    Have found the Supertech 80-90W is the most economical, was confirmed that it includes additives for LSD, and is "recommended for Limited Slip / Positive Traction rear axles", so no additional additive was needed for mine; it runs without chatter. But sounds like that's not your issue.
    Using a stethoscope should be able to tell if its the rear pinion or something else. FWIW had a whine that could hear in the cab then traced rearward from front diff to front wheels down the driveline through tcase to rear diff and rear wheels to locate it was actually the rear wheel bearing but it made noise at all speeds.
    G_unit3000 and Lexmunk[OP] like this.
  14. Sep 19, 2024 at 3:34 AM
    #164
    Lexmunk
    Okay, so I might have screwed up a bit? The PCV that plugs into the back of the air intake has been unplugged for a month or more.. around when I did the timing belt change, I just noticed while I was doing a check of the engine and saw it was off on the engine side, not the side of the intake. Is this super bad? I just did the oil a few days ago and it wasn't burned, check the oil again after plugging it back in and the oil seems fine, normal levels, very new color still. I probably drove 2k+ miles with it unplugged. Now that it is plugged in, the ticking noise I was hearing before changing the timing belt is back as a side note. not my image below, but the same hose.
    G_unit3000 likes this.
  15. Sep 19, 2024 at 10:17 AM
    #165
    Passenger side head actually doesn't see as much issue with varnish/buildup, so I'm thinking you're fine.
    Check the ends of the hose. They like to crack, and it's easier for them to pop loose. My 2006 at 70k(ish) origianl miles were cracked. I replaced both hoses, which on OEM comes with foams included, about 6months ago.
  16. Sep 19, 2024 at 2:05 PM
    #166
    bfunke
    Concur with @shifty` - it’s a vent but not connected vacuum like PCV hose. There might be a little by Venturi effect of the air intake but you’ll be fine. That part is still available for 2005-6 but discontinued for earlier FGTs. If yours is split or brittle replace now.
  17. May 16, 2025 at 10:53 PM
    #167
    Lexmunk
    Checking back in, I'll have a bunch of photos for what I've completed on the restore so far, still working on finding replacement seats. I do have a question though, and I have already gone down the line of fixes mentioned in the stickied brake thread. This issue is driving me up the wall, I did the rear brakes, old brakes looked fine, but I wanted a fresh start so I did a replacement while keeping the drums, but replaced all the other hardware and shoes. My issue is that I am having intermittent squeaks on the rear at low speeds, I've already pulled them off again and greased back plate, cleaned, realigned.. you name it. Still squeaks with no pattern to it other than below 8-10 mph, I HAMMERED with a rubber mallet to get those drums back on and know they're fitting plenty tight with no wiggle, I know they're clean, and I know the back plate is greased. So I bled the brakes just in case, no dice, still squeaking, did brake flush, just in case there was air somewhere deeper, still squeaking.. I'm beside myself with anger at this point having pulled them off multiple times, so I thought maybe it was something else squeaking, but confirmed it is both rear brakes.. is this just a breaking in period? Should I have not used NAPA premium brake shoes? I've spent 2 weeks attempting to fix this, and I'm willing to do just about anything to make that squeak stop. Btw, brakes work great, no mush in the peddle at all, parking break has 7 clicks.
    Also, rebooted CVs with no issue, bought a Raider camper (need to paint it), replaced Monroe shocks with Bilstein 5100s, keeping the 31" tires for now, everything else is going really well and having no issues or codes from the engine, fluid manit is solid, just completed a 660mile trip camping with light/medium off-road, 4LO is so awesome.
    *edit: I did both the 15/25mph hard brake, and 10/15mph reverse hard brake, no issues with either, also didn't squeak.
  18. May 17, 2025 at 7:37 AM
    #168
    You shouldn't need to hammer the drums back on, and you may've been or damaged something depending how hard you hammered.
    You should be dialing the pads inward so the drum slides on with no force, then adjusting down, but before you do that, you should make sure ratcheting the e-brake auto-adjusts the star wheel so you know that mechanism is functional, it needs to be if you want your brakes to continue dialing-in as they should. Once you've checked to make sure that's working, I'd be sliding the drum over the shoes to make sure it clears without force, then pop off and click the adjuster a couple 1-2 clicks forward, then testing fitment of the drum again until you get roughly into the ballpark, still slides on with no real force, but you start to feel a little friction. Then either click the star wheel one click at a time thru the inspection window at the rear while spinning the wheel until you have enough resistance the wheel stops at within an inch or two of spinning.
    There's only (6?) points on the back plate to grease, I think it's 3 high spots under each shoe.
    We did have someone else on here who had problems after replacing OEM hardware. One of the springs on the autoadjuster was different from OEM and was causing him grief. (link)
    Are you 100% positive it's the rears, and you don't have the issue I had at low speeds where I'd get a squeal and I swore it was the rears, but it actually ended up being the front? My dust shield up front was barely touching the rotor at the edge. It was such a tiny amount I didn't see it the first two times I looked. (link)
  19. May 17, 2025 at 7:45 AM
    #169
    ToyotaDude
    ToyotaDude Member
    Looking forward to pics. How's the hood turn out?
  20. May 17, 2025 at 12:01 PM
    #170
    Lexmunk
    Went out and swapped out the new hardware, with old hardware and squeak is gone.. SHIFTY' IS GOD AND I'LL WORSHIP AT HIS ALTAR UNTIL THE END OF TIME! Drove it for an hour with the sound entirely gone, I couldn't see anywhere it was contacting with NAPA hardware, but I'll buy some OEM today. The parking brake adjuster worked fine, at this point I'm just glad the squealing is gone.
    Still haven't got rid of that orange peel, and I already scraped the edge when I was doing the head cover gaskets lol.
  21. Aug 11, 2025 at 7:28 PM
    #171
    Lexmunk
    Managed to snag this camper shell for $200, sitting in a junk yard, got it painted and cleaned out.
    Still a work in progress, got new LCA + hardware on the way, dunno what else I'm going to throw on at this time. I have around $4.5k as a "truck fund" and I'm not sure what to spend it on at this point. Appreciate all the help you guys have provided. (hood looks way better imo).
  22. Aug 11, 2025 at 7:37 PM
    #172
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Nice! You look like your garage might be tall enough to store your camper on the ceiling if you ever want it off and need the floor space. I do this periodically, using four ratchet straps connected from the ceiling to 2x4s under the camper shell edge. Works pretty good for removing it alone.
  23. Aug 11, 2025 at 8:23 PM
    #173
    ToyotaDude
    ToyotaDude Member
    Nice! Looks like you took on painting the shell too after the hood!
    Lexmunk[QUOTED][OP] likes this.
  24. Aug 12, 2025 at 6:23 AM
    #174
    I'd really love to paint-match my camper shell, great work you've done there @Lexmunk!
