Transmission fluid D&F at 120K
Discussion in '2.5 Gen Tundras (2014-2021)' started by sea_weathered, Aug 4, 2025.
  1. Aug 9, 2025 at 9:44 PM
    #61
    tun44
    tun44 New Member
    2015 Tundra 4.6
    Thanks! And i thank everyone on here that took the time to explain proper maintenance. My local toyota dealership is adamant that the fluid is lifetime so people like me really do need yalls input when it comes down to important repairs/maintenance. After years of bad luck with cars this forum felt like a blessing to find haha.
    23Tundy and joseph_womack like this.
  2. Aug 9, 2025 at 10:33 PM
    #62
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    If you hadn’t read, general consensus I’ve seen is 60k for drain and fill, every 30k if you tow a lot
    blenton likes this.
  3. Aug 9, 2025 at 11:36 PM
    #63
    blenton
    blenton New Member
    Well, they aren’t technically wrong about the fluid… It will the last the life the transmission if you never change it - just not a long, happy life..
    My dealership parts guy gave me the same spiel when I asked for four quarts of ATF WS for a truck with 30k on the clock. He tried everything he could to NOT let me buy it. I made a pint of finding him every 30k miles for the next couple of years to buy more ATF. He got the point and laughed about it.
    30k miles is a good recommendation from a few transmission shops, as well as folks that work on Toyotas. It has worked well for me, though mine could have actually used it slightly shorter interval.
  4. Aug 10, 2025 at 5:38 AM
    #64
    joseph_womack
    Joe
    Louisiana
    Even shorter??
  5. Aug 11, 2025 at 4:53 PM
    #65
    sea_weathered
    sea_weathered [OP] New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    Okay, it’s done. It does seem to shift slightly smoother (maybe)
    The ATF that I removed still had a little red color to it, but it was dark. The littlest amount of glitter against the white background of the bucket, and no foul smell to the old fluid with 120k on it. The drain and fill took approximately 3.5qts.
    My normal operating temperature appears to be between 180°-200°f.
    There are two transmission temperature sensors according to the OBDLink MX+. The first one seems more stable, and the second one jumps around a lot. Here are some photos of the job.
    IMG_8754.jpg IMG_8757.jpg IMG_8755.jpg IMG_8762.jpg IMG_8758.jpg IMG_8769.png
  6. Aug 11, 2025 at 4:58 PM
    #66
    Great job. The lower more stable temp is your pan temp. The higher more volatile temp is the torque converter temp. It will match pan temp if locked for a while. When unlocked, there is more friction in the converter which cranks the heat up. They can be 50° apart at times.
  7. Aug 11, 2025 at 5:06 PM
    #67
    The Dude
    The Dude New Member
    Chandler, AZ, not anymore :(
    Good job! Looks a lot like when I did it, don't they all though :rofl:
    I did go a little overboard with mine lol
    https://www.tundras.com/threads/yet-another-atf-drain-fill.89432/
