Need help finding specific rear shocks for 1st gen tundra
Discussion in '1st Gen Tundras (2000-2006)' started by TtxrdCe, Apr 30, 2025.
  1. Apr 30, 2025 at 10:25 PM
    TtxrdCe
    TtxrdCe [OP] New Member
    2002 tundra sr5
    I couldn’t find any shocks for my 1st gen tundra I need shocks that are 16” extended and 12” collapsed they are stud mounts (on top) eyelids mount (on bottom) any suggestions help!
    Edit :measurement 18” extended and 13” collapsed
  2. May 1, 2025 at 5:39 AM
  3. May 1, 2025 at 6:31 AM
    Check out the "Suspension, wheel and tires ..." section of THIS THREAD, see if it helps you with what you're trying to do. It's our collective community knowledge on all the mistakes/issues/challenges with suspension on 1st gen Tundras.
    If nothing in those few bullets helps you solve your problem, come back here and reply, let us know what you're trying to accomplish and why, so we can help you out.
    TtxrdCe[QUOTED][OP] likes this.
  4. May 1, 2025 at 6:33 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Yeah I second the "why?". Do you have pics of your setup. That may help us guide you in the right direction
  5. May 1, 2025 at 6:34 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Must be slamming it. My rear 5100’s are 23.25” extended, and 13.84 collapsed.
    maybe cantilevered?
    TtxrdCe[OP] and shifty` like this.
  6. May 1, 2025 at 7:00 AM
    The reminds me, I need to update the megathread with more lowering info. Needed to hook in with assdog to start working on that.
    TtxrdCe[OP] and Sirfive[QUOTED] like this.
  7. May 1, 2025 at 7:23 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    TtxrdCe[OP] likes this.
  8. May 1, 2025 at 8:30 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Studs…as in a stem mount on both ends of the shock? A 4” stroke isn’t very much, so you could make just about any shock work by placing the shock mounts exactly where you want them.
  9. May 1, 2025 at 11:54 AM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    The older 80s and 90s pickups had the barrel studs on top and bottom for the rear and the shock slid on and a bolt threaded into the barrel stud to hold the shock in place.
    Considering our trucks dont have that style mount i can only assume its been slammed / notched and a stud welded in place because those shock lengths seem short. First place i would look is the 89-95 toyota pickup rear shocks. I dont have their lengths off hand but they sound about in that range. The 89-95 4wd rear shock is about 4" longer than the 2wd if my memory is right. Those would be the first place i checked.
  10. May 1, 2025 at 12:10 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    If you cant find any solid info in the thread Shifty referenced. I know Competition Engineering can help you, but those shocks might be over-kill.
    I was in your same situation many moons ago for my 69 Nova and had only a certain amount of travel and CE was able to get me what i needed.
    You should be able to place a call to any of the manufactures you are interested in and their tech staff should be able to provide specific shocks for your application.
    TtxrdCe[QUOTED][OP] and shifty` like this.
  11. Aug 10, 2025 at 10:28 PM
    TtxrdCe
    2002 tundra sr5
    Yeah ill look into those shocks my rear is slammed i got some shocks but they’re a bit out of range of the measurements im looking for Ill check those shocks out thanks! i haven’t checked this forum out but thanks for the advice.
  12. Aug 10, 2025 at 10:29 PM
    TtxrdCe
    2002 tundra sr5
    I’ll take a look at it.
