DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Jul 19, 2025 at 4:16 PM
    #3811
    COTundra23
    COTundra23 New Member
    yup and I’m running 1” spacers
    BreyTundy[QUOTED] likes this.
  2. Jul 19, 2025 at 4:39 PM
    #3812
    GreatBallsOfFire
    GreatBallsOfFire "I wanna go fast" - Ricky Bobby
    Seth
    Fairbanks, AK
    2017 Pyrite Mica Sequoia Limited
    Why spacers with the rock warrior wheels? They are ~+55 offset which should allow you to fit 37s with no rubbing and no cutting.
    COTundra23 likes this.
  3. Jul 19, 2025 at 4:47 PM
    #3813
    COTundra23
    still running factory sway bar up front
    Prefer the offset with a wheel spacer which provided about .5” of poke
    CaptRussia253 likes this.
  4. Jul 19, 2025 at 7:13 PM
    #3814
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Between the RW wheels (may need to lose the spacer), the aftermarket front bumper, and some custom alignment, I bet you’ll be fine.
    COTundra23[QUOTED] likes this.
  5. Jul 19, 2025 at 7:47 PM
    #3815
    COTundra23
    that’s what I’m thinkin. Will test fit without spacers tomorrow. Maybe remove sway bar
  6. Jul 21, 2025 at 10:58 AM
    #3816
    COTundra23
    alright got a alignment done this morning and rubbing less with a little more positive caster
    that being said, think I need to hammer or saw off some of the fender.
    what do yall recommend?
  7. Jul 21, 2025 at 8:00 PM
    #3817
    GreatBallsOfFire
    Seth
    Fairbanks, AK
  8. Jul 24, 2025 at 3:53 PM
    #3818
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
  9. Jul 28, 2025 at 5:32 AM
    #3819
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
  10. Aug 1, 2025 at 6:58 PM
    #3820
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    2020 Tundra Cement Grey TRD 4x4
    King lift,Leather seats,3m film wrap around,35's KO2 on FUEL Wheels,Line-X, backflip,Bam 10" exhaust with Toyota Black Chrome Exhaust tip,Amp research step,K&N air Filter,TRD air flow Accelerator
    Yo fellas, need some help. Finally pulling the trigger and going 37's. My question to you guys is I'm going all out and getting a new pair of shoes too. New wheels I'm looking at have a +10 offset. Would I be good with that? I'm also going down to a 17" from an 18" wheel. Heading to the local shop tomorrow morning so any info would be appreciated. Thanks
  11. Aug 3, 2025 at 4:09 PM
    #3821
    subspd
    subspd New Member
    Seth
    SW Florida
    2015 Tundra Platinum 4x4
    Magnuson Supercharger - TRD Exhaust - TRD BBK
    Hey all I am getting my lift installed this month and then I will be going with BFG 37s. Issue is I have the TRD BBK so I have to keep a 20" wheel to clear the caliper. I found a company that will build me the exact wheel I need to get the perfect offset. So from the online calculators it seems like I should go with a 20x8.5 et+45 rim to get me the best offset for the BFG 37x12.5x20 tires. Any input on this would be appreciated! These wheels ain't cheap.... And I don't get any do overs.
    https://9and3wheels.com/collections/all-wheels
  12. Aug 3, 2025 at 5:32 PM
    #3822
    SAGE63
    San Diego County
    I would double check the +45. seems the sweet spot is +25 -+35... with 18s anyway
    subspd likes this.
  13. Aug 6, 2025 at 6:44 AM
    #3823
    martiartisan
    martiartisan New Member
    North Texas
    2020 Tundra DC, 2006 Tundra Crew Cab
    Adv fiberglass, king suspension, cbi armor, RLD Cap
    IMG_4377.jpg Took the RLD cap off and installed a Rough Country Speedometer Calibrator. Truck feels great with the reduction of weight. The canopy alone was 300+lbs not including the roof rack
  14. Aug 6, 2025 at 7:56 AM
    #3824
    2014 Black tundra
    2014 tundra sr5
    Nice looking truck. :cool::thumbsup: Your build looks proportionately right. :101010:
  15. Aug 6, 2025 at 8:15 AM
    #3825
    martiartisan
    North Texas
    Thanks! I have a SOB fabrication high clearance rear bumper sitting in the garage that I need to install. I think that’ll even out the look of the rear when compared to the front. I am on 37x13.50 right now but think I will switch to 12.50 for me next set of tires
    Trusty Rusty likes this.
  16. Aug 6, 2025 at 9:34 AM
    #3826
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Have you hammed down the pinch welds?
    I have KO2s as well in 37s with ET0, I had to flatten the pinch welds to allow proper clearance during compression.
  17. Aug 6, 2025 at 2:38 PM
    #3827
    Trusty Rusty
    Trusty Rusty New Member
    2011 Rock Warrior CrewMax
    Truck looks RAD! Nice work...calvary blue hits just right. Running rear swings on the SOB bumper? Arguably the best option out there, his work is top tier - keep thinking a road trip out to NM from Houston for a couple bumpers might be time well spent. :bowdown:
  18. Aug 6, 2025 at 3:01 PM
    #3828
    martiartisan
    North Texas
    Thanks dude! I got my bumper optioned for the dual rear swing outs but not sure if I’ll run both of them all the time. I probably would have driven out there myself if I lived in Texas at the time of ordering the bumper!
    Trusty Rusty[QUOTED] likes this.
  19. Aug 7, 2025 at 11:49 AM
    #3829
    paulbk
    paulbk New Member
    Finally joined the club!
    Went from 35s on 18” SCS SR8 +25 offset (added bora spacers 1.25” effectively making the offset -8).
    Running 37s on 17” RRW rr7-7 +0 offset.
    The wheels were pretty flush with the flares, but didn’t poke as much as I’d prefer….. so i reinstalled the 1.25” spacers, effectively making the offset -32.
    Obviously there’s a ton of rubbing and I will be grinding down on plastics for fitment.
    May not be considered the ideal setup, but I happy to achieve the stance I was aiming for.
  20. Aug 8, 2025 at 5:28 AM
    #3830
    COTundra23
    looka great!
    what are you doing with those SR8s…
  21. Aug 8, 2025 at 9:37 AM
    #3831
    paulbk
    paulbk New Member
    Gotta offload and sell the SCS SR8s.
    I had shop remount the 35s on the wheels (after pulling the sensors) so the prospective buyer can just throw them on.
    I considered keeping them as a spare set, but I don’t have much room to store them.
  22. Aug 8, 2025 at 5:28 PM
    #3832
    AaronD334
    AaronD334 TX
    Aaron
    Austin, TX
    2015 Tundra TRD Pro
    Just set aside the 35’s and joined the club. Slapped some 37x12.50 Toyos on Method MR318 18X9 5X150 +18
    Thanks to everyone here posting their experiences I have zero rubbing :cheers:
  23. Aug 8, 2025 at 5:54 PM
    #3833
    martiartisan
    North Texas
    Looks great! Do you have a front view showing how much the tire pokes out or is it flush with the fender?
  24. Aug 8, 2025 at 6:39 PM
    #3834
    AaronD334
    AaronD334 TX
    Aaron
    Austin, TX
    2015 Tundra TRD Pro
    Thanks! It’s slightly more narrow than the fenders.
    I have 1.5” spacers that I ran with the 35s and had the shop install the wheels with the spacers out of curiosity. They said they were rubbing the body mount slightly. My plan all along was to ditch the spacers so I’m happy but I may put them back on at some point we’ll see.
  25. Aug 8, 2025 at 7:53 PM
    #3835
    martiartisan
    North Texas
    I do like the stance of your truck without the spacers! I have 0 offset and definitely have some rubbing at full lock
    AaronD334[QUOTED] likes this.
  26. Aug 8, 2025 at 9:40 PM
    #3836
    AaronD334
    AaronD334 TX
    Aaron
    Austin, TX
    2015 Tundra TRD Pro
    Good to know. I’m going to try to take it offroad this weekend and see how they tuck and if there’s any rubbing.
    One thing I just noticed is that the rear wheels seem to be much closer to the rear of the wheel well vs the front so I have a feeling I may rub there. Maybe I installed my leafs springs backwards? :monocle::facepalm:Not sure if it would have that effect.
    martiartisan[QUOTED] likes this.
  27. Aug 9, 2025 at 3:29 PM
    #3837
    TeaRD
    TeaRD New Member
    S.F. Bay Area
    2020 Crewmax 4x4 1794 Edition
    Ironman FCP 3/2 Lift | JBA UCAs | Spidertrax 1.25" spacers | 285/75/18 Toyo RT Trails | F/R SwayBar delete
    That looks great.
    I have the exact same set of Fuel wheels as on your truck in the last picture, 18x9 with a +18 offset. I’m curious if you had the same spec. Also wondering if you swapped out the wheels plainly for the looks since you’re on the same +18 offset, and not for potential fitment issues with 37 inch tires.
    I want to pull the trigger on 37s but really thinking it would be pretty tight with potential rubbing on the body mount.
  28. Aug 9, 2025 at 5:24 PM
    #3838
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Truck looks good. I had debated the same bronze Fuel wheels for my mesquite Tundra a while back.
    TeaRD[QUOTED] likes this.
  29. Aug 9, 2025 at 5:43 PM
    #3839
    AaronD334
    AaronD334 TX
    Aaron
    Austin, TX
    2015 Tundra TRD Pro
    I swapped the wheels for the bronze look. If I had yours I would keep them! Also, my stock TRD pro fenders flares have bolts so having bolts on the wheels as well just felt a little overkill.
    My fuels were +20 offset. It’s my understanding that keeping the offset between +18 and +25 is the sweet spot. The BMC and SPC UCA are definitely helping.
  30. Aug 10, 2025 at 12:38 PM
    #3840
    TeaRD
    TeaRD New Member
    S.F. Bay Area
    That makes sense, great choice on the wheels I must say.
    The bronze really goes well with a lot of colors on our trucks.
    I don’t have any rubbing on the body mount with 35s but it’s tight in there and I reckon 37s would definitely rub with my wheels offset.
    I love the way the Fuel’s look but can’t decide where I want to give in, bmc or a higher offset wheel.
