General Supercharger Thread
  1. Aug 5, 2025 at 12:05 PM
    blenton
    blenton New Member
    Since we are talking about plugs, what would be a reason to go with a different heat range on the plug? Meaning, what signs/issues/problems would one be seeing? I seem to recall discussion being <10PSI, stick with the recommended IHK22's, >10psi, go with a step up in heat range. And the higher number means a colder plug?
    I looked like mad for the IKH22's that Whipple suggested, only to realize that it was a typo as noted by @Wynnded and @Mdl. In fact, I still have no idea which is correct.. But I ordered them from RockAuto with some other parts, so shipping didn't bother me. As long as they aren't coming from Amazon or eBay, I don't mind paying a little in shipping - I've personally received too many counterfeit parts from them.
    Wynnded, snivilous[OP] and e30cabrio like this.
  2. Aug 5, 2025 at 12:30 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    A colder plug removes heat faster reducing chances of detonation/pre-ignition. They can have drawbacks like fouling/rough idle/lower mpg. I haven't experienced those well maybe mpg. I went with them as it was suggested when I installed the SC.
    The 22's are fine and if the plugs looks like it's over heated/pre ignition maybe try a step colder.
    The 24's are 2 steps colder than stock.
  3. Aug 5, 2025 at 1:15 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    did he seafoam the gas, oil, or both? I usually do both, and change the oil after 100 miles
    Wynnded, e30cabrio and HulkSmurf14 like this.
  4. Aug 5, 2025 at 1:29 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Both as I understand it, and one or two tanks through and back to what it was doing before. I don't think he's changed the oil yet.
    Wynnded and HulkSmurf14 like this.
  5. Aug 5, 2025 at 1:33 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Wonder if he goes to a 40w if it'll quiet down?
  6. Aug 5, 2025 at 1:43 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I'm really glad that Whipple went through the effort to Bold and Red THE WRONG PART NUMBER!
    I'll order the ones from rock auto.
  7. Aug 5, 2025 at 2:05 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    I switched to 10w/30...no change in engine Noise
  8. Aug 5, 2025 at 4:13 PM
    blenton
    blenton New Member
    While researching the chain tensioner issues, I’ve seen a few cases where Seafoam has quieted down the timing chain tensioner, only to have it return shortly after. Same goes for a fresh oil change as Viktor said it would. Mine would quiet down after an oil change for 500 miles or so, but mine also only made noise at a very particular temperature. Stone cold or fully warm, it never made noise - just if I idled about 5 minutes in to the warm up cycle.
    It would be interesting to know if your customer’s truck is making enough noise from the timing chains to register as knock. It wouldn’t be a total surprise to me.
  9. Aug 5, 2025 at 4:44 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’d try some Valvoline restore and protect for a few oil changes if I got the tensioner clatter.
  10. Aug 5, 2025 at 4:56 PM
    Silver17
    Eastern PA
    Also, I got my core deposit back today for the VB. Thanks @Cruisers & Co.
    Sounds like Johnny has been very busy with a custom build for an event.
  11. Aug 5, 2025 at 6:33 PM
    snivilous
    SW UT
    I won't regurgitate too much from the Sniv Speed Shop thread, but after 10x revisions over the past two days, I'm finally comfortable offering a 14-21 gauge mount for the center console. If you're interested in a initial production/pseudo prototype model and giving feedback, the prices are lowered and they are ready for shipping/building; lots of options from DIY flat patterns to customized front cut outs! https://www.snivspeedshop.com/product/14-21-tundra-gauge-mount
  12. Aug 5, 2025 at 6:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Looks great!
  13. Aug 5, 2025 at 6:48 PM
    blenton
    blenton New Member
    Woohoo! Ordered :)
  14. Aug 6, 2025 at 8:42 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Looking at the diagrams, it seems the three share power at the D53 connector in the junction box between the firewall & air box. I checked the blue & wite stripe wires, all seem ok.
    I just also got 0778, so the transmission has entered the chat. goody
  15. Aug 6, 2025 at 8:49 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    The wiring for the sensors is in the same bundle as the transmission wiring, top of transmission to back of engine...maybe the harness was damaged during one of your engine removals/reinstalls?
    Wynnded, Mdl, blenton and 1 other person like this.
  16. Aug 6, 2025 at 8:51 AM
    blenton
    blenton New Member
    That’s was I was thinking as well.
    Wynnded, Mdl and mustang67408 like this.
  17. Aug 6, 2025 at 8:53 AM
    e30cabrio
    This is undeniable.
    I'm just beyond sick of bad mechanics.
  18. Aug 6, 2025 at 8:56 AM
    mustang67408
    Victor
    Welcome to my world..They make the rest of us look bad.
    Wish you were closer.
  19. Aug 6, 2025 at 9:25 AM
    bflooks
    bflooks New Member
    Metrowest MA
    get it to Sniv! ask him to haul the Hilux down so you have it as collateral (and for fun). :)
  20. Aug 6, 2025 at 1:12 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Nothing but desperation to get the PS box out.
  21. Aug 6, 2025 at 6:04 PM
    bflooks
    bflooks New Member
    Metrowest MA
  22. Aug 6, 2025 at 6:20 PM
    e30cabrio
  23. Aug 6, 2025 at 7:50 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This seems to be the place to bring this up ;).
    Have any of you all with this gauge ever had issues with it displaying A/F clearly out of range swings or freezing at a particular random, clearly non-accurate value then maybe going back to normal or displaying -- -- ? When taking a log, it also shows the displayed weirdness. I've already replaced the sensor, but now I'm leaning hard toward a neurotic gauge but hoping to find something a little more solid before gambling another $350 on another one. Tomorrow I'll check to see if any of my wiring wasn't up to snuff.:hattip:
    Mdl likes this.
  24. Aug 6, 2025 at 7:55 PM
    mustang67408
    Victor
    I've replaced the sensor already after 3 months.
    Every now and then the gauge acts weird like you said..
    I'm Snivtuned and never had any issues.
    Not sure I completely trust the gauge either...chineseium....
    The gauge cut out on me the other day, but turned out to be a bad connection..
    Have you tried resetting it?
    I've done that a few times now, seemed to help
    Mdl likes this.
  25. Aug 6, 2025 at 8:04 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Both of the sensors that I've had hooked up acted the same, so I've sorta ruled them out. I've been resetting it by shutting off, then restarting the truck. Are you referring to trying a recalibration of the sensor? I seems like it wants to act up when I'm wanting to get a log on the Interstate and then I have to wait until the next interchange to stop/start.
    Mdl and mustang67408[QUOTED] like this.
  26. Aug 6, 2025 at 8:10 PM
    e30cabrio
    Yes. PSB-1 that freaked out sporadically. ECF-1 was AFR dead out of the box. I had to send it in for review, a month later I got a new one.
    Mdl, Wynnded[QUOTED] and mustang67408 like this.
  27. Aug 6, 2025 at 8:14 PM
    mustang67408
    Victor
    Yes, the recalibration, taking it out of the exhaust and doing whatever the instructions say .. Sorry I forget and don't have then handy
    They do seem to be a hit and miss... Again, chineseium ...
  28. Aug 6, 2025 at 8:48 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I've never had an issue with my AEM. I changed the sensor out after I blew my engine. That was back in 2015.
  29. Aug 6, 2025 at 8:52 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yep same here AEM no issues. Even caked in oil on the way back to the house lol
    e30cabrio, nobodyintexas, Mdl and 3 others like this.
  30. Aug 6, 2025 at 8:56 PM
    snivilous
    SW UT
    I should really stop recommending Innovate. Except mine has been flawless for like 6 years and they're the only ones that don't look like they came from the 2Fast2Furious production :mad:
