  1. Aug 5, 2025 at 7:59 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This.
    BR73 and HulkSmurf14 like this.
  2. Aug 5, 2025 at 8:08 AM
    Morebouldersplease
    Morebouldersplease New Member
    G
    Brushy Creek, Texas
    2017 Super White DC TRD Pro
    WKOR Sliders Valhalla shield front and rear plates Falken AT3W 295's Snugtop Highliner Sport
    At last! TRD Pro LED Headlights with the iHacker harness. Pretty smooth install!
  3. Aug 5, 2025 at 8:11 AM
    NEVERGIVEUP
    NEVERGIVEUP New Member
    2021 Super White Tundra SR5 CM
    How are those at night time?
  4. Aug 5, 2025 at 8:13 AM
    Morebouldersplease
    G
    Brushy Creek, Texas
    I started last night after the baby went down and finished leveling them and putting things back together early this morning. I'll let you know tonight!
  5. Aug 5, 2025 at 9:09 AM
    RobertD
    Robert
    DFW, Texas
    Huge improvement over the halogens. You get a wider area of illumination and much better illumination as well. It's worth the upgrade if you do basically any driving where headlights are needed.
    And the fact that they look better is a nice plus.
  6. Aug 5, 2025 at 8:17 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Finally installed the Coachbuilder tie rods. They’re crazy beefy. After the truck got aligned, everything feels super tight, not as sloppy as before. The old tie rod boots were worked, and I had some slop in my steering.
    edit. My cv joints aren’t actually at those angles. Truck was lifted on a jack.
  7. Aug 6, 2025 at 3:42 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Mine are lol
  8. Aug 6, 2025 at 6:47 AM
    martiartisan
    martiartisan New Member
    North Texas
    2020 Tundra DC, 2006 Tundra Crew Cab
    Adv fiberglass, king suspension, cbi armor, RLD Cap
    Took the RLD cap off and installed a Rough Country Speedometer Calibrator. Truck feels great with the reduction of weight. The canopy alone was 300+lbs not including the roof rack
  9. Aug 6, 2025 at 6:54 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Yoyr truck looks great au natural! I take my topper off every summer...or for at least a few months a year...feels SO good! This weekend, however, I'm throwing the topper back on...tho, I'm at 180lbs with mine...
  10. Aug 6, 2025 at 6:57 AM
    Boneskull420
    Boneskull420 New Member
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Was the Speed calibrator a pain? Would also like to hear an update as to how accurate it played out. Truck looks good!
    OHwendTrd and Tripleconpanna like this.
  11. Aug 6, 2025 at 6:59 AM
    martiartisan
    North Texas
    I have a roll up tonneau cover I will throw on just to keep things dry and looking “secure”. If I were to do it again I am not sure I’d go with the RLD canopy
    HulkSmurf14[QUOTED] likes this.
  12. Aug 6, 2025 at 7:06 AM
    martiartisan
    North Texas
    Was surprisingly easy to install. About 30 min total. You do need a windows computer to program it because Rough country uses the same hypertech software which is windows based. I programmed it off of tire size vs the gear ratio. Felt like this yielded better results. I left the usb cable hooked up so I could just plug in a laptop and fine tune it without having to pull the instrument cluster again. Took me a couple tries to get it perfect but now my Speedo matches perfectly with 2 different gps apps I used for speed comparison. The computer has adapted to reflect true mpg and I feel like the shift points/rpms are a little better. Overall I am happy and should have done this mod a long time ago.
    The biggest thing I learned is it won’t be perfect if you just put your current tire size. You have to tweak it a bit to get the speeds to match between gps and speedometer. For example my true tire height is 36.77. By putting this number it got me closer on the speedometer but i was still 2mph off. I found that going down a size in my case to 35.77 got the numbers to match perfectly
  13. Aug 6, 2025 at 7:12 AM
    Boneskull420
    Tn
    Nice, thanks! Also just noticed the wide fenders. That looks sweet!
  14. Aug 6, 2025 at 7:51 AM
    mr_schiz
    mr_schiz New Member
    Caleb
    2020 TRD Sport Double Cab
    Fox 2.5 Resi's, 315/70R17 Toyo MT, Diamondback Switchback Tonneau
    Are those CBI Offroad sliders? If so how are you liking them and would you recommend? How was the install?
    martiartisan[QUOTED] likes this.
  15. Aug 6, 2025 at 8:04 AM
    martiartisan
    North Texas
    thanks! Haven’t decided if I’ll do glass fenders in the rear. I have an SOB fabrication high clearance rear bumper sitting in the garage that I need to install
    Yota303 and Boneskull420[QUOTED] like this.
  16. Aug 6, 2025 at 8:07 AM
    martiartisan
    North Texas
    Yes they are the cbi sliders. Overall I really like them and have been solid. Top fill plate feels good to stand on. I just primed and spray painted them for ease of touch up. I think when I respray I’ll go with raptor liner just to get the added texture. I will say they are a little slick when wet but I don’t think that is any fault to the slider and more the paint I used. Just a matte finish rust-oleum spray paint.
    Install was a little of pain from what I remember but I also did the install myself. The hardest part was bolting it up by the gas tank since there isn’t a ton of room between the tank and frame where the slider connects
  17. Aug 6, 2025 at 10:38 AM
    Boneskull420
    Tn
    Trying my hand at plastic welding, trying to design a pannel for 8in speakers to go in the rear door pannels where the bottle holders/trash collector is, so instead of just cutting the door to pieces I used a heat gun to pop the plastic nubs on the back side and pulled this whole piece out to get the shape and measurements for the speaker pannels. Now I'm welding this back. The end game is have a pannel/mesh cover to go over the whole pice to cover the speakers and crossover and minimal destruction to the pannel and still look semi flush and clean in my opinion 20250804_151213.jpg 20250806_112659.jpg
  18. Aug 6, 2025 at 3:45 PM
    TreeCat
    TreeCat New Member
    2017 White Limited 4x4
    Ambitious weekend of maintenance at 150k. Made it through the dirty stuff: front and rear differential fluid, transfer case fluid and power steering fluid. Hopefully do the spark plugs this weekend. Started off easy, rear diff and t-case fluids drained and filled no issues. (side note: the liqui moly 75W oil I got for the t-case had a built-in extension tube which was super helpful). The reason I couldn't get everything done was the dang front differential. Specifically the 10mm hex drain plug that I stripped almost immediately, which I found out was a common problem. Yay! The ensuing hours of problem solving led me to a thread on here that suggested replacing the plug with that of a Lexus GX470, which has a 14mm bolt head. After a couple trips to Harbor Freight and the Lexus dealer, I finally got the drain plug free with a 3/8" pipe nipple extractor and me kicking the ratchet like Bruce Lee. Why does it feel like every bolt or plug last touched by the dealership is tightened by Superman? Anyway, replaced the mangled bolt with the Lexus one, replaced the two rear diff plugs for good measure, and used all new washers. And made sure everything was torqued to spec!!!
    After all of that the power steering flush was a breeze. Bought a fluid extractor recently, hooked it up to the return hose of the power steering fluid reservoir and quickly pulled all the old fluid out while pouring the new stuff in. Another diy job that took longer than it should but will go much smoother next time.
  19. Aug 6, 2025 at 4:05 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    HVAC motor fan upgrade
  20. Aug 6, 2025 at 4:31 PM
    NMTundra
    NMTundra New Member
    Anyone have a Limited/Platinum with the stock 20" wheels and spacers? Trying to decide if that would give me the stance I want or if I'm going to need to go aftermarket.
    Pimpala1962 likes this.
  21. Aug 6, 2025 at 4:53 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Good days work on the Tundra.If you don't have any of these electrical disconnect pliers get a pair off Amazon.They make life much easier.PXL_20250505_003340205.MP.jpg
    MGMTundra18, schleinj, equin and 9 others like this.
  22. Aug 6, 2025 at 4:54 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    YES my wife got me a set from temu!
  23. Aug 6, 2025 at 5:04 PM
    Boneskull420
    Tn
    I dont have either of those trims but me personally I dont like the idea of spacers, just another component to fail that you dont want to fail while driving, not saying they are bad just more maintenance in my opinion
  24. Aug 6, 2025 at 5:57 PM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    This truck is a recent purchase, and needed a tonneau cover asap. The Tyger T1 soft cover arrived tonight. I pulled the rails and coolers to do a full clean-out. I then de-greased, dried, and brushed in 303 UV protectant. IMO it looks better than new. I am able to fit all my req tac gear in one side cooler, they fit a LOT.
  25. Aug 6, 2025 at 6:06 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Did my annual swap out of the cabin air filter. Almost all paved roads. Yuck!
  26. Aug 6, 2025 at 6:35 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Might bump up your interval to 6mos:)
  27. Aug 6, 2025 at 7:24 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    They came on mine, but didn’t suit what I was looking for. Went with Icon 18’s and Falkens.IMG_5100.jpg
    pkeawe809, rdiddy5, equin and 10 others like this.
  28. Aug 6, 2025 at 7:26 PM
    Those Rebounds are nice wheels. We have the black ones on one of our 4Runners.
    rdiddy5, Boneskull420, ATV25 and 2 others like this.
  29. Aug 6, 2025 at 7:30 PM
    Tundra2n3
    Tundra2n3 New Member
    2015 Tundra DC SR5 TSS Off Road V8 5.7L 4x4
    Great write up and pictures! Especially the part numbers!
  30. Aug 6, 2025 at 7:50 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    Full spare from DT - Method 701, Nokian Outpost nAT 285/75/18.
