General Supercharger Thread
  1. Aug 1, 2025 at 12:11 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I'm hoping to shoe horn it behind the air cleaner.
    Thanks
    Seeing as they never responded to the email about the cap & don't answer the phone, I'll see about getting it in, more coolant is better.
    Thanks
    HulkSmurf14 likes this.
  2. Aug 1, 2025 at 3:45 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Show off some photos of your setup as my imagination is not as strong this fine Friday! :homer:
  3. Aug 1, 2025 at 5:33 PM
    e30cabrio
    This is before I reverted to the Magnuson reservoir.
    This is now.
    Downstream O2's have less than 2k on them, were throwing heater 37 & 57 errors. Do you guys think cleaning them helped them? (new ones are in)
  4. Aug 1, 2025 at 6:34 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm just the peanut gallery but if I could suggest a re-route of your setup.
    Bottom port from tank to pump. Pump to I/C, I/C to SC i/c brick out to top port of tank.
    My O2's needed a thorough cleaning after they were covered in oil. But they only survived another year before replacing.
  5. Aug 1, 2025 at 7:30 PM
    e30cabrio
    With the large tank is how the shop gave it back, I have it the way you suggest now (I think)
  6. Aug 1, 2025 at 7:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Cool. And for your new tank. You want to have bottom port to pump and return on top. Just to keep system from getting airborne and longevity.
  7. Aug 2, 2025 at 8:46 AM
    e30cabrio
    How is it possible 0 mile new sensors are still throwing 037/57 & it idles when the codes are there like it's cammed? Also odd, it dies when the codes are cleared. (starts right up, runs fine)
  8. Aug 2, 2025 at 8:56 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Are all your grounds hooked up? ECU wiring to O2's?
    Wynnded likes this.
  9. Aug 2, 2025 at 9:06 AM
    e30cabrio
    Yup, I have good charging voltage, which generally is the first thing to go when there are ground issues. I checked them when the Voltage Pro stopped working. I'm back over 14 on the HKB.
  10. Aug 2, 2025 at 10:26 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    More like the grounds to the valve covers/ transmission etc.
  11. Aug 2, 2025 at 12:25 PM
    nags
    nags New Member
    Aaaand.... The Whipple is missing a bunch of parts, including the injectors, and the heat exchanger was damaged either previously or in shipping. ‍♂️
    Mdl likes this.
  12. Aug 2, 2025 at 12:28 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Can’t catch a break
  13. Aug 2, 2025 at 12:29 PM
    nags
    nags New Member
    Not even a little. XAT reached out to Whipple already requesting them to overnight everything.
    He's also not sure the Stillen intake is gonna work with the Whipple.
    bflooks and Mdl like this.
  14. Aug 2, 2025 at 12:32 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Stillen box won’t bolt in but I’m sure could be made to work
    HulkSmurf14, nags[QUOTED] and Mdl like this.
  15. Aug 2, 2025 at 12:36 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    That seems to be a common issue with Whipple not including all the parts.
    snivilous[OP], nags[QUOTED] and Mdl like this.
  16. Aug 2, 2025 at 1:20 PM
    blenton
    blenton New Member
    Oof. When I had my 2.9L installed a year and half ago, they were missing a tensioner pulley. They overnighted the part without a fuss. Guess I better go double check my box...
  17. Aug 2, 2025 at 1:41 PM
    e30cabrio
    Yes, to the valve covers, I didn't look at the transmission. I erased the memory and relearned the alcohol with my Autel, the negative has been off the battery since 10am
    I'll see what there is to be seen. Do you know where the transmission ground is?
    It's 120, I'd like to know where I'm looking, searches have it all over the place lol.
    Thanks.
  18. Aug 2, 2025 at 2:14 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Should be passenger door side just aft of the t-stat/puck.
    e30cabrio likes this.
  19. Aug 2, 2025 at 4:46 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Whipple sucks fucking ass, I would never buy or recommend one. First the shit of messed up blowers, then slow to fix, forever to ship, then I saw plenty of shit on Reys that came straight from their factory that was embarrassing, and now nags issues.
    ssmokedz, nags, Silver17 and 6 others like this.
  20. Aug 3, 2025 at 4:22 AM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Packing up the truck today and heading down to National Speed in NC. 8 hours oh boy! Working out of a hotel so didn’t have to take pto which is nice. Can’t wait to hear how the headers sound with the spd cat back. Excited!
  21. Aug 3, 2025 at 8:02 AM
    e30cabrio
    The Trans ground is there but it's frayed and looks corroded. I added to a stud on the opposite side of the truck the "knitted" strap in the picture and added the 2 gauge to the driver side valve cover and connected it to the body ground to the right of the battery.
    Silver17, Mdl, M3Tundra-JK and 5 others like this.
  22. Aug 3, 2025 at 4:15 PM
    WinterWarlock21
    South Jersey
    500 miles -- took 9 hours with 1 stop to refuel/bathroom (16 mpg!) - should've been 7.5 hours but as soon as I hit Virigina it was stop and go traffic all the way until Richmond on i95. I'll update Friday with my experience when I get home (hopefully no traffic when I leave 3pm Thursday ha).
  23. Aug 3, 2025 at 4:50 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I only brought up the grounding strap issue as you had several engine changes. Sometimes it can be overlooked and cause some funky stuff with the coils/plugs/shifting and O2's.
  24. Aug 3, 2025 at 5:25 PM
    e30cabrio
    It could not hurt, the transmission ground was needing attention. Adding a better ground to the valve cover can't hurt.
    Thanks!
  25. Aug 3, 2025 at 8:23 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'd grab a picnic lunch, hang out for a few hours and then cannonball run that baby home during the night... you know, as a proper break-in :D
  26. Aug 4, 2025 at 7:18 AM
    e30cabrio
    037 & 57 won't go away, searches say it must be the wiring, if not the sensors. Anyone know where in the circuit both downstreams would be sharing wiring? I doubt both had a separate failure.
    Altermatively, I did the "training" to allow HPTunes to open emissions locked codes, but still can't edit these. Have you guys found a way around that?
    mustang67408 likes this.
  27. Aug 4, 2025 at 8:00 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    The only wire they share is the 12v power supply. (+B)
    They both ground separately thru the ecu. (E1)
    They both send signals to the ecu thru separate wires (OX1B) (OX2B)
    They each have separate wires for the heater circuit power supply from the ecu. (HT2B) (HT1B)
  28. Aug 4, 2025 at 8:12 AM
    e30cabrio
    Thanks, I didn't think the heaters shared anything, this is infuriating.
    Also, I know they don't have a separate fuse but checked all the under hood fuses (hate going under the dash, I would like to stone whoever put them there) No bad fuses.
  29. Aug 4, 2025 at 8:48 AM
    mustang67408
    Victor
    Junction connector D53 is the common 12v to +B, make sure its snapped in properly.
    Here's the diag for that circuit. (PDF)
  30. Aug 4, 2025 at 9:25 AM
    e30cabrio
    Thanks! None seemed loose or had any visible issues. I pulled all, sprayed Deoxit-5 on both sides, & made sure all were firmly connected/all wires were firmly in their sockets. It still stalled when I started it (another odd new symptom) but is idling normally & no code in 5 minutes idling. Hopefully you are on to it.
    I sent sniv a log yesterday (still having Pro cable Innovate not reporting issues) maybe between this and a tune I can get a freaking breaak.
    Thanks for your help!
