What are you MAKING today?
Discussion in 'Food Talk' started by T-Rex266, Aug 2, 2020.
  1. Mar 22, 2023 at 4:58 PM
    #751
    TaquitoBandito
    Joel (AKA Bif)
    I'm going to make a La Viña–Style Cheesecake this week. I picked up the 2.5 lbs of cream cheese yesterday. Now I just have to find the time to do it.
  2. Mar 25, 2023 at 4:10 PM
    #752
    SwitchThrottle
    2021 Barcelona CrewMax
    10lb rib roast
    Moon Puppy, RainMan_PNW, JMB and 3 others like this.
  3. Mar 25, 2023 at 4:18 PM
    #753
    TaquitoBandito
    Joel (AKA Bif)
    :drool:
  4. Mar 25, 2023 at 4:50 PM
    #754
    SwitchThrottle
  5. Mar 28, 2023 at 6:54 PM
    #755
    TaquitoBandito
    Joel (AKA Bif)
    @SwitchThrottle Made the La Vina-Style Cheesecake tonight. Pretty good stuff. No water bath and it cooks at a high heat. No crust, just eggs, flour, cream cheese, sugar and heavy cream. Tastes like a mix between a custard and a campfire marshmallow. Has a nice oozy center - the pic of it came out blurry but if you squint, you'll see it.
  6. Mar 28, 2023 at 7:36 PM
    #756
    SwitchThrottle
    Looks amazing!
    :101010:
    I don't water bath mine either, but I do a graham cracker crust base and a half a lemon zested. 500 for 15 minutes, 200 for an hour, then slow cool.
  7. Mar 28, 2023 at 7:38 PM
    #757
    TaquitoBandito
    Joel (AKA Bif)
    Interesting - This cooked for 45 minutes at 425
  8. Mar 28, 2023 at 7:48 PM
    #758
    SwitchThrottle
    If you want the recipe, let me know. I'm sure its very similar to yours.
  9. Mar 28, 2023 at 7:51 PM
    #759
    SwitchThrottle
    I made Homemade brownies on Saturday for the 1st time. Also super simple.
  10. Mar 28, 2023 at 8:27 PM
    #760
    TaquitoBandito
    Joel (AKA Bif)
    That would be great - thanks!
    La Viña–Style Cheesecake (from Cooks Country)
    7 large eggs, room temperature
    2 cups (14 ounces) sugar
    2¼ pounds (36 ounces) cream cheese, room temperature
    1 cup heavy cream, room temperature
    ¼ cup (1¼ ounces) all-purpose flour
    Adjust oven rack to middle position and heat oven to 425 degrees. Spray or lightly sprinkle 2 approximately 16 by 12-inch pieces of parchment paper evenly with cold water. Crumple each piece of parchment into ball, then gently uncrumple. Overlap parchment pieces slightly to form approximately 16-inch square. Press parchment into bottom and sides of 9-inch springform pan. Fold overhanging parchment outward, over edge of pan. Using scissors or kitchen shears, trim overhanging parchment to about 1 inch past edge of pan.
    Process eggs and sugar in large (14-cup) food processor until mixture is frothy and pale yellow, about 1 minute. Add cream cheese, heavy cream, and flour and pulse until cream cheese is broken into large, even pieces, 8 to 10 pulses. Process until mixture is completely smooth, about 2 minutes, scraping down sides of bowl and breaking up any large clumps of cream cheese as needed (processor bowl will be very full).
    Transfer batter to prepared pan and place pan on rimmed baking sheet. Bake until top of cheesecake is deeply browned, edges are set, and center of cheesecake registers 155 degrees, 45 to 55 minutes (center will be very jiggly). Remove cheesecake from oven and transfer to wire rack. Let cheesecake cool in pan for at least 2 hours.
    Remove side of pan. Gently peel parchment away from sides of cheesecake until parchment is flush with counter. To slice, dip sharp knife in very hot water and wipe dry after each cut. Serve slightly warm (after 2 hours cooling) or at room temperature. (Cheesecake can be refrigerated for up to 3 days; let sit at room temperature for 1 to 2 hours before serving.)
    Rgross2112 and FrenchToasty like this.
  11. Mar 29, 2023 at 3:21 PM
    #761
    SwitchThrottle
    @TaquitoBandito
    Cheesecake
    40oz full fat cream cheese (room temp)
    1 1/2 cups sugar
    3T flour
    1t Vanilla
    1/2t lemon zest
    5 eggs room temp
    2 yolks room temp
    1/2 cup heavy cream
    Crust
    1 package graham crackers (crushed)
    1/4 cup butter melted
    3T sugar
    Heat oven to 350f
    Mix crust (I use a ziplock) and press into bottom of 9" springform.
    Bake 10-15min. Take out to let cool.
    Heat oven to 500f
    In a large mixing bowl, beat Cream cheese with mixer, then blend in sugar, flour, vanilla, lemon zest, eggs, yolks and cream until fully blended.
    When done mixing, tap the bowl on the counter (a lot...you have to get the bubbles out).
    Pour batter into spring form pan (try not to add bubbles when pouring).
    Into the oven at 500 for 15 minutes.
    Turn oven down to 200 and bake 60 minutes more.
    Turn oven off leave cake in over with door closed for 60 minutes.
    Open the door leave cake in for 30 minutes.
    Remove cake to cool for another 30-60 before moving to fridge.
  12. Mar 29, 2023 at 5:33 PM
    #762
    TaquitoBandito
    Joel (AKA Bif)
    :hattip:
  13. Apr 21, 2023 at 10:22 AM
    #763
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    Knocking up some pork tenderloins on the recteq smoker
  14. Apr 21, 2023 at 10:25 AM
    #764
    Yum
    T500[QUOTED] likes this.
  15. Apr 21, 2023 at 4:26 PM
    #765
    Rgross2112
    Rush
    2020 Silver TRD Limited
    What’s up with those little green flakes in those brownies?:monocle:
  16. Apr 21, 2023 at 4:28 PM
    #766
    Rgross2112
    Rush
    Went to a 50’s style drive up restaurant. Had their Italian steak sandwiches with fries and a chocolate malt shake. Entertained by watching people rip out burning up their tires and showing off how they like to invest in fuel and rubber.
  17. May 21, 2023 at 4:46 PM
    #767
    justcuz
    justcuz 2.5 Gen Member
  18. May 31, 2023 at 11:33 AM
    #768
    justcuz
  19. Sep 26, 2023 at 6:53 AM
    #769
    Chief9
    Chief9 New Member
    Greg
    VA
    2023 Tundra Platinum Supersonic Red
    Made a simple Mexican casserole last night. Found the recipe online, but it was delicious. Ground beef, taco seasoning, chili powder, tortillas, refried beans, black beans, corn, cheese and jalapenos. Will do this again!
  20. Oct 9, 2023 at 9:29 AM
    #770
    justcuz
  21. Oct 30, 2023 at 3:56 PM
    #771
    justcuz
    My mom used to make this when she was still alive. IMG_2669.jpg IMG_2672.jpg
  22. Jun 6, 2025 at 7:53 PM
    #772
    Mdnitedrftr
    Mdnitedrftr TAKITEZ
    Rich
    NW, CT
    '21 1794
    Made some pizzas for tonight's dinner. Typically I would do pizzas on my Ooni outside, but we had t-storms threatening so I just did them in the oven.
    Chicken Parm pizza (cheese pizza with chicken cutlet) for tonight, breakfast pizza (4 cheese blend, scrambled eggs, bacon, tater tots, and a dusting of jalapeño seasoning) for the morning. :cool:
  23. Jun 22, 2025 at 5:10 PM
    #773
    Mdnitedrftr
    Mdnitedrftr TAKITEZ
    Rich
    NW, CT
    '21 1794
    More pizzas. Chicken parm, and a BBQ chicken. Slightly overdone, but they were good.
  24. Jun 23, 2025 at 3:09 PM
    #774
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Have 6 lbs of King Crab legs and Caviar coming this Friday!!
    It's the Wife and I's anniversary so we're gonna do it up right!!
    But Holy Shit those things are pricey!!!
    $785 BUCKS!!!!!!
    But there's nothing better than pulling out a hunk of Crab meat damn near the size of your forearm!!!!!
    TaquitoBandito and JMB like this.
  25. Jun 23, 2025 at 3:17 PM
    #775
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Oh...35th Anniversary.
    TaquitoBandito, RainMan_PNW and JMB like this.
  26. Jul 27, 2025 at 3:29 PM
    #776
    Mdnitedrftr
    Mdnitedrftr TAKITEZ
    Rich
    NW, CT
    '21 1794
    Made some slightly healthier and higher protein cinnamon rolls complete with Cinnabon flavored protein. They're a little dense, but the flavor is good. I'm not a baker, so don't judge me. :D
  27. Jul 28, 2025 at 11:19 AM
    #777
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Fresh channel cat and okra for lunch.
  28. Aug 2, 2025 at 5:51 PM
    #778
    Mdnitedrftr
    Mdnitedrftr TAKITEZ
    Rich
    NW, CT
    '21 1794
    I have no idea why, but for the life of me it's like I forgot how to use my Ooni pizza oven. Everything came out burned and yet raw and under cooked.
    I swear I USED to know how to use it, but the past couple times everything has come out fubar'd. So frustrating. :frusty:
    Ended up tossing 2 pizzas and cooking the rest in the kitchen oven to salvage dinner.
