Cv axle boots
Discussion in '1st Gen Tundras (2000-2006)' started by Hi06silver, Sep 11, 2023.
  1. Nov 12, 2023 at 6:34 AM
    #61
    Richid
    Richid New Member
    The fingers on that device would have to be as long as the axle to avoid removal. It only takes about 15-20 minutes to get the axles out (I didn't remove the spindles, I just tied them out of the way). This could save the hassle of disassembling the joint to just replace the boots. My guess is that for the use, it probably wouldn't be worth it although @Hi06silver would have a better answer. I swapped the entire axle instead of replacing the boots.
    I would suggest that if someone buys one, maybe offer to share it on a specific thread, like the bearing tool.
  2. Nov 12, 2023 at 9:07 AM
    #62
    Hi06silver
    Hi06silver [OP] Fat. Thumbs.
    2006 DC 4x4 Waltrip
    I don't think I have a better answer....I suppose it depends the price of that thing. I don't see it being worth it unless it helps avoid the mess of the whole thing, which it cannot. I also bet that the OEM boots ain't gonna stretch like that, one feels more hard plastic like than the other and I ain't about to go non OEM if I I can avoid it or absolutely have a reason to.
    Only real way to avoid mess is while new axle, the only real hard part of the whole thing is popping axles out and then finding the fucking clip which requires cleaning grease out well enough to get snap ring pliers to not slip of it but you're at super mess level at that point so I'd say it's not crazy practical. Maybe I'm thinking wrong?
    Richid[QUOTED] and shifty` like this.
  3. Nov 14, 2023 at 7:44 AM
    #63
    Richid
    Richid New Member
    Ya - me neither. My original axles (boots) lasted 22 years - I expect that the truck will be gone before it needs another set. I kept the old ones, but after reading about your experience changing the boots, they'll just stay in the boxes with the torn boots.
    I think you may be right - if the tool can stretch the boot that far, the boot is probably not sturdy enough to last long.
  4. Nov 18, 2023 at 11:34 AM
    #64
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    Just a heads up to anyone looking at an axle debacle in the future... I got OEM remans and the new OEM boots tore within weeks. I was so pissed. So I ended up rebooting the OEM remans (surprisingly easy and not too messy if prepared in advance) with the Porsche non-neoprene boots recommended by Kartek, and they've been awesome. Here's my post on the matter with pics and some basic tips I learned along the way: https://www.tundras.com/threads/200...pic-heavy-little-ot.75017/page-7#post-3057086
  5. Jul 2, 2024 at 11:13 PM
    #65
    1stGen907
    1stGen907 New Member
    907
    2005 RC LB 4.7 4WD
    Like user 912, I had a boot crack on a recent Toyota remanufactured shaft, on my 2005 RC. The shaft was replaced May 2023, and during an oil change recently I noticed the driver side outer boot was cracked all the way around. The grease was still fairly clean inside, and I live on a dirt road, so I guess I got lucky and caught it early before major damage was done.
    My local dealer told me they could not get a new shaft or a reman - they are discontinued. So I purchased a Toyota boot kit (04438-0C020). My local dealer wanted MSRP plus 30%, plus a week for delivery, I ordered it online for MSRP minus 20% and it showed up four days later.
    This was actually the easiest CV axle I've ever replaced - just unbolt the LBJ and the axle comes right out. But that's when the ugly part of the job started. Notice the 3-piece boot. I wonder if Toyota got a bad batch of boots.
    Cleaning all the old grease out of the outer joint wasn't too bad; I used a paintbrush and mineral spirits in a paint tray to get 95% of it out, lots of flushes (turkey baster!) and working the joint around, then a few sprays of carb cleaner and some compressed air and it was nice and clean.
    The messy part was removing the inner boot and pulling off the inner joint. It took a few tries to get that circlip spread; when you can't see what you're doing because of all the grease it adds a little frustration. But eventually I got it apart and slapped a new outer boot on. I decided to reuse the old inner boot as it was still fine and the joint was well-greased. The rebuild kit included a mix of clamps inclucing one low-profile Oetiker clamp. I don't have the special pliers for those but managed to improvise. It didn't seem very tight - I'll keep an eye on it and replace it if needed. Also, the kit included small clamps of 33.7 and 38.1 mm. It turned out I needed two of the smaller size, so I ended up reusing one of the old clamps. I had removed it carefully, so I think it'll work, but I'll need to keep an eye on it for sure.
  6. Jul 3, 2024 at 12:30 AM
    #66
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Did you replace the snap ring part #4342504020 that holds the axle in the diff (a replaceable part when removing / installing).
  7. Jul 3, 2024 at 8:11 AM
    #67
    1stGen907
    907
    2005 RC LB 4.7 4WD
    No, I reused the old one. I know the FSM says to replace it, but I forgot to order it. I knew the axle was only a year old, it popped out cleanly with little fuss, and the snapring looked undamaged on close inspection. So I feel pretty good about it, fingers crossed.
  8. Jul 3, 2024 at 8:30 AM
    #68
    bfunke
    bfunke Tundra Curmudgeon
    You'll be fine.
    des2mtn likes this.
  9. Apr 27, 2025 at 7:47 AM
    #69
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    Any ideas what a fair cost for boot replacement should run at the dealership? I don't have the tools nor the patience and this truck is my daily so can't really afford for it to be down longer than a couple days.
  10. Apr 27, 2025 at 7:53 AM
    #70
    Hi06silver
    2006 DC 4x4 Waltrip
    I'd bet you're in for at least 2-3 hours of labor. I could be wrong but having to remove and install I bet the book time is close to that. Someone in here is likely a tech and could look it up for sure.
    Tundra2Yak[QUOTED] likes this.
  11. Apr 27, 2025 at 7:54 AM
    #71
    You don’t need to be down for a couple days. Pull the axles, plug the holes on the diff, and you can hand off the axles.
    I’ll be shocked if they’ll do it at the stealership though :rofl:
  12. Apr 27, 2025 at 8:01 AM
    #72
    Tundra2Yak
    2016 1794 4x4 CM
    Yeah, one dealership stated the labor for reboot was the same as axle replacement and said that was the way to go...at $1200.
    The more I read about it, the more it seems the OEM axles should be retained and just rebooted.
  13. Apr 27, 2025 at 8:07 AM
    #73
    Yeah. I’d buy two new OEM axles and drop the coin. They’re around $350-400/ea if I recall? Then reboot the old ones later, and have them as time permits.
    Hi06silver[OP] likes this.
  14. Apr 28, 2025 at 9:59 AM
    #74
    Tundra2Yak
    2016 1794 4x4 CM
    My truck has a 6 inch lift with diff drop. I'm assuming that means high angle boots aren't required. Is that a correct assumption?
  15. Apr 28, 2025 at 10:22 AM
    #75
    This is the 1st gen subforum, we don't usually deal with anything newer than a 2006 Tundra or 2007 Sequoia. If you're talking about a 2016, I dunno. I recommend checking in at the 2.5 gen subforum.
  16. Apr 28, 2025 at 11:06 AM
    #76
    Tundra2Yak
    2016 1794 4x4 CM
    Oops, you're right. My apologies.
  17. Jul 3, 2025 at 9:52 AM
    #77
    Hi06silver
    2006 DC 4x4 Waltrip
    Eh, OEM reman didn't hold up well. Not sure if I accidentally damaged it when installing the 2nd time after joining the mangler club doing the ECGS bushing or what....
    The original reboot (passenger side) from this thread is doing just fine. I tried a quick fix cleaning the boot and putting some 3m thick rubber tape and it didn't hold. Tiny ass hole. Guess I'm gonna try the rtv fix from another thread and reboot with Porsche boots or ORS boots. Hopefully I can find a temp.fix that will last so I can just do lbjs at the same time when they are due.
    Jack McCarthy likes this.
  18. Jul 3, 2025 at 10:22 AM
    #78
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    That's a bummer.
    I've used... Shoe goo... No joke! On an OEM boot that got scuffed and screwed up either by me or during shipping.
    Clean it, scuff it a lil, apply, and let dry. Works best in a spot that doesn't flex as much obviously.
  19. Jul 3, 2025 at 10:40 AM
    #79
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Hard to tell but it looks like the inner boot that got damaged. That seems like an odd place for a hole to show up. I think that may just be bad luck from ECGS bushing.
  20. Jul 3, 2025 at 8:24 PM
    #80
    ToyotaDude
    ToyotaDude Member
    Seems like a lot of space between the baffles. 4wheel much? Maybe it got poked with a stick.
  21. Jul 4, 2025 at 12:57 PM
    #81
    Hi06silver
    2006 DC 4x4 Waltrip
    It's likely just the angle and being zoomed in. I don't 4-wheel much at all. I tried the show glue because a bike patch failed likely due to the prep and not being able to put enough pressure on it. I need to go check the SG now that I think about it.
  22. Jul 4, 2025 at 6:30 PM
    #82
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    I went with ORS in 2016, if memory serves me correctly, no issues. My Tundra is mostly an asphalt warrior, YMMV.
  23. Jul 10, 2025 at 9:03 AM
    #83
    TnPlowboy
    TnPlowboy New Member
    2004 Tundra SR5 AC 4.7L 4WD, Tow Package: Blue Marlin Pearl
    I have recently developed a crack in one of my boots. Is this a job, so unpleasant that people are going ahead and rebooting both axles. Or alternately, so messy that folks are fixing only the axle that requires repair?
    Just wondering what folks were doing and other experiences were.
  24. Jul 10, 2025 at 9:40 AM
    #84
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I would inspect both first. If one is cracked and the other is fine I would just address the cracked one. However, chances are that both are in similar condition unless you've already replaced one. If you have the time and you're going to do one, then I would just do the other while you're making a mess. They aren't too messy if you have a bucket or two handy for the old grease, a roll of paper towels, and some gloves.
  25. Jul 26, 2025 at 8:50 AM
    #85
    Hi06silver
    2006 DC 4x4 Waltrip
    How are these inner porsche boots holding up? I'm about to order them as the OEM reman boot (inner) on my drivers side got dinged during ECGS bushing debacle and after reading a comment below with the 3 piece boot I'd rather try the porsche mod.
  26. Jul 26, 2025 at 12:53 PM
    #86
    ToyotaDude
    ToyotaDude Member
    On OE reman axles had immediately stretched the inner reman boots about 5/8" with smooth-walled rolled-edge clamps (just past the factory axle clamp-indent location), hoping to get some miles out of them before a 930 swap that is inevitably planned. But they are tiny boots so can't stretch far like Tacoma boots and the famous BSM, and still rub. However, it likely relieves some pressure and holding up using silicone spray on the baffles after about two years and 1,400 miles.
    Have seen some extend outer boots with the inners too on Tacos, though most feel its unnecessary with stock or OE replacement boots (not remans). Stretching the outers seems wise if rubbing there too with reman boots. Had contemplated doing that too. How far did you have to stretch inward on the outers, maybe only about 1" so you could clamp just past the indent, or could you go further? And that has been working fine?
    TIA.
  27. Jul 29, 2025 at 8:24 AM
    #87
    912
    2005 DC 4x4
    the boots are holding up great. No complaints.
    yeah, I probably extended them an inch or so. best to study the pics i posted in my thread to be sure, since it was quite awhile ago and my memory is a bit foggy around it.
  28. Aug 1, 2025 at 6:21 PM
    #88
    Hi06silver
    2006 DC 4x4 Waltrip
    Got the Porsche boots, install tomorrow. It seems the Porsche boots clamp area is what may keep them from splitting? They would clamp further back towards the diff and allow the boot to flex where it typically seems to tear when it's the factory boot...just a hypothesis of course. There isn't much more boot left after the Porsche boot fits where it should compared to OEM really. I hope this is a good solution.
    I've searched, and haven't found a definite answer to the grease type or I got corn-fused? For this go round I'm using the 2 packets that came with the Toyota reboot kit. Anyone have specs on what that grease actually is?
  29. Aug 1, 2025 at 7:15 PM
    #89
    ToyotaDude
    ToyotaDude Member
    There is an inner an outer grease with the toy kit. What apparently keeps the boots from splitting is installing the much larger boot and clamping the part on the shaft more outward outside the usual notch so the baffles don't rub when it is in use. The rubbing causes wear. Check out the video.
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-1916#post-3451375
  30. Aug 2, 2025 at 4:07 PM
    #90
    Hi06silver
    2006 DC 4x4 Waltrip
    Got 1 Porsche boot on... haven't driven it yet so we'll see if the CV axle falls out on the way to the store again lol.
    I didn't clean and pack with all new grease just added some as the fuckin' CV is basically new and there couldn't have been that much lost.
    I couldn't get the outer boot to stay past the indentation unfortunately. Luckily that hasn't been a problem so not too worried. The Porsche boot is a touch bigger than the part that it clamps too so hopefully the rolled edge clamp does it's job. The only real issue I had was that damned suction thing and the ribs getting all dented at points but I got it figured out.
    DarkMint, 912, abcinv and 2 others like this.
