Ironman 4x4 Suspension
Discussion in 'Suspension' started by linwozzle, Apr 1, 2020.
  1. Feb 12, 2025 at 7:10 AM
    #1111
    Savagesawyer
    Savagesawyer New Member
    Beaverton, OR
    Odd. I’ve used them on two trucks with no issues.
  2. Feb 12, 2025 at 7:49 AM
    #1112
    beard_power
    beard_power New Member
    2019 TRD CrewMax
    Thanks for your insight. What makes you say that the coils I received are the older style?
    Did you get the rear springs too?
    Now that your issues are resolved how does the suspension ride?
    Another issue I forgot to mention is the pitting of surface of the springs; The spring surface is not smooth.
    Is this normal? Or an indication of manufacturing defects?
    Trying to decide if I should just return everything and buy something else.
  3. Feb 12, 2025 at 7:58 AM
    #1113
    Jla14
    Jla14 New Member
    2014 White 1794
    I got the stage 2 kit with front, rear, leaf springs and UCA. The kit rides fine but I wouldn't say it was worth the hassle of getting the issue resolved. I've used the 6112s and 5160s, toytec aluma boss and now the ironmans.
    I read on some forums the green springs were an older model that were prone to the rubbing and bowing. Take that with a grain of salt because I fell down several forum holes because I had months until they got the bowing and rubbing issue resolved. If I could do it again I'd go back with the Bilstein or Toytecs.
    Also I can't go full lock without the coilover making contact with the tie rods, I never had this issue with any other set up I was running.
    equin likes this.
  4. Aug 2, 2025 at 10:53 AM
    #1114
    dhsmith06
    dhsmith06 New Member
    Tundra 2012
    Finally got my 3.5' Foam Cells in today after a long wait.
    2012 Tundra 5.7 4wd.
    Time to replace the 3.5 RC struts.
    2.5" OME rear springs.
  5. Aug 15, 2025 at 7:03 PM
    #1115
    dhsmith06
    Tundra 2012
    Finally got my foam cell pro 3.5" installed. What a difference from the 3.5 RC bolt on struts. They absorb the road bumps so much better. It doesn't feel or sound like my truck is about to fall apart. Nice and solid!
    Legend33 and slcsez2000 like this.
