  1. Jul 29, 2025 at 5:05 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Nice looking truck! How are the brakes?
    Tripleconpanna and HulkSmurf14 like this.
  2. Jul 29, 2025 at 5:50 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Nice truck.:thumbsup: Nicer if it was black. :cool::D
    Tripleconpanna likes this.
  3. Jul 29, 2025 at 5:51 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Did you do the rears, too?
    reywcms likes this.
  4. Jul 29, 2025 at 6:55 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    I’ve only got 27 miles on them so far, but already a huge improvement over stock!
    23Tundy and woods[QUOTED] like this.
  5. Jul 29, 2025 at 6:56 AM
    Js18tundra
    Not yet, those still have plenty of life left, I’ll change those toward the end of the year.
    HulkSmurf14[QUOTED] likes this.
  6. Jul 29, 2025 at 6:57 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    What bundle deal are you guys referring to?
  7. Jul 29, 2025 at 7:04 AM
    seydou
    seydou Distinguished Member
    This makes zero sense to me. The stock plate is virtually worthless and you can still incur damage while city driving considering all the debris on the road. And more important to me would be the oil filter access door on the TRD plate. Can't imagine having to change the oil regularly without it. TEHO
    23Tundy likes this.
  8. Jul 29, 2025 at 7:09 AM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
  9. Jul 29, 2025 at 7:16 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Interesting you have 3 recalls for your 19. My 18 had only one recall, for dim parking lights that required repositioning in of the connector. Some here posted the fix so I did it myself. My truck has been trouble free so far, but I don’t put many miles on it, @41K miles now. I bought one of the adapters that can do the 12v pllug in with voltage, and 4 USB. Two which are the new USB - C .. I noticed it read 11.1 v. Truck still starts but it may be time to replace the original battery.
  10. Jul 29, 2025 at 8:26 AM
    MGM16
    MGM16 New Member
    Central Wisconsin
    2016 MGM Tundra DC
    OEM LED headlights, Lasfit switchback fog light bulbs, Color matched hood bulge, TRD grille, SCS wheels, Bilstein 5100's, SCS Ray10
    Gave the ol gal a bath along with a quick ceramic spray, and installed some Lasfit switchback bulbs into the fogs.20250726_145052.jpg 20250726_145120.jpg 20250728_170203.jpg 20250728_170211.jpg
  11. Jul 29, 2025 at 8:48 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    BR73 likes this.
  12. Jul 29, 2025 at 8:53 AM
    Edemoya160
    Edemoya160 New Member
    Enrique
    2017 Tundra 1794 edition
    What are those ditch lights?
  13. Jul 29, 2025 at 1:32 PM
    trevorklat
    trevorklat Don't Mess with Texas!
    The Lone Star State
    2018 Super White Platinum Tundra 4WD CM
    Linex bed liner, Retrax roll-top bedcover, Ranch Hand Summit brush guard, SDHC ABS sensor guards, Interior LEDs, Cargo lamp LEDs, Reverse Light LEDs, Rear TRD sway bar, Valhalla's Shield Cat plates, Husky floormats
    Does it stay powered-on when the ignition is off? Does the display continue to draw power when the truck is off? Does it get hot with prolonged charging?
  14. Jul 29, 2025 at 1:45 PM
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
  15. Jul 29, 2025 at 1:55 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    nice.. I kind of thought the beach there looked like NC! :D I was just at Topsoil during 4th of July weekend.
  16. Jul 29, 2025 at 2:18 PM
    I was wondering the same thing.
    Tripleconpanna and BR73 like this.
  17. Jul 29, 2025 at 2:20 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Randydw and bulldog93 like this.
  18. Jul 29, 2025 at 2:32 PM
    blenton
    blenton New Member
    The stock plate is easy to deal with. My CBI skid requires me to remove 8 bolts to open the filter access panel and the drain plug (4 on each panel). The stock plate is also 8 bolts if memory serves, and very easy to manipulate out of the way. But with the stock plate removed I have access to the entire underside of the vehicle rather than working at a filter housing through an opening barely big enough to fit both my hand and the filter housing through. So it’s easier and less mess to change the oil with the stock plate. Even my RCI skids make it more difficult, and I have access to the fumoto valve without removing a second access plate.
    As for robustness, the stock plate is much more robust than people give it credit. Mine has absorbed 2x4 strikes on the freeway, bird strikes on the highway (it was like playing pretendo duck hunt but with a full size truck…), slow speed rock strikes, a few gravel road beachings, and a plethora of other abuses most folks don’t see. An aftermarket plate is definitely better, and I run them on all three rigs if for no other reason than the transmission plate, but you still can’t use any of them as a lift point for jacking up the vehicle. The dent in my steel CBI shows that. For what 98% of people do with their trucks, I’d surmise that the stock plate is sufficient - and easier to deal with.
  19. Jul 29, 2025 at 2:41 PM
    2014 Black tundra
    2014 tundra sr5
    I would love to go to a beach to drive on.
    OHwendTrd and JerryH[QUOTED] like this.
  20. Jul 29, 2025 at 2:47 PM
    2014 Black tundra
    2014 tundra sr5
    I have the metal RCI skids. I used my floor jack to jack up the front to bring both tires off the ground. It only put some scratches on the skid plate. I had no problems.
    BR73 likes this.
  21. Jul 29, 2025 at 3:08 PM
    JerryH
    SOMD
    I grew up going to Topsail. Love it there also!!!
    phabej[QUOTED] likes this.
  22. Jul 29, 2025 at 4:39 PM
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    Finally getting around to install some mods I have had laying around for awhile. Installed heated steering wheel, hooked up the MagSafe charger to replace the Scosche (RainMan) Moved my back window switch along with install single NSV switch in Black Cat Works custom switch panel. Still need to fill one spot of get a blank cover. Throwing in a photo of the Tundra with my daughters FJ.
  23. Jul 29, 2025 at 5:44 PM
    Boneskull420
    Boneskull420 God loving,Tundra driving,rednek custom joker!
    Mark
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Got my OTT tune done by Appalachian Toyota Tuning today. Went medium/spicy. So far I like it. Maybe if I get back in his area I will see if I can replace the spicy for super spicy but overall I am happy with everything so far!20250729_203947.jpg 20250729_203455.jpg
  24. Jul 29, 2025 at 6:06 PM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    Went to the Toyota dealership to have a 2nd key made and install the front skid. It was part of the sale. Three hours at dealer and hour drive each way. Ohh well
    : [​IMG]
  25. Jul 29, 2025 at 6:12 PM
    WAtundra4x4
    Den
    Wet side WA
    It goes off with the ignition off. It turns on with the accessory being on. I have not done prolonged charging yet with it, but I would think it will be hot. Nice to have a USB-C socket as the 2018 did not have one.
  26. Jul 29, 2025 at 6:23 PM
    Tboh1870
    Tboh1870 New Member
    Herman
    Just starting reno
    Damn what ramp ...
    1 month away can't wait
  27. Jul 29, 2025 at 8:49 PM
    vmkeith
    vmkeith Slow is smooth, smooth is fast
    Vince
    Clark County, Wa
    2014 Super White Tundra SR5 CrewMax 4x4
    Rhino Lining bedliner LT275/70R18 Cooper Discoverer ATP II TRD Pro dual exhaust with TRD exhaust tips Lund 5" Cab Length Oval Curved Tube Steps RealTruck TruXedo Pro X15 Tonneau Cover RealTruck Elevate FS Bed Rack Rhino-Rack Carriers Diode Dynamics SS3 LED Fog Light Kit Auxito LED Headlight Bulbs Rydonair 7" antenna
  28. Jul 29, 2025 at 8:53 PM
    InfernoBoyz
    InfernoBoyz YoutubeTech
    Reno, NV
    2016 Inferno Tundra Double Cab OR
    started on the new rear deck platform. working on the back then getting carpeted.
  29. Jul 30, 2025 at 4:42 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    What are you going to use the platform for?
    BR73 likes this.
  30. Jul 30, 2025 at 5:55 AM
    JerryH
    SOMD
    Ramp 49
