  1. Jul 28, 2025 at 3:46 AM
    It takes longer for me to find one posted here than it does via Google.
  2. Jul 28, 2025 at 8:44 AM
    That'd be a big fucking mistake. Dude. No.
    One of the members on here, maybe @Redoak either had or one of his friends had their Gates timing belt snap after 40k-50k miles.
    Dude. Buy Aisin. Get the kit that ends with -021 in the part number. Even if you only use the belt, but while you're in there, you may as well replace the pulleys and stuff, and I mean ... water pump. It's all in the kit.
    BroHon, Redoak, FirstGenVol and 2 others like this.
  3. Jul 28, 2025 at 8:52 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Gates HD green serpentine belt is fine, but NOT timing belt.
  4. Jul 28, 2025 at 8:54 AM
    Nimitz_
    Nimitz_ LA face with an Oakland booty
    Sam
    Seattle-ish
    06 DC LTD 4X4 4.7 V8
    Found the cause of my intermittent overheating issue. Turns out the guy that did my TB left it a full gallon short of coolant. I was adding it one resi bottle at a time because it would all disappear when it got cold and realized I just needed to fill the radiator. Burped it and now it's sitting at halfway. Gonna drive it to the office and see if it makes it.
    Also ditched my LED projectors for halogens, the LEDs simply didn't turn on and I didn't want to eff around with figuring out why. Now after a month of ownership, I have highs, lows and the fogs even work. Like a real boy!
    Finally got the receiver that was rusted in place off because it in turn had a hitch rusted inside it that looked like it hadn't moved in about 15 years. Gonna wire wheel and paint the one from the donor and finally have an empty hitch. Also scored a tow harness from the donor and got that plugged in too.
    BroHon, KNABORES and shifty` like this.
  5. Jul 28, 2025 at 9:00 AM
    Yup, I'm using HD green serp too.
    @Upshot Knothole Mitsuboshi (not Mitsubishi) is OEM for the timing belt, and that's what's included in the Aisin kit, along with the tensioner, pulleys, Aisin (same as OEM) water pump, etc.
  6. Jul 28, 2025 at 9:09 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Did you go with 100w halogen and upgraded harness or back to regular halogen? You installed led projectors in the halogen housings but they wouldn't turn on?
  7. Jul 28, 2025 at 9:18 AM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    I'm talking about the serpentine belt. I already said I have the AISIN TB kit sitting in a box.
  8. Jul 28, 2025 at 9:23 AM
    Upshot Knothole
    Thatchery
    PDX OR
    Yeah, I'm asking about all the other stuff to replace while having the AISIN kit installed.
    Thermostat, fan bracket, serpentine belt, pulleys, tensioner, radiator, hoses, etc. The only Gates kit I was referring to was this one.
    https://www.rockauto.com/en/moreinfo.php?pk=9118632
    shifty`[QUOTED] likes this.
  9. Jul 28, 2025 at 9:29 AM
    Nimitz_
    Sam
    Seattle-ish
    Just went with regular halogens. I hooked up the leds right when I got them and they worked, but after doing all the work to mod the housings they never turned on again after I installed them.
  10. Jul 28, 2025 at 9:47 AM
    ToyotaDude
    ToyotaDude Member
    Hmm. Sounds like they failed. Hearing about the lack of longevity with the projectors in other threads so preinvesting in matching spares for future swaps has been disuading this mod. But having new housings with clear lenses again even with regular halogesns has been a great "upgrade" from the fogged housings and repeated sanding. May do it one more time on the OEs removed ... and clear them proper as spares.
  11. Jul 28, 2025 at 9:56 AM
    Upshot Knothole
    Thatchery
    PDX OR
    eBay battery retainer arrived and installed.
    And these Hella horns will always make me smile and think of Subarus. I do need to see if I can make them more symmetrical at some point since they’re totally visible through the grill.
  12. Jul 28, 2025 at 10:22 AM
    Nimitz_
    Sam
    Seattle-ish
    I’d be surprised if both failed simultaneously, I’m more inclined to think there was a voltage issue that was confusing the truck.
  13. Jul 28, 2025 at 11:16 AM
    ToyotaDude
    ToyotaDude Member
    Was the resistor used?
  14. Jul 28, 2025 at 11:18 AM
    Nimitz_
    Sam
    Seattle-ish
    Didn’t have one, just ballasts or whatever it needed inline between the facroy harness and the projectors
  15. Jul 28, 2025 at 12:15 PM
    Nimitz_
    Sam
    Seattle-ish
    Not having fun anymore. Trying to limp this thing home while it over heats every 1/4 mile
    jerryallday likes this.
  16. Jul 28, 2025 at 12:17 PM
    oscardog86
    oscardog86 New Member
    Southern California
    Sorry youre having so much trouble with your FGT right now. That really sucks dude!
    Nimitz_ likes this.
  17. Jul 28, 2025 at 12:21 PM
    Nimitz_
    Sam
    Seattle-ish
    Can’t seem to get enough coolant into it. Don’t think I have a leak, just think it has a bunch of air in it still.
  18. Jul 28, 2025 at 12:41 PM
    Looks like the radiator cap has been squirtin'. You know how to get 'em hot, and make 'em squirt, my friend.
    Seriously though, run the truck with heat on full blast. I was gonna ask if you're sure it's overheating, but based on the top of the radiator, I'm thinking it may really be.
    Have you squeezed all the tubes to see if any aren't firm when running?
    455h0le_dachshund and Filthyphil like this.
  19. Jul 28, 2025 at 1:14 PM
    Nimitz_
    Sam
    Seattle-ish
    Just poured a half gal of coolant into it after ubering to O’reiley and it just ran out of the bottom of the plastic on top so the rad has bit the dust. I guess I need to order a denso but I’ve been pouring money into this thing and still can’t drive it. Might need to take a break.
  20. Jul 28, 2025 at 1:53 PM
    ToyotaDude
    ToyotaDude Member
    Sorry to hear. But good news is if it's leaking that much then it's likely diagnosed and repair is contained to about $200 for rad and coolant with a fairly straight forward swap.
  21. Jul 28, 2025 at 2:08 PM
    Sucks man. Them battery terminals lookin seksy tho
  22. Jul 28, 2025 at 2:11 PM
    Nimitz_
    Sam
    Seattle-ish
    If I basically overheated this thing to steaming 4 times in 2 hours what do I need to look for to make sure I didn't trash the engine? As soon as it hit the red, I pulled over and turned it off.
  23. Jul 28, 2025 at 2:24 PM
    Upshot Knothole
    Thatchery
    PDX OR
    Coolant in oil or transmission fluid, or oil in coolant would be the first things I'd check. Make sure you didn't blow a head gasket or break the transmission cooler than runs through the radiator.
  24. Jul 28, 2025 at 2:37 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I’m sure it’s fine, make sure the front end of your truck is facing uphill to the rear so that your radiator cap is the highest point in your cooling system, crank the heat on full blast start your truck and add coolant until thermostat opens and no bubbles are coming out. Squeeze hoses like stated as well.
  25. Jul 28, 2025 at 7:03 PM
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    @Nimitz_
    With the Fill/Funnel kit this was how I burped it to get better heat, took longer than you might think. Make the rad cap the highest point (truck on angle on the hill), heat temp dial on high. Squeezing hoses and revving the engine a bit to burp air out. About 30-45 minutes.
    Voss, RealTruck, G_unit3000 and 7 others like this.
  26. Jul 28, 2025 at 7:37 PM
    Nimitz_
    Sam
    Seattle-ish
    Thanks brochacho. I did mine on ramps on my inclined driveway but didn’t run the heat. Just ordered a rad so I’ll get another chance to practice.
    KNABORES and BroHon[QUOTED] like this.
  27. Jul 28, 2025 at 8:06 PM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    Of the things these trucks need done this one of the easier ones. Not good to have that leak/failure, but better than the trans fluid milkshake that you can't see....
    If your HVAC heat control knob is hard to turn (like mine was) sometimes the cable wont open the valve all the way. Here is what fully open, and closed looks like on the valve on the firewall. You can move it by hand if it's not opening up fully.
    Shout out to @whodatschrome for those HVAC parts! :fistbump:
    OPEN
    CLOSED
    Pretty self explanatory, but making sure that valve is fully open makes a big difference.
    Good luck with the radiator coming undamaged!
  28. Jul 28, 2025 at 8:24 PM
    Nimitz_
    Sam
    Seattle-ish
    Is it worth trying to save the coolant? It’s probably got 100 miles on it and is like a month old.
    ToyotaDude and BroHon[QUOTED] like this.
  29. Jul 28, 2025 at 8:28 PM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    Full polish and Ceramic coat today, including the entire SnugTop. 91 and humid outside today (hard on a snow monkey). It was so nice to have a 75deg space, with tunes blasting to work in.:thumbsup:
    Not sure why I bought that polisher, it's a piece. Any recommendations on a good variable speed rotary that's mid price range?
  30. Jul 28, 2025 at 8:31 PM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    I would, but I'm cheap AF. I don't see why not. I'd probably strain it on the way back in maybe...
    G_unit3000, ToyotaDude and KNABORES like this.
