Coastal offroad diy weld bumper review/ write up
Discussion in '2.5 Gen Tundras (2014-2021)' started by Wahayes, May 22, 2022.
  1. May 30, 2022 at 8:51 PM
    #61
    Wahayes
    Wahayes [OP] Older I get the wiser I realize my dad was
    Will
    2017 tundra limited *sold*
    Does your engo have a removable winch control box?
  2. May 30, 2022 at 9:20 PM
    #62
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Yeah it does, hoping that buys me enough clearance.
  3. Jun 1, 2022 at 2:48 PM
    #63
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    What brand are the lights? Beam pattern? Are they decent lights or cheap chinese ones like you'd get on Amazon? Coastal doesn't have much info about them on their site other than the wattage.
  4. Jun 1, 2022 at 4:46 PM
    #64
    Wahayes
    Will
    They are cree leds, the lights themselves don't have any logo markings, but they seem to be solid quality construction, all metal housings and the seals look good. Haven't hooked them up yet to confirm pattern. I'd say probably higher end Amazon type stuff based on my previous Amazon light ventures.
    helidave likes this.
  5. Jun 6, 2022 at 5:37 PM
    #65
    helidave
    flagstaff
    2015 DC 4x4
    My bumper kit is on the way... Curious what you did with the plastic inner fender on the back side of the bumper? Haven't seen any pics of that.
  6. Jun 6, 2022 at 5:43 PM
    #66
    Wahayes
    Will
    Removed it. It basically comes off woth the oem bumper
  7. Jun 6, 2022 at 5:43 PM
    #67
    Wahayes
    Will
    Mine was already hacked all to hell to fit my tires lol
  8. Jun 6, 2022 at 5:51 PM
    #68
    Wahayes
    Will
    By the way lights are bright , and are a driving/spot pattern.
    helidave[QUOTED] likes this.
  9. Jun 6, 2022 at 5:54 PM
    #69
    helidave
    flagstaff
    2015 DC 4x4
    Thanks for all the info :thumbsup:
    Wahayes[OP] likes this.
  10. Jun 6, 2022 at 6:11 PM
    #70
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
  11. Dec 4, 2023 at 10:20 AM
    #71
    Oochi20
    Oochi20 New Member
    2008 Salsa SR5
    OME 2.5" Lift SSW Stryker Wheels 35" Nitro Ridge Grappler Tires
    Sorry to revive this old thread but I just got a Coastal bumper and was looking through thread to see what I got myself into. Great write up! I also got hung up on the power steering relocation. In your picture it seems that you may have the brackets on upside down as it should push the cooler up much higher than shown. They may have changed the instructions since you got yours.
    But regardless, I have the factory trans cooler which was in the way of the lines for the power steering relocation. For others running into this, I used their supplied brackets then made my own brackets to fit an aftermarket cooler.
  12. Dec 26, 2023 at 11:52 AM
    #72
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    Which amber pod lights do you have?
  13. Dec 26, 2023 at 11:53 AM
    #73
    Rakso
    Oskar
    What happened with the lights connector issue?
  14. Dec 28, 2023 at 5:05 AM
    #74
    300BLK
    300BLK New Member
    Bumper pod lights are Diode Dynamic SS3's. Ditch lights are Baja Designs XL Pro's.
    Rakso[QUOTED] likes this.
  15. Dec 29, 2023 at 1:34 PM
    #75
    kevine0001
    kevine0001 New Member
    Kevin
    Just curious. If you do not end up installing a winch, are there any parts that have to be relocated? I'm considering either a kit like this, or fabbing one from scratch. I want the winch plate but it may be a while (if ever) that I actually install one. Never needed one and I don't do any crazy off roading, mainly fire roads for hunting, and 99% of the time with a partner in his truck. And I'd prefer not to have to relocate/re-mount parts etc. if possible.
    On the bull bar issue, I'm assuming this kit can be mounted so it sticks out a little further for a bull bar?
  16. Dec 29, 2023 at 2:55 PM
    #76
    Rakso
    Oskar
    I'd call or email them with those questions.
    15% off is hard to pass.
  17. Jan 10, 2024 at 11:42 AM
    #77
    Rakso
    Oskar
    Awaiting shipment.
  18. Jan 15, 2024 at 7:36 PM
    #78
    Rakso
    Oskar
    Arrived today. Pics coming up
    TOYOTARIG likes this.
  19. May 15, 2024 at 10:05 AM
    #79
    Rakso
    Oskar
    What primer and paint did you use?
  20. Mar 16, 2025 at 4:32 PM
    #80
    Billan1
    Billan1 New Member
    2010 tundra
    Coastal bumper, icon suspension, custom rear bumper, leather interior
    Hi guys, I just got a coastal for my truck and had a fabricator install for me. Now I am realizing I want to install a light bar. Is it possible to do it without removing the bumper?
  21. Mar 17, 2025 at 9:52 PM
    #81
    Rakso
    Oskar
    No
  22. Mar 17, 2025 at 9:54 PM
    #82
    helidave
    flagstaff
    2015 DC 4x4
    maybe if you take the grill off. try it and report back
  23. Mar 18, 2025 at 6:49 PM
    #83
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Do you have pics on where you mounted your winch controller? Is that the smittybilt 12k?
  24. Apr 2, 2025 at 7:35 AM
    #84
    CS_AR
    CS_AR New Member
    Craig
    2000 Tundra TRD
    Just starting.
    It looks great. Did you get any documentation for cutting the rear fenders? I'm trying to install the bumper built for a 2000 model AC and am looking for help with measurements to cut the rear fenders.
  25. Apr 2, 2025 at 8:14 AM
    #85
    No documentation, you basically have to get the base/frame section mounted and eye ball it or use a string line
    CS_AR[QUOTED] likes this.
  26. Apr 22, 2025 at 3:55 PM
    #86
    Billan1
    Billan1 New Member
    2010 tundra
    I was able to get the light bar mounted without removing the bumper. We did have to remove the valence above the bumper and slide it on but turned out well.
  27. Jul 16, 2025 at 12:07 PM
    #87
    KrOswalt
    KrOswalt New Member
    I assume you have to remove it, can’t leave it and move it when you install a winch?
  28. Jul 27, 2025 at 6:15 PM
    #88
    Wahayes
    Will
    Correct . It can’t stay in the same place so you have to either relocate it with a bracket , or do like I did and just replace it with an aftermarket cooler.
  29. Jul 27, 2025 at 6:16 PM
    #89
    Wahayes
    Will
    I don’t , I sold the truck and didn’t
    Take pics of that. I don’t remember the winch brand
  30. Jul 27, 2025 at 6:18 PM
    #90
    Wahayes
    Will
    Rattle can rustoleum self etch, high build , and rustoleum black
