Dashcam Install
Discussion in '3rd Gen Tundras (2022+)' started by jvperez, Dec 17, 2022.
  1. May 17, 2023 at 11:19 PM
    ArticTundra
    ArticTundra New Member
    Cold
    For those of you running the Viofo A139 pro or similar, have you had any issues with your camera recording in super fast forward mode? I had a 20 minute drive home and the whole file took about 40 seconds to play. When I slow it down, it gets all crappy. any ideas?
  2. Jul 1, 2023 at 1:06 PM
    Indy Tundra Guy
    Indy Tundra Guy New Member
    2023 Crewmax 5.5 Blueprint 1794 non-hybrid
    Thank you for this. I plan to do the same thing for my truck. Do you have any additional tips or suggestions before I get started?
  3. Jul 2, 2023 at 11:28 AM
    P1NDLESK1N
    P1NDLESK1N New Member
    2023 Solar Octane Toyota Tundra TRD Pro
    Took a few pics on how I set mine up, hopefully it helps.
    Pull this down and towards you to get access.
    After creating a little harness like I posted earlier, you can plug it into the available plug and tuck it up under the headliner. Towards the mirror is a hole you can push your wires through to plug the dash cam into.
    To connect the rear camera, you can guide the wire out from under the headliner up towards the passenger side of the rear view mirror and out towards a premade hole. I then tucked the wire between the headliner and the A, B, and C pillars towards the rear window.
    For the rear camera I bought this short length bracket and tucked it under the weatherstripping for the rear window.
    Indy Tundra Guy likes this.
  4. Jul 2, 2023 at 11:45 AM
    Indy Tundra Guy
    Thank you so much! This is great!
    P1NDLESK1N[QUOTED] likes this.
  5. Jul 2, 2023 at 12:36 PM
    P1NDLESK1N
    Sounds like it's on time lapse mode? Maybe your hot and switched wires are reversed? Not sure how else it'd record that way.
  6. Oct 7, 2024 at 6:37 PM
    mfa1981
    mfa1981 New Member
    Marcel
    2024 Nightshade Limited
    what's the correct name for that 5 pin female connector? I'm gonna install my camera this week and thinking I will build the connector instead of tapping into the wires for a clean installation but I don't know exactly what is the correct form factor of that connector
  7. Oct 7, 2024 at 7:04 PM
    P1NDLESK1N
    The actual name for the 5 pin plug? No idea.
    I just eyeballed it online and ordered the Subaru harness, didn't want to figure out how to build it.
  8. Jul 27, 2025 at 1:22 PM
    NimbusDog
    NimbusDog New Member
    Tampa, FL
    2022 Tundra
    https://www.aliexpress.us/item/3256806039270154.html
