General Supercharger Thread
  1. Jul 25, 2025 at 5:57 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    This thing is out of sight so I didn't even catch it to test/inspect. Told the tech/mech doing my brakes to check on it when he replaces my PCV.
    Thanks all. I'm fairly certain this is it.
    e30cabrio, Mdl and HulkSmurf14 like this.
  2. Jul 25, 2025 at 5:58 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    The problem is
    one end is one diameter
    the other end is another diameter
    hence the need for a pipe band
  3. Jul 25, 2025 at 6:06 PM
    Saltyhero13
    ahh that explains it lol. WTF Harrop.
    Anyone know the nipple OD and the hose ID?
    I don't know what dimension this is: Re-connect the PCV hose to the Ø10 hose barb under the supercharger inlet cover.
    e30cabrio, HulkSmurf14 and Mdl like this.
  4. Jul 25, 2025 at 6:20 PM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    It’s likely 10mm, or roughly 3/8 hose. I just added an additional small hose clamp and snugged it up. I don’t recall an issue per se, may have been chasing the p0101 when I addressed it but I'm not sure that was the culprit. I just know I was not satisfied with how it fit.
  5. Jul 26, 2025 at 12:16 PM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    Jumping in real quick to share a recent experience:
    I had the full SPD exhaust (single-cat downpipes + cat-back) which I loved, until I started towing a travel trailer/toy hauler. It was just too loud, so I decided go with OEM style.
    Ultimately I went with BRExhaust (MagnaFlow) as it was cheaper than Toyota - even after the 4th of July 20% off at Anderson Toyota - and marketed as "OE direct-fit replacement". It fit beautifully and was whisper quiet in the cab.
    Unfortunately, it was no match for the volume of exhaust due to the supercharger, and it let go at 9psi of boost. I had smashed the gas to pass someone and the canister went BOOM. Ironically, I had just left a forum members house after selling him the SPD cat-back.
    I'm sharing this because I'm aware of a couple of people with supercharged Tundra's considering quieter exhaust. I'm not sure if OEM would have held up better, but it certainly highlights the volume of exhaust gases getting smashed out of the system.
    upload_2025-7-26_13-13-48.heic
  6. Jul 26, 2025 at 12:21 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    :101010:
  7. Jul 26, 2025 at 12:57 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I've wondered about my OEM exhaust with my boost, but it's been on for nearly 100k miles...I max out at the occasional 6.5psi...hmmm, this is good insight...thanks for sharing your wild experience!
  8. Jul 26, 2025 at 1:07 PM
    Saltyhero13
  9. Jul 26, 2025 at 1:12 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    We don't need no can opener!
  10. Jul 26, 2025 at 1:17 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Get rid of the restrictions and let it rip!:rolleyes:
    At certain points my exhaust is loud, someday I'll quiet it down. I'm told I'm sometimes deaf. Selective listening or years exposed to high frequency noise from diesels?:D
  11. Jul 26, 2025 at 1:30 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    A quiet and free flowing exhaust are in my "someday" plans. Considering long tubes, OEM cats, resonators, going to a single 3.5" quiet flow muffler. Either axle or bedside dump.
  12. Jul 26, 2025 at 1:56 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    Current : Magnuson S/C 5.7 FFV, Tundra CM, SNIV tuned w/HP Tuner, SG-1 Wide band AF w/gauge, TRD cat back, slotted and drilled rotors, stainless brake lines, TRD pads front and rear, front OEM Sport sway bar, rear TRD sway bar, 38 gallon OEM fuel tank, Tesla screen, ham radio, 2.5 Icons w/ res front and rear. X2 battery w/Voltage Booster Pro 2014 OEM wheels. 17.2 MPG on road trips https://drive.proton.me/urls/Y8739Z14BG#HCVT8AowG9fl ---------------------------------------------------- Previous: 2002 Tundra AC 2wd... Converted to OEM 4wd , S/C 4.7, TRD exhaust. 35's w/4:88's, too many other mods to list. https://drive.proton.me/urls/SWEWY4AFMC#eC7zX57Ex6pI ---------------------------------------------------- Other: 1967 mustang , Blown 408, 671Mike Kuhl 12.5% overdriven, 300shot NOs 5 speed TKO600, 4:11's Ford 9", Detroit Locker (real) Evans Coolant, Twin 12" Spahl fans https://drive.proton.me/urls/ABBVY3TQ3M#OT9LceyNwbTy ---------------------------------------------------- 2015 4runner TRD drop in filter Prinsu 1/2 roof rack, Nfab side steps, TRD FJ lift kit. ---------------------------------------------------- 2007 Prius 45mpg+ ... It's the only way to afford fuel for these Beasts!
    It's funny you say that today> I noticed that my TRD cat back sounds different since I installed the SC. Normally it's to hot to drive with the windows down, but it was 77 this morning and really nice at 5am on my way to work. I was thinking it might be starting to come apart..I guess time will tell. I have another one in the shed if it does, with all the other extra parts..:rofl:
  13. Jul 26, 2025 at 2:31 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Bedside exit will be a lot quieter than axle dump.
    Wynnded, mustang67408 and e30cabrio like this.
  14. Jul 26, 2025 at 2:45 PM
    mustang67408
    Victor
    Not sure I agree, only because my last 2002 S/C 4.7 Tundra had bed side exhaust, and it wasn't by any means quiet :rofl:
    Maybe because it was the 3 chamber flowmaster,,,,:eek::rofl:?????
  15. Jul 26, 2025 at 2:46 PM
    e30cabrio
    After sitting in the Panda "express" drive through for 25 minutes IAT was reporting 150 (114 ambient) highest I have ever seen in the Sequoia, I got these DTCs
    I flushed the coolant 6x more (now at 10) mostly coolant & water wetter came out but there was some oil. I also restored the original Magnuson reservoir.
    All the codes except the damn secondary air clear, it comes back immediately & if I clear it when the truck is running the motor dies. It's in super limp mode while the code is there
    Can HP Tuner tune it out? If so can anyone tell me how as sniv is out of town.
    If not can I get the Hewitt kit & just do the wiring harness part? I really don't want to mess with the blockoff.
    I just can't get a break OH, and to prove that, I got a Federal Jury summons today. KMN
    HulkSmurf14, Mdl and mustang67408 like this.
  16. Jul 26, 2025 at 3:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Until sniv returns I can disable codes if you want. Usually limp mode is not enabled on the tune. How are air pump connections, passenger fender? Check the power connectio s by dipstick and drivers connection by fuse block.
    I did a test when my I/C pump was disabled at 88deg F. I ran 2 WOT runs and had knock retard in the 5's and 2 events in 6's which was not present with normal lower temps. Also happened around 3500-4000rpm. Wonder how you guys in the heat deal with it?
    Wynnded and e30cabrio[QUOTED] like this.
  17. Jul 26, 2025 at 3:18 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    When I went from dual rear bedside exit D, P side to axle dump it was 4x's as loud.
  18. Jul 26, 2025 at 3:40 PM
    e30cabrio
    Thanks, I started a conversation
    HulkSmurf14 and Mdl[QUOTED] like this.
  19. Jul 26, 2025 at 4:18 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Same
    my Trd cat back changed sound with the s/c
    it’s holding up quite nice
    Grok said it was good for ~550 hp
    My unprofessional uneducated guess is a dual exhaust is more better
  20. Jul 26, 2025 at 4:42 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Unless! ;)
    This discussion hits home because I don't know which muffler to go with. It's going to be louder with the built motor. It's going to be louder when I go 4" turbo back. I'm concerned about that balance between volume and performance.
    The DD factory cat back was good for about 4psi. The banks true 3" was good for about 6-7psi (~525whp), but was a little louder. 4" should serve me fine, but only because I can't fit a true 5". The issue is resonator, muffler, or both in different sizes? I'm probably going to bring in 3-4 and try them under different loads to find a good balance.
    Between videos not doing justice, personal preference, and literally being at the peak of one system vs 1/2 flow of another is so hard to narrow this stuff down.
  21. Jul 26, 2025 at 4:46 PM
    e30cabrio
    I found this thread on HP Forum, I do not find the values it refers to, maybe it's 2007 only? I did find them in diags but the codes are numbered differently. I made a file unchecking the diag boxes in these pictures, no more air codes, but 101 is now permanent, seems my turbokts MAFs don't like me. I'm going to throw the OEM MAF in & see what happens after it cools down some, it's 114 & IATS reported to be at 161 when idling.
    https://forum.hptuners.com/showthread.php?82531-Tundra-SAI
    mustang67408, Saltyhero13 and Mdl like this.
  22. Jul 26, 2025 at 4:47 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    That turbo wants the biggest exhaust/ no exhaust possible. Couple large burns mufflers or resonators would be the way to go. That’s what we ran on the big 1000+hp Supra’s
  23. Jul 26, 2025 at 5:06 PM
    bflooks
    bflooks New Member
    Metrowest MA
    That Engine Masters episode ruined me! And then to follow MotorTrends articles about their Supras gaining 50+HP with 1/2" upsized exhaust made me commit right away to it. Enter that healthy friction of performance vs usability/driveability. Track day vs tow day is extremely different and I'll give up some HP for peace and sorta quiet. #spokenlikeatruepre-1992baby
  24. Jul 26, 2025 at 5:17 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Well I don't have cats and DD true dual 3 inch all thr way back fron the LT's with 1 7/8 collectors. Seems to hold up to the 15psi I pushed through it. Probably sitting at 650hp ish?
  25. Jul 26, 2025 at 5:21 PM
    bflooks
    bflooks New Member
    Metrowest MA
    My issue on the turbo is the circulated wastegate. The stock cat back could handle the 4psi, but not more without dumping the wastegate. Mind you, the waste gate at those pressures were down around 20-24% DC. That's a lot of extra air to pump through a system after the O2s.
  26. Jul 26, 2025 at 5:21 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Ok...ok. you got the big boy turbo that doesn't want to mess around and get straight to the point! Haha I had to re-read and forgot you may want to go with some bigger HP numbers!
  27. Jul 26, 2025 at 5:23 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Do you have your file with stock supercharger MAF values before the turbokit maf? Your fuel trims will be way off if you just swap em without a rewrite.
  28. Jul 26, 2025 at 5:43 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Damn it. Heard loud and clear. Don't let me become that tone deaf guy! Not my intention at all.
    Tripleconpanna and HulkSmurf14 like this.
  29. Jul 26, 2025 at 7:54 PM
    e30cabrio
    Anyone know how to find the Magnuson air filter lid on SCOL? I vaguely remember it was a hassle. My MAF has been out so many times there is no more material in the screw "threads", I have used high temp RTV last 2 times & it's not happy after doing it again.
    mustang67408, Mdl and HulkSmurf14 like this.
  30. Jul 26, 2025 at 8:02 PM
    AZTundra
    Paul
    Phoenix, AZ
    Let me check my email. I had called them about a replacement lid a couple of weeks ago due to the corner on mine cracking. I think they emailed me an invoice which might be of help.
    mustang67408, HulkSmurf14 and Mdl like this.
