General Supercharger Thread
  1. Jul 25, 2025 at 4:07 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    What codes are you getting exactly?
    e30cabrio and HulkSmurf14 like this.
  2. Jul 25, 2025 at 5:31 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    P0101 and the left bank rich right bank rich codes I think were P0172 and P0175.
  3. Jul 25, 2025 at 6:44 AM
    Silver17
    Eastern PA
    Maybe it’s a good time to invest in a smoke machine to find leaks quickly and not waste time pulling unnecessary stuff off the truck. Is your vacuum hose connection under the snout on there tightly? I remember that was a kind of suspect connection and I added additional clamps. I want to get a smoke machine myself since these problems are pretty common and they’re pretty affordable.
  4. Jul 25, 2025 at 6:55 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I built a cheap diy one a few years ago, paint can, nichrome wire, lamp wick, and mineral oil. Worked great to track leaks on my wife's LS430.
    I think they're getting cheaper now tho.
  5. Jul 25, 2025 at 7:12 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    HulkSmurf14 likes this.
  6. Jul 25, 2025 at 7:14 AM
    VWTim
    Corvallis, OR
  7. Jul 25, 2025 at 7:17 AM
    e30cabrio
    My issue there was fuse delete, I am back to the GM version for now. I ordered the HKB.
  8. Jul 25, 2025 at 8:31 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    HKB is the way to go. I had the VB pro on my wife’s T4R and low setting was still a touch high. HKB on my Taco and it’s perfect. I keep the OG fuse in my console in case. Note the HKB is directional, you’ll know right away if it’s backwards, you’ll get an alternator/battery light on the dash.
  9. Jul 25, 2025 at 9:38 AM
    e30cabrio
    New motor first Synthetic oil change question.
    I'm doing the drain & fill tomorrow. Have the 30 dyno in there. As I am in a hot climate and the oil never gets "cold" should I use a straight weight? If so, what would you guys use?
    I have a bunch of Kirkland 0-20 but feel like I'd be better off going to a 40 weight. What do you guys think?
  10. Jul 25, 2025 at 9:57 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    40w for the win!
    e30cabrio likes this.
  11. Jul 25, 2025 at 10:40 AM
    Saltyhero13
    Yes. Good suggestion. Already did smoke myself and the mech working with Sniv did as well. Found an exhaust leak after the O2s using it. No leaks detected before the engine or at the headers before O2. I think it is only occurring under high boost so smoke and other methods didn't pick it up until the system is pressurized. Definitely can run it again before taking more drastic measures.
    Are you talking the two lines from the valve cover connecting to the intake? or the other end of the PCV/Catch can lines going back into the engine?
    PCV seems to be working since my can is catching blowby residue, doesn't mean it isn't getting stuck. Cheap enough to replace.
    I don't have evidence boost is leaking from the oil cap question was more is it possible and if so what condition(s)? Stuck PCV seems to be the answer.
    On a new MAF and O2s, everything else is buttoned up tight.
    Last step is to remove the laminar flow screen since the MAF basically has a similar feature. Eliminating that as a potential issue.
    Mdl and HulkSmurf14 like this.
  12. Jul 25, 2025 at 12:14 PM
    e30cabrio
    70 buck smoke machine on Amazon works well. I hope you find the issue.
    Mdl and Saltyhero13 like this.
  13. Jul 25, 2025 at 12:29 PM
    Saltyhero13
    Thanks. So far no luck with it except for the inconsequential exhaust leak.
    e30cabrio[QUOTED] and Mdl like this.
  14. Jul 25, 2025 at 12:36 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm partial to Mobil1 5w-40 or 0w-40 ESP. The 5w has a little better bearing additives than 0w.
  15. Jul 25, 2025 at 12:56 PM
    HulkSmurf14
    2014 Tundra Limited
    5w40 in the winter, 10w40 in the summer...just like any boosted Euro car...there's a reason why it's used...keeps things sealed, lubed, and happy...until it's not!
    Mdl and e30cabrio like this.
  16. Jul 25, 2025 at 12:58 PM
    centex
    centex New Member
    Everything I own except the rzr gets 5-30 Mobil one. Lawn mower, all three vehicles, generator, heck even my chain saw blade gets it.
  17. Jul 25, 2025 at 1:15 PM
    e30cabrio
    I have 4 cases of this Castrol for the BMW.
    HulkSmurf14 and M3Tundra-JK like this.
  18. Jul 25, 2025 at 1:25 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    good reminder, I need to change the oil in the M3. $100 diy oil change incoming
  19. Jul 25, 2025 at 1:27 PM
    e30cabrio
  20. Jul 25, 2025 at 1:28 PM
    HulkSmurf14
    2014 Tundra Limited
    I'm rocking the Valvoline version...
  21. Jul 25, 2025 at 1:30 PM
    M3Tundra-JK
    Scott
    2005 GX470
  22. Jul 25, 2025 at 1:32 PM
    HulkSmurf14
    2014 Tundra Limited
    That's the site I use for my S2, but not that thick...EXCELLENT oil!
  23. Jul 25, 2025 at 1:34 PM
    M3Tundra-JK
    Scott
    2005 GX470
    When you absolutely, positively, gotta use all 8.5k RPM's in every gear lol
  24. Jul 25, 2025 at 1:34 PM
    HulkSmurf14
    2014 Tundra Limited
    CAN'T STOP, WON'T STOP!!
    Tripleconpanna, Mdl and e30cabrio like this.
  25. Jul 25, 2025 at 1:54 PM
    Silver17
    Eastern PA
    I’m talking about this guy here by the crossover pipe. That reminds me, I still have that intake honeycomb before my MAF as well, and that was actually what resolved my P0101 codes paired with a new tune. Maybe your honeycomb shifted in the pipe and is messing up your MAF? Mine was a tight fit and I added a couple rivets.
  26. Jul 25, 2025 at 3:15 PM
    Saltyhero13
    The double clamped hose underneath the snout (looking through the install manual the others are coolant)? I'll take a look at it when I get the truck back next week. What symptoms did you have and how did you detect the issue?
    My honeycomb is straight in and not moving. It was riveted in by MRP when they built my custom MAF intake tube. It is also at the 3.5" from the MAF which meets their recommendation for distance from the MAF. The fins aren't damaged either.
    Did you retune when you installed the honeycomb or was it running like shit and the honeycomb fixed it?
    I asked MRP about the screen, they basically said they have customers who install them on OEM applications without retuning and they work fine. I doubt its causing any issue just eliminating it as a potential cause. Mine was in before retuning.
    Thanks.
  27. Jul 25, 2025 at 3:53 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    When I had my 101 code, right after install
    it was that connection under the snout
    it looked tight but it wasn’t
    only got the code in boost situations
    I put a mondo pipe band on it. All is well
  28. Jul 25, 2025 at 4:45 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I installed a honeycomb straightener but yanked it out a month ago. No change in performance with its removal or codes.
  29. Jul 25, 2025 at 5:43 PM
    Saltyhero13
    Well shit! This is probably my culprit.
    Is it 10d in the install manual?
  30. Jul 25, 2025 at 5:52 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    instructions? Don’t nobody read that chit
