Front CV axles for 2.5" lift
Discussion in '1st Gen Tundras (2000-2006)' started by buccirj, Apr 30, 2022.
  1. Dec 7, 2023 at 2:53 PM
    Yeah their budget axles don't have good reviews. I opted for their "best" axles with silicone boots and they have held up perfectly since 2020.
  2. Dec 7, 2023 at 3:49 PM
    evanhmn
    evanhmn mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    Just about always always always go with OEM my dude. Just had my driver-side CV axle replaced a couple of days back and opted for OEM over a $120 less alternative. It hurts the pocket but better than having to do it twice :D
    BooRoc and WaTrout88[QUOTED] like this.
  3. Dec 7, 2023 at 4:06 PM
    BooRoc
    BooRoc New Member
    Drew
    No Shit. Thanks for the heads up Man. I am about to spend a fortune on a front and rear gear set up from ECG and am gonna order a set of OEM reman axles Stock with heavy duty hose clips.
    WaTrout88 likes this.
  4. Dec 8, 2023 at 8:25 AM
    WaTrout88
    WaTrout88 Toyota Family
    Ben
    Spokane, WA
    1978 FJ40, 2002 Tundra TRD, 2018 Tundra
    2002 Toyota Tundra - Billy's 5100 2nd Notch, 285/75/16 OEM Wheels + 1.5" Spacers, Archive Garage HD Leaf Springs, AG Bump Stops, Freedom Offroad UCAs, ARB Coil Springs 2887
    I believe the Silicone boots are only on the inner portion of the axel. The guy at CVJ said they do not install them on the outers because they have a greater risk of tearing due to road debris/branches ect. Glad to hear your outers are holding up tough. Maybe they changed the material used at some point.
  5. Dec 8, 2023 at 9:24 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I think the OEM boots are plastic and that's what CVJ uses on the "best" option.
    BooRoc likes this.
  6. Dec 8, 2023 at 9:43 AM
    WaTrout88
    Ben
    Spokane, WA
  7. Dec 8, 2023 at 5:07 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    Lookout Mtn Georgia
    Mine are hanging in just fine (all paved though for me)..
    shifty` likes this.
  8. May 15, 2025 at 7:08 PM
    HipHapa
    HipHapa New Member
    2008 Tundra Crewmax Limited
    6112's & 33's
    I have an '05 with a 3" lift on 34's. Just replaced a boot while installing the lift. After a couple months and 2 off-road trips, OEM boots tore on both sides. Just upgraded. My mechanic has used these on several 1st Gen Tundras with good feedback.
  9. May 15, 2025 at 7:32 PM
    What are “these”?
    bmf4069, FrenchToasty and Spread5150 like this.
  10. May 15, 2025 at 7:52 PM
    Spread5150
    Spread5150 New Member
    Dave
    2000 Tundra 4x4 SR5 V8 2019 Tundra TRD Pro 1994 Toyota Pickup 4x4
    I also want to know what they are ?
    I did the off road solutions boot on a reman axle and I have been happy.
  11. May 15, 2025 at 8:19 PM
    That p/n is the same as on my Trakmotive extended travel CVs.
  12. May 16, 2025 at 8:17 PM
    HipHapa
    HipHapa New Member
    6112's & 33's
    Yes. They're the TrakMotive extended travel CV axles.
  13. May 16, 2025 at 11:10 PM
    BooRoc
    BooRoc New Member
    Drew
    I have the exact same ones as well. Found them on Rock Auto. So far so good.
  14. May 17, 2025 at 3:51 PM
    We couldn't get mine to seat right so they're leaking. I believe @NickB_01TRD has the same ones as well.
    B888s likes this.
  15. May 17, 2025 at 5:42 PM
    B888s
    B888s New Member
    Brandon
    Bakersfield, CA
    2000 TRD Off-Road SR5 4x4 Access Cab
    Original owner!
    My son has been running the Tracmotive on his 200 AC 4x4 for a little over a year. He will Ben hone in a few weeks to do the front brakes. I will post up pics on how they are holding up. I saved to stock ones to potential rebuild in the future.
  16. May 18, 2025 at 4:46 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Yup. No issues with mine
  17. May 18, 2025 at 6:04 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    My trackmotives are holding up after 2 years.
  18. May 18, 2025 at 6:05 AM
    Those may need to be my next set in a few years when these boots split yet again on these Advanced Auto axles
  19. Jul 24, 2025 at 3:56 PM
    Wareagle69
    Wareagle69 New Member
    Jared
    03 limited Tundra 4wd
    2.5 suspension lift
    do you mean remanufactured as reman?
  20. Jul 24, 2025 at 4:20 PM
    #50
    Yes.
  21. Jul 24, 2025 at 4:31 PM
    #51
    Reman OEM is currently unavailable. But you can still buy new, bulletproof, new OEM CV axles, whose boots won’t start to tear or crack in 1-3 years like almost all the aftermarket ones will.
  22. Jul 24, 2025 at 7:11 PM
    #52
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    If your oem cvs arent damaged except for the boots, it may not be necessary to replace the whole CV, especially if lifted and the boots are rubbing that could again cause them to wear into splitting? Here's a picture of the rubbing that happens with high angle:
    https://www.tacomaworld.com/threads/my-cv-boot-mod.190669/page-4#post-5287675
    Are your inner boot baffles touching?
    Here's a rundown of options for rebooting. There's links to the 930 boots available from KarTek Offroad, the CVJ boots if so inclined to go with a really epensive option, and the Allpro kit, as well as details on outer OE kit, and rolled edge clamps from Cap Hardware, along with a video and write up of the installation.
    Cap Hardware's phone # is (949) 235-7658 BTW and they are very helpful.
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-1916#post-3451375
    New links to the Norma Toro and Carlyn clamps are here:
    https://www.caphardwaresupply.com/p...yle-hose-clamps-9mm-wide-25-40mm-w4-stainless
    https://www.caphardwaresupply.com/product_detail/40-60mm-torro-thin-clamp-partial-ss
    Think it was $15-20 including shipping for a set of eight. Don't then have to buy special pliers and also can tighten as desired with more control to address grease sling.
    shifty` and BooRoc like this.
