General Supercharger Thread
  1. Jul 22, 2025 at 9:49 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    sounds good, but was hoping to see the fuel that already in it....
    like sniv said keep driving the "old stuff" out until you're sure the "New" stuff is in
    HulkSmurf14 likes this.
  2. Jul 22, 2025 at 9:52 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I get it, I really don't want to mess with the not leaking fuel system right now.
    I have this from when Advance closed my local store, I can add it & see what happens.
  3. Jul 22, 2025 at 9:54 AM
    mustang67408
    Victor
    Totally Understand:thumbsup:
    e30cabrio[QUOTED] likes this.
  4. Jul 22, 2025 at 10:01 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    That and the IATs at the lowest yesterday were 111F before the blower, so that sure isn't helping things.
  5. Jul 22, 2025 at 10:16 AM
    e30cabrio
    It was 105 and 50% humidity, the IATs are significantly higher than the + 3-5 it was.
    It's "cool" thanks to Monsoon season & the humidity it brings.
    mustang67408 likes this.
  6. Jul 22, 2025 at 10:21 AM
    bflooks
    bflooks New Member
    Metrowest MA
    hey folks, just heard back from XAT on the water jacket discussion. They've never seen one fail and they can only think of a catastrophic failure or contamination (e.g. never changing your coolant) to cause damage/wear/failure. they did say that some people actually forget to replace them during engine builds, so i guess that's an interesting variable, but Andrew says they are 100% required for adequate cooling and to prevent hot spots.
    on a brighter note for myself, the motor is getting picked up today and should be to the installer on Friday.
    Edit in bold
    ARES35, Jego, ssmokedz and 8 others like this.
  7. Jul 22, 2025 at 11:09 AM
    mustang67408
    Victor
    Toyota says the same thing...
    Saltyhero13, e30cabrio, Mdl and 2 others like this.
  8. Jul 22, 2025 at 11:19 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I've got nothing. I wasn't even aware they existed. lol I asked, they responded, I'm relaying. Nice to know they haven't seen an issue with them.
  9. Jul 22, 2025 at 11:19 AM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    I think the concern @Jowett was showing was for the fact that the wall of the plastic jacket on the intake side is more restrictive to flow than the exhaust side, and he was proposing trimming the intake side for more flow and cooling, not removing it entirely. He suggested the damage to the pistons was seeming to possibly stem from the intake side getting too hot if I was reading his comments correctly.
  10. Jul 22, 2025 at 11:25 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Clearly I don't have the cycles to keep on top of it all and to relay correctly. I'll exit stage left and go back to the gallery. I tried. lol
  11. Jul 22, 2025 at 11:29 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Correct. NA application vs FI adding extra heat on intake.
  12. Jul 23, 2025 at 5:06 AM
    ssmokedz
    Shelton CT
    I can't wait to hear that thing.
    Mdl, e30cabrio, Tundra Texan and 4 others like this.
  13. Jul 23, 2025 at 1:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Although my zzperformance I/C pump failed after 2 years. Looks like motor grounded out. It could be a few things that happened. I bought a new one and paid for standard shipping. They express shipped it out. That was a nice surprise.
  14. Jul 23, 2025 at 6:10 PM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    How did you know it failed?
    e30cabrio and Mdl[QUOTED] like this.
  15. Jul 23, 2025 at 6:55 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It's run off my ignition fuse. I turned the key to ACC to work on my radar/laser mount and it was too quiet. It probably failed a few days prior but didn't notice. Another reason to get the dual IAT gauge so I can see if the SC air is not normal.
  16. Jul 24, 2025 at 3:30 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    same here. ignition fuse
    my IAT gauge (scangauge 3) saved me when my relay decided it needed to sit sideways.(Thx @Saltyhero13)
    EX:
    my IAT runs ~30 degrees above ambient (Harrop sensor)
    when the IC pump is not on...it will go up to 80degrees above ambient.:bananadead:
    IAT was 165 degrees when the pump was glitched last time.
    ever since I tilted my relay sideways, it has run flawlessly. <knocking on wood>
    and thx to @Silver17 for the IC cooler cap replacement info. <mine was leaking>
    my IAT now runs ~28 degrees delta.....it was ~30 degrees for a long time.
  17. Jul 24, 2025 at 9:37 AM
    e30cabrio
    Do we have an idea of how much difference there is between the IAT at the MAF & the SC? (on approximate average)
  18. Jul 24, 2025 at 9:50 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    You could use me as an example
    add 30 degrees to your maf temp and you will get your post s/c temp
    made a little more if you run a 1900, as they spin faster
  19. Jul 24, 2025 at 9:57 AM
    Silver17
    Northeast
    It’s hard to say how much of that 30 degrees is also just heat soak from the supercharger manifold radiating heat into the sensor from direct contact with the engine. The air itself is likely cooler than our reading.
  20. Jul 24, 2025 at 10:06 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I should have at least drilled and tapped for the air sender whenvi had it apart. At least it can be done by just pulling the IC brick.
    Edit: Think I'll put the IAT sender in between cylinder 5 and 7 since those were historically prone to pop.
    e30cabrio and HulkSmurf14 like this.
  21. Jul 24, 2025 at 1:34 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Opened up the side of the airbox to combine the air accelerator and SABM. I didnt get to finish as I got company coming. Will use some roof flashing as a mold to fiberglass a section into the fender well. The flashing contours to the accelerator cutout well.
    Anyways I ran to the store and picked up a full psi of boost. Hit 15 psi and it was pulling really well.
    I grabbed some pics from the SABM mod thread.
    BigAl, e30cabrio, Silver17 and 10 others like this.
  22. Jul 24, 2025 at 5:52 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Anyone leak boost via oil cap?
  23. Jul 24, 2025 at 6:13 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  24. Jul 24, 2025 at 6:13 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The engine oil fill cap? Can that even happen?
  25. Jul 24, 2025 at 6:16 PM
    Silver17
    Northeast
    You think you have some major blowby happening?
  26. Jul 24, 2025 at 6:38 PM
    centex
    centex New Member
    That’s not supposed to happen.
  27. Jul 24, 2025 at 7:18 PM
    HulkSmurf14
    2014 Tundra Limited
    You need to change out your PCV and then go to the next step...cheapest/easiest thing first, tho...
    Wynnded and bflooks like this.
  28. Jul 24, 2025 at 7:20 PM
    HulkSmurf14
    2014 Tundra Limited
    Possible causes...
    Wynnded, Saltyhero13 and Mdl like this.
  29. Jul 24, 2025 at 7:46 PM
    Saltyhero13
    Hit a MAF error and double rich banks again. PCV is good. Eliminating everything else before pulling the blower to check the seals.
    Wynnded, Silver17[QUOTED] and Mdl like this.
  30. Jul 24, 2025 at 7:50 PM
    Saltyhero13
    Thank you for this.
    HulkSmurf14[QUOTED] and Mdl like this.
