General Supercharger Thread
  1. Jul 21, 2025 at 8:03 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I drive it less than 200 miles a month, generally 100. It's got about 180 or so since last Wednesday & 80 of that is the trip home & a round trip back to get my transmission oil, Toyota red & the Jowett filter housing they forgot to give back.
    sniv said to put some miles on it & see if it works out the issues, it's possible it's learning from being batteryless for a month.
    I am babying it for now, trying to stay under 4k rpms (you can see I failed in the log) lol
  2. Jul 21, 2025 at 8:04 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    What plugs went back in?
    Mdl likes this.
  3. Jul 21, 2025 at 8:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It could be over torqued or loose knock sensor. Drive a bunch as new tunes can be funky until settled. Condition of plugs etc.
    HulkSmurf14 and snivilous[OP] like this.
  4. Jul 21, 2025 at 8:08 PM
    e30cabrio
    New Denso IKH24.
    HulkSmurf14, Mdl and reywcms[QUOTED] like this.
  5. Jul 21, 2025 at 8:29 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    It's like the mod gods are telling you to just stop...
    HulkSmurf14 likes this.
  6. Jul 21, 2025 at 8:48 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    My intercooler zzperformance pumps motor just fried. It's 4 years old. Will order up another tomorrow after I call them to see if any discount. Can't hurt to ask...
    M3Tundra-JK, HulkSmurf14 and reywcms like this.
  7. Jul 21, 2025 at 9:11 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    The before graph is running the same tune the engine has before the rebuild, why there is so much retard happening on the same setup I don't know.
    The after looks worse than it is, the high retard events were one offs, but I pulled a ton of timing to get there so still odd those are showing up. The truck now has like 7deg less timing in general than a normal tune I would do, which considering it's a pretty low boost setup is weird to me.
  8. Jul 22, 2025 at 5:50 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    DID the truck sit for quite a while during the rebuild? Did the fuel go bad? Overtightening of the knock sensors is a common thing, it distorts them. They only need to be snug = 15ft/lbs torqued. They are in the valley.
    They go in these 2 bolt holes on the drivers side and there are 2 more on the passenger side. 4 Total
  9. Jul 22, 2025 at 5:56 AM
    e30cabrio
    It sat for about 5 weeks, came back with 1/4 tank. I filled it with 18 gallons of 91 (most available here)
    I hope they fastened them properly, but obviously there's no way to know.
  10. Jul 22, 2025 at 6:11 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Note to self replace knock sensors while it’s apart lol
  11. Jul 22, 2025 at 6:18 AM
    mustang67408
    Victor
    I would also recommend replacing the knock sensor wire too. It is a small harness the connects all the sensors to a plug at the back of the engine. Those wires get very hot and brittle.
  12. Jul 22, 2025 at 6:23 AM
    Land Bruiser
    Land Bruiser New Member
    2018 Lexus 5.7
    Harrop 2650, 285/70r20
    Yes, voles, packrats, and ground squirrels also love to make nests there and chew through the knock sensor harness. That was fun to deal with last year.
  13. Jul 22, 2025 at 6:34 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Literally pulling these numbers up for quick shipping. I got replacement crank sensors but didn't think of this.
    HulkSmurf14 and reywcms[QUOTED] like this.
  14. Jul 22, 2025 at 6:36 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    You have a part number handy for the wiring
  15. Jul 22, 2025 at 6:37 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    HulkSmurf14 and bflooks[QUOTED] like this.
  16. Jul 22, 2025 at 6:39 AM
    e30cabrio
    I spent a fortune on all the while I was in there stuff in December. All sensors, gaskets, O rings, Alternator, Starter, torque converter.
  17. Jul 22, 2025 at 6:40 AM
    e30cabrio
  18. Jul 22, 2025 at 6:41 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yep I’ve already got the other items new from when the headers went it. Along with a new high amp alternator that was included in my first parts pallet to sniv.
  19. Jul 22, 2025 at 7:04 AM
    bflooks
    bflooks New Member
    Metrowest MA
    82219-0C020
    https://www.toyotapartsdeal.com/oem/toyota~wire~sensor~82219-0c020.html
    Not sure if this is qty 1 or qty 4. I'm just going to call Fred Anderson. Their prices are a few bucks less (literally a total of $5 savings), but they ship quickly. Will report back once I get the answer.
  20. Jul 22, 2025 at 7:11 AM
    mustang67408
    Victor
    bflooks[QUOTED] likes this.
  21. Jul 22, 2025 at 7:14 AM
    e30cabrio
  22. Jul 22, 2025 at 7:15 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    @e30cabrio is it knocking even without you driving in boost?
  23. Jul 22, 2025 at 7:32 AM
    e30cabrio
    I'm blissfully unaware of any knocking.
    It felt better before the reduction in timing but obviously I prefer less possibility of damaging the motor
  24. Jul 22, 2025 at 8:03 AM
    mustang67408
    Victor
    Can you get a clear clean glass bottle or jar and get a fuel sample so we can see what the fuel looks like? No fancy tools needed, just you and another person.
    I know it's not scientific, but a lot can be determined from fuel smell, (Iknow we can't smell it on the intenet), and looks, without having to send it out. You might be able to smell if its "BAD" (turpentine or just old) or just smells like regular gasoline.
  25. Jul 22, 2025 at 8:58 AM
    Silver17
    Eastern PA
    Just wondered, since you were just messing with the intercooler loop maybe it is air bound or the pump stopped working. Shouldn’t matter with regular driving though I would think.
    HulkSmurf14 and mustang67408 like this.
  26. Jul 22, 2025 at 9:08 AM
    e30cabrio
  27. Jul 22, 2025 at 9:10 AM
    mustang67408
    Victor
  28. Jul 22, 2025 at 9:16 AM
    bflooks
    bflooks New Member
    Metrowest MA
    y'all were correct. 1 harness, 4 sensors. part numbers confirmed by Fred Anderson.
  29. Jul 22, 2025 at 9:30 AM
    e30cabrio
    I think they have the reservoir hoses backwards, did not notice until after the last drain & fill. The pump absolutely runs, I can feel the liquid moving through the output hose.
  30. Jul 22, 2025 at 9:44 AM
    e30cabrio
    I have an AN 8 adapter there & AN hoses running to my FPR. I will fill up & get a small sample of the new gas from the same station which is where I get my gas 99% of the time.
    mustang67408[QUOTED] likes this.
