2024 TUNDRA REAR NOISE RATTLE
Discussion in '3rd Gen Tundras (2022+)' started by aleayala18, Dec 14, 2023.
  1. Nov 14, 2024 at 7:26 PM
    #61
    alex17117
    alex17117 New Member
    Alex
    2024 limited, Lunar Rock
    Did they replace the whole assembly or just one of the components?
  2. Nov 15, 2024 at 5:21 PM
    #62
    alex17117
    Alex
    I torqued my cab mounts and that significant reduced the clunking on bumps I was experiencing. I still get it on big bumps so might consider replacing them eventually.
    I also retorqued the bed bolts after backing them out and greasing the contact points with the frame. I found when I loosened the bolts, half of them popped like they were holding a bunch of tension from the composite bed. Now my bed rattling is gone!!
    Tundrastruck91 likes this.
  3. Nov 16, 2024 at 4:34 AM
    #63
    myfirsttundra1
    myfirsttundra1 New Member
    2023 Platinum crewmax
    what size torx did you need for the bed bolts?
  4. Nov 16, 2024 at 5:05 AM
    #64
    alex17117
    Alex
    T55
  5. Nov 16, 2024 at 5:10 AM
    #65
    Pine_Cone67
    Pine_Cone67 New Member
    2024 Tundra Limited
    Any chance you can post a pic showing the location of the cab mounts/bolts? New owner here with only 1,000 miles but already scared I’ll develop the clunk and want to be prepared when the time comes ….
  6. Feb 3, 2025 at 10:12 AM
    #66
    Tundrum74
    Tundrum74 New Member
    San Diego
    2024 Tundra Limited TRD Offroad Ice Cap
    All stock
    Update: Dealer replaced seat belt retractor, of course it did not fix the issue, now my truck is at the dealer to have the bed removed (per Toyota Corp) to see if that is the issue, maybe when this doesnt fix the issue they will get to the Dynamic Cab mounts, one can hope!! I even explained to the service writer that the noise went away when I had 3 grown adults in the back seat, but it really doesnt matter, the dealer mentioned this to Toyota Corp but that clearly didnt sway them. Happy Monday!
  7. Feb 3, 2025 at 10:31 AM
    #67
    Samuryan
    Samuryan Nayrumas
    Reno
    22 sr5 trd OR
    I posted in another thread, but I too had the bed rattle. Loosened all my bed bolts then torqued them down and the rattle is gone. The bed "popped" when all the bolts were loose, like it relieved all the tension.
  8. Feb 3, 2025 at 10:41 AM
    #68
    Tundrum74
    San Diego
    All stock
    Thanks for the response. That could be the issue as well, if I didnt have the factory sprayed bed liner I would have tried that as well but I didnt want to mess up the coating, I'll let the dealer fiddle with it and see what happens.
  9. Feb 28, 2025 at 10:03 AM
    #69
    jcar25
    jcar25 New Member
    DFW, TX
    2024 Tundra Limited
    Wondering if anyone who had their cab mount(s) replaced can send me what dealership you used. I have this noise happening and it's driving me crazy. My dealer can't seem to find any TSB for it, so they're dragging their feet a bit. I've had the truck since november and the noise started right around 5k miles, and I'm at 7500 now. Truck is phenomenal otherwise, just hoping I can somehow get my dealership in contact with another that has seen trucks with the issue. Thanks!
  10. Mar 1, 2025 at 12:57 PM
    #70
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    Got my hydraulic cab mount replaced, no more noise. Only the passenger side replaced and that was where the noise came from. They also replaced front brake disc and shim kit, no more squeaking. Also, got the 2nd key.
    Got to drive the Taco TRD OR 4- banger for a day and I'm glad I didn't buy the taco.
  11. Apr 25, 2025 at 12:37 PM
    #71
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Happy customer over here finally. I have 13k miles on my 24 Platinum and I told my dealer about a noise that was driving me crazy at low speeds over bumps at my 5000 mile oil change. They inspected truck and didn’t find anything abnormal. I have a lot of stuff in my bed and I figured it was something rattling cause I took everything out and for a quick mile jaunt I didn’t hear it. Since then I tried securing things better but the noise was still present. Went in for an oil change the other day and showed my dealer this forum and insisted they check my bed bolts and my cab mounts especially the drivers side. After a little back and forth he agreed that it was most likely the cab mount and he replaced drivers side. My noise is finally gone. It was a light thumping noise that I was hearing. Thank you to this forum!!!! Hope this helps someone else.
    GoHuskers and Tundrastruck91 like this.
  12. Apr 25, 2025 at 2:25 PM
    #72
    Dudeman PNW
    Dudeman PNW New Member
    24 Limited Hybrid Crewmax SS Red
  13. Apr 25, 2025 at 2:26 PM
    #73
    Dudeman PNW
    I can hear it squeak going down the road, especially when I hit bumps.
  14. Apr 25, 2025 at 2:41 PM
    #74
    Ero2
    Ero2 New Member
    Has anyone with non-hydraulic cab mounts had the cab mount replaced and it get rid of the noise? I had my truck in for the last three days and they say they can’t replicate it and that they’re not allowed to test drive over 10 miles an hour to try to replicate it. I explained that it doesn’t happen all the time Just quite a bit and I provided videos too, but they said they can’t replicate it so sorry.
  15. Apr 25, 2025 at 2:43 PM
    #75
    Ero2
    Ero2 New Member
    Also, if you have the spray in bed liner and back out the bolts do you have to break the spray / crack it to get the bolts out, or just do it from the underside? Never done this before for sure.
  16. Apr 25, 2025 at 7:23 PM
    #76
    Ero2
    Ero2 New Member
  17. Jul 18, 2025 at 3:23 AM
    #77
    FishinD
    FishinD New Member
    2024 White Tundra TRD
    Hi Guys. Want to say thank you so much for this thread. I had been experiencing that exact same noise for several months now. Slowly getting worse. Bought my 2024 SR5 Crewmax in December and for first 4 ish months it was perfect. Then I started noticing the sound over small bumps. I have an aftermarket tonneau I installed so o thought it was that. I removed. Still noisy. Took out the jack and emptied out the rear. Still there. Finally took it to Dealer.
    The noise baffled them too. My guess is this was their first go around with it. They had truck there for 2 weeks. Ordered and installed bolts, washers and bushings for the rear seat. At this time I took to the interwebs LOL. Found this thread and played the video and had immediate PTSD. There was the exact noise! Kept reading to discover yall had rear cab mounts replaced. I mentioned this, and sent a link to this thread to my dealer. Another 4 days go by. They reach out to tell me they replaced the bolts and bushings I mentioned above but the noise was still there. Shakes my head. Once again I point them to this thread, a bit more sternly and make a strong suggestion that they check the rear cab mounts. A week goes by and lo and behold, I get a text that they checked them, and replaced them. Problem solved! If only they had listened to me the first time. Would have saved themselves a lot of time and money. Anyhow this thread is a lifesaver. Hopefully it helps out fellow owners as I am sure there are many more out there going through this right now.
