Rear ABS Speed Sensor Connector Wires
Discussion in '1st Gen Tundras (2000-2006)' started by joeramirez, Jul 15, 2025.
  1. Jul 15, 2025 at 9:54 AM
    joeramirez
    joeramirez [OP] New Member
    2005 TUNDRA DC SR5 4WD V8
    2005 DC, SR5, 4wd, v-8 Replacing just the connector that plugs into the sensor and the colors on the existing connector are Blue and White. The new aftermarket connector has a black and white wire. Does the white go to white, and blue to black?S3115_Front.jpg IMG_1864.jpg
  2. Jul 15, 2025 at 11:50 AM
    Refer to the electrical wiring diagrams. Links to those are in the 6th line from the top of this thread: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    (Note the links to "Tundra" and "Sequoia".
    It will tell you the order in which the wires should go.
  3. Jul 15, 2025 at 12:20 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    joeramirez[OP] likes this.
  4. Jul 15, 2025 at 12:23 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Unfortunately you won't find that in the EWD per say. With the ABS rear sensors, there is an initial 4 pin connector(A19) at the rear that branches off....2 conductors each to RH and LH side.
    However, since the sensors are simply resistive, the 2 conductors of new connector can go either way.
  5. Jul 15, 2025 at 2:13 PM
    Actually, to this point, if the original connector is intact, as long as OP positions the connector in the same orientation as the original, and secures it using solder/heatshrink, or a waterproof butt splice, it will work as intended.
    1lowlife and joeramirez[OP] like this.
  6. Jul 16, 2025 at 3:36 AM
    bfunke
    bfunke Tundra Curmudgeon
    Why not repin your wires into a new connector. Toyota sells the connectors. @daveeasa can also recommend the correct Sumitomo aftermarket connector.
  7. Jul 16, 2025 at 7:34 AM
    I mean, the aftermarket connector should accept the same pins, so it should be feasible to unpin each wire from the existing connector, and re-pin into the same position on the aftermarket connector.
  8. Jul 16, 2025 at 8:12 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Perhaps the pins are not as bad as they look but from my couch those pins are beyond useable. Might as well do it right the first time.
  9. Jul 16, 2025 at 8:43 AM
    All I know is @joeramirez should swap out the unsealed butt splices they gave him for sealed ones. Given those wires are outside, will take on water, and are linked to a safety system and also his speedometer's ability to read (I think, is it rear or passenger front right, I forget?)
    Anyway, you don't want to be this seller, trying to offload a hacked up 1st gen for $35k, creating a dangerous situation for the owner: https://www.tundras.com/threads/you-guys-see-this-rig.161200/#post-3980240
    Always sealed/waterproof butt splices.
  10. Jul 16, 2025 at 9:45 AM
    This is apparently the acceptable way to repair it on $35,000 first gens.
    BubbaW likes this.
