TRD Pro light bar Switch P/N
Discussion in '3rd Gen Tundras (2022+)' started by Buellride, Nov 26, 2022.
  1. Jun 6, 2025 at 11:51 AM
    #91
    kjinxx2
    kjinxx2 New Member
    Posting here as well to spread the information for those who stumble upon this thread.
    FYI - I received PT45A-35240-PR today and can confirm that it is a TRD Light Bar switch with a white backlight (not blue)
    Calif-Tundra and AF555 like this.
  2. Jun 6, 2025 at 7:13 PM
    #92
    ghunter321
    ghunter321 Trail Hunter
    NC
    2022 Blueprint Limited Tundra
    Retrax Pro XR bed cover, UpTop Overland mid truss system with Baja Designs rock lighting X6, GGOffroad rearview camera relocation kit, Pelican cargo BX90 case, Maxtrax recovery traction boards, OEM bed step, OEM dash and door trim/cubby/footwell lighting, Slee Offroad dual wireless Qi phone charger upgrade, CBI covert front bumper with air dam delete module, TRD Pro heritage grille replace with amber OEM marker lights, Diode Dynamics 18" white lightbar kit and OEM marker lighting, Diode Dynamics covert 18" amber lightbar, Rough Country bed mat, Rough Country defender series fender flares, TRD camo tailgate spoiler and OEM marker lights, TRD camo rear bumper arms, Screen Protech for interior surfaces, OEM badge blackout
    Did Toyota stop making the part with a blue backlight? If not, does anyone have THAT part number?
  3. Jun 6, 2025 at 7:18 PM
    #93
    kjinxx2
    kjinxx2 New Member
    Switch with blue backlight: PT45A-34220-AA
    ghunter321[QUOTED] likes this.
  4. Jul 1, 2025 at 10:32 AM
    #94
    1FSTREX
    1FSTREX New Member
    Will
    Northern California
    2023 Limited OR
    Has anyone made further progress in wiring up an aftermarket light bar to the factory TRD switch? I saw the harness by @KClav but I’m trying to see if any additional new information has been discovered before proceeding.
  5. Jul 2, 2025 at 4:33 PM
    #95
    KClav
    KClav MGM Limited
    2022 Tundra Limited CM MGM TRD OR
    See post 79 in this thread
    https://www.tundras.com/members/raymondlopez27.126628/
  6. Jul 3, 2025 at 7:07 AM
    #96
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    Does anyone know if this part # is a toggle switch?
  7. Jul 4, 2025 at 6:17 PM
    #97
    kjinxx2
    kjinxx2 New Member
    It is a momentary switch
    Siblue likes this.
  8. Jul 8, 2025 at 8:06 AM
    #98
    1FSTREX
    1FSTREX New Member
    Will
    Northern California
    2023 Limited OR
    Thanks, unfortunately it looks like that harness isn't available on Aliexpress anymore. Just seeing if anyone else was able to find a pre-made one yet.
    Also curious what the need for the self locking relay is? Sorry kind of an electrical newbie here.
    Lastly, I was wondering if there is a way to build in the self locking relay into my existing Diode Dynamics wiring harness since the DD wiring harness includes a 4-pin relay already.
    Thanks for the help!
  9. Jul 13, 2025 at 7:44 AM
    #99
    Just1MoreMod
    Just1MoreMod New Member
    GA
    2025 Blueprint Tundra Limited
    I’ve gone through this thread multiple times and I’m just lost in the sauce. Anyone have a video or care to break it down Barney style?
  10. Jul 13, 2025 at 4:15 PM
    #100
    kjinxx2
    kjinxx2 New Member
    What exactly are you trying to do? Many of us use the OEM switch but there are countless ways to implement it
  11. Jul 13, 2025 at 5:33 PM
    #101
    Just1MoreMod
    GA
    Thanks for the reply. I’m prepping everything right now. I’d like to use the OEM TRD Light bar switch with a BD S8. I’d also like for the switch to be dimmable. Just trying to keep everything to look as factory as possible.
  12. Jul 14, 2025 at 7:58 AM
    #102
    tundradoan
    tundradoan New Member
    What is BD S8? Does it allow you to dim the switch lights?
    I got the Rave Of Road button and it's significantly brighter than OEM. I would like to dim it or switch it out with a different button. I have a platinum so I can't fit the OEM TRD button because of my running boards and step.
    sudobash likes this.
  13. Jul 14, 2025 at 8:28 AM
    #103
    kjinxx2
    kjinxx2 New Member
    https://www.tundras.com/threads/trd-pro-light-bar-switch-p-n.116422/page-2#post-3256955
    KClav's writeup up, which is a PDF attached to his post, is as Barney as it gets. The only difference here is that instead of running the 'switch illumination' where he said, you should T-Tap into the Purple & Brown wires on either the neighboring switches, or on the harness that is plugged into the blank that you're replacing.
    In terms of the harness no longer being available - I'm not sure if there is a substitute - you can find the actual harness connector by googling '1747375-2 harness' but all require you to crimp and insert wires (that's what I did).
    If that is the part you're stuck on I have an extra connector I could potentially make one for you.
    Where else are you running into trouble?
  14. Jul 14, 2025 at 8:34 AM
    #104
    Just1MoreMod
    GA
    Thanks for clearing that up. I’ve read the PDF a few times. I’m thinking about printing it out and having the wire shop at my job try to make one for me. No guarantees though. What pins did you use? What lengths on the wires? Not all lengths seem to be states or maybe I missed it.
    I would definitely pay for a harness if I can get one.
  15. Jul 14, 2025 at 8:35 AM
    #105
    Just1MoreMod
    GA
    I’m mounting a Baja Designs S8 20” light bar to the grille.
  16. Jul 14, 2025 at 8:40 AM
    #106
    LionsFan20
    Josh
    24 Tundra
    Well that's a bummer...I just bought some Rave switches as well lol. The OEM switch isn't a toggle switch is the problem. However the Tacoma has some "AUX" labeled switches that are toggle that my work better.
  17. Jul 14, 2025 at 8:44 AM
    #107
    kjinxx2
    kjinxx2 New Member
    The connector I ordered comes with the pins - https://www.corsa-technic.com/item.php?item_id=2082
    You would wire Pin 12 (switch illumination(+) Pin 12) to the purple wire inside of the dash & Pin 7 (switch illumination(-) Pin 7) to the brown wire inside of the dash - I can get a picture later.
    I only put a 6" or so lead off of the harness, then used solder seal wire connectors (https://www.amazon.com/dp/B083LZS69N) to hook up the longer wire runs (that go to the relays etc) and T-Taps (https://www.amazon.com/dp/B0BLK7FK52) to hook to the switch illumination wires.
  18. Jul 14, 2025 at 9:39 AM
    #108
    Just1MoreMod
    GA
    Is that Corsa connector the same one from the PDF write up?
    can these wires be soldered instead of using a TTap? TTaps are just prone to failure after some time.
  19. Jul 14, 2025 at 10:09 AM
    #109
    kjinxx2
    kjinxx2 New Member
    The corsa connector is not the same from the writeup - the one in the writeup is a pre-wired harness.
    You could solder but that would require cutting & soldering the existing vehicle's wires.
    I haven't had an issue with high-quality t-taps and I wouldn't be comfortable completely cutting & soldering my truck's wires. The ones I linked are high quality and very snug for the gauge they're designed for. It is up to you how you tap into those wires.
  20. Jul 15, 2025 at 10:59 PM
    #110
    Edwin8484
    Edwin8484 New Member
    Edwin
    25 Tundra Platinum Hybrid TOR
    Hello everyone, looking through this thread and it seems like most of the suggested parts are no longer available. Can anyone help me source what is needed to wire up the OEM switch to an aftermarket light at? I have the switch and light bar with harness that has a relay and 3 wires coming out of it. A white 12v hot a blue return hot and a black ground wire. Where do I source the female plug for the switch? What else is needed to make this work and if possible dimmable. Thank you all in advance.
  21. Jul 16, 2025 at 5:52 AM
    #111
    kjinxx2
    kjinxx2 New Member
    All you need is:
    - the connector female connector (you will have to learn how to crimp the female terminals onto wires that go into the connector) - the connector from corsa comes with the terminals. You can also buy the pre crimped wires from eBay as described in the PDF
    - self locking relay - also available still
    Also probably want to put the self locking relay in a weather proof project box
