TRD Pro light bar Switch P/N
Discussion in '3rd Gen Tundras (2022+)' started by Buellride, Nov 26, 2022.
  1. Mar 22, 2023 at 4:57 PM
    Cdunner
    Cdunner New Member
    2023 White Sequoia SR5 TRD Off-road
    My dealer was able to find the oem part number but is unable to order.
  2. Apr 25, 2023 at 9:08 AM
    Cdunner
    Cdunner New Member
    Anyone have luck finding the oem switch?
    Apica likes this.
  3. Apr 25, 2023 at 1:46 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    Any idea what plug goes into the switch?
  4. Apr 25, 2023 at 2:08 PM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    If I had this part I would dissect it to figure it out.
    Cdunner and ryanwgregg like this.
  5. Apr 25, 2023 at 7:32 PM
    Cdunner
    Cdunner New Member
    I just ended up ordering one off of Aliexpress for $5.
  6. May 6, 2023 at 9:14 AM
    Cdunner
    Cdunner New Member
  7. May 9, 2023 at 2:22 PM
    Cdunner
    Cdunner New Member
    I wonder how many they got
    ryanwgregg likes this.
  8. May 9, 2023 at 3:59 PM
    KClav
    KClav MGM Limited
    2022 Tundra Limited CM MGM TRD OR
    Mine was ordered on April 13 but haven’t been notified of it being shipped
  9. May 17, 2023 at 9:38 AM
    Cdunner
    Cdunner New Member
    Thanks for the leg work. Momentary switch huh.
  10. May 28, 2023 at 11:04 AM
    BaronG
    BaronG New Member
    PT45A-34220-AA
  11. May 28, 2023 at 11:09 AM
    BaronG
    BaronG New Member
    Bro any update? WAs hoping you could post a picture of wiring from back on the switch
  12. Jul 15, 2023 at 1:35 PM
    KClav
    KClav MGM Limited
    Finally got around to figuring this out. Wired the OEM TRD Light Bar switch PT45A-34220-AA to a 20” Heretic Studios light bar. Had to use a couple relays and buy the connector with some wire terminals for the switch to “plug into”.
  13. Jul 15, 2023 at 2:08 PM
    KClav
    KClav MGM Limited
    I’ll do a write up of how I did it. The OEM switch was the most expensive part.
  14. Jul 16, 2023 at 6:07 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Anyone find a switch that fits where the manual headlight adjust switch is? My only blank.
  15. Jul 16, 2023 at 8:09 AM
    jaywj39773
    jaywj39773 New Member
    Hello Guys i'm a new memeber and Tundra owner.
    Was you guys able to figure out the connection plug to the TRD PRO OEM Lightbar switch (PT45a-34220-aa)
  16. Jul 16, 2023 at 10:46 AM
    ohdannyboy
    ohdannyboy New Member
    Attleboro , MA
    2023 Tundra SR5
    Good work! Can’t wait to find out what you used in that write up of yours
  17. Jul 16, 2023 at 11:11 AM
    jaywj39773
    Has anyone been able to get the OEM TRDPro Light bar to work?
  18. Jul 16, 2023 at 11:16 AM
    ohdannyboy
    Attleboro , MA
    2023 Tundra SR5
    I don’t think so. The past couple of posts have been integrating the OEM light switch with an aftermarket light bar. From what I’ve read, the OEM light bar is Can-Bus
  19. Jul 16, 2023 at 11:25 AM
    jaywj39773
    Yea, I think i'm going to return the OEM light bar and grab a Baja Design light bar.
  20. Jul 16, 2023 at 6:52 PM
    #50
    KClav
    KClav MGM Limited
    Attached is my write up of this install.
  21. Jul 16, 2023 at 7:20 PM
    #51
    jaywj39773
    Thanks Bro for posting this.
    forzamrit and KClav[QUOTED] like this.
  22. Jul 17, 2023 at 8:49 AM
    #52
    bballjames
    bballjames New Member
    Inland PNW
    22 Tundra Platinum 4x4 Hybrid Crew Max 6.5ft bed
    That was a fantastic write up. I have automatic running boards, so that switch spot isn’t open on mine. I ended up using the Rave switch. I don’t love it, and of the two I ordered, one was defective, but it’s fine.
  23. Oct 17, 2023 at 6:42 AM
    #53
    Xlocdnguyen
    Xlocdnguyen New Member
    Loc
    Houston,TX
    2023 Black Tundra SR5 Off-Road
    TRD Front Grille
    Thank you for the write up! Going to order the parts and see if I can’t make it myself. Ever thought about selling the harness?
  24. Oct 18, 2023 at 8:12 PM
    #54
    KClav
    KClav MGM Limited
    Never considered it. The crimping tool is expensive, probably cost prohibitive. That’s why I bought the terminals precrimped to the wire. Tried it myself the first time and didn’t have the right tool
  25. Nov 6, 2023 at 1:51 PM
    #55
    Notanother_trdpro
    Notanother_trdpro New Member
    2023 tundra limited 4x4
    Total chaos uppers/rear links, king IBP 3.0’s
    I’m trying to use an oem button to control my Baja designs light bar, I have the button and the wiring connector. I’m not sure what wires on the BD harness(2 red 1 black)go into which spots on the connector(6 pin).
  26. Nov 9, 2023 at 1:19 PM
    #56
    KClav
    KClav MGM Limited
    Do you have the OEM 'TRD Pro Light Bar' switch as noted previously in this thread or another button?
  27. Nov 25, 2023 at 8:08 AM
    #57
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I really, really appreciate this write up and I’m about to attempt to make my own harness to do the same.
    a couple questions if you don’t mind:
    1. Coming off the TRD switch, the pin12 to the outer mirror #6 pin; is this ignition/switched power or constant power? Wondering if I can also tap in the TRD running lights on heritage grill here as well if ignition power
    2. Are you able to use your lightbar at the same time as headlights are on with high beams?
    3. Where did you end up tucking the project box?
    4. Just to confirm you have a power wire from the 30-pin relay to the self-locking relay with a wire spliced into the input and output of the self-locking relay (creating basically a jump) to the fuse to the positive battery, correct?
  28. Nov 25, 2023 at 10:07 AM
    #58
    KClav
    KClav MGM Limited
    1. The outer mirror is not constant power, it is switched (or at least it is on my Limited). The power to those switches is very minimal, the wire size has to be a#26ga or so, so not enough to handle running much load at all.
    2. I am able to use the light bar independent of anything. It can come on with high beams, fogs, etc., it is completely separate from any other lighting, it can be turned on/off even when the truck is not running.
    3. I tucked the project box left above the brake pedal (this is essentially just behind and slightly below the switch). There's quite a bit of room up there. I left some slack in the wires to work with the box on the floorboard and then tucked it up out of the way when I was done. Part of my note #14.
    4. Correct, it's basically jumped to the fused side of the battery (+). The splice is before the input and output because the wire size wouldn't fit into the terminals on the self locking relay, see my notes #10 and #11.
  29. Nov 25, 2023 at 10:10 AM
    #59
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Perfect, thank you very much for the info
  30. Dec 29, 2023 at 7:27 AM
    #60
    shocker88
    shocker88 New Member
    2024 Tundra Platinum Hybrid TRD off road+ TRD 3" Lift (MGM)
    amp research power running boards, method wheels 18x9, toyota dashcam, TRD skid plate, vent shades, bed step, toyota swing storage boxes rear, voodoo blue tundra inserts front and tailgate; Future mods: TRD PRO fender flares, bumper cover, ditch lights, TRD pro Grill, and tail gate lights, light bar upper and lower, Covert front bumper, retrax cover
    Worked great. I am a little mad at myself for not finding this sooner as I had purchased another trd light bar switch that was $60 vs this on that I used since wanted to maintain the wiring diagram.
    I found power in fuse box as on my hybrid the battery is under back seat, also hid the box behind the plastic side snap in panels top of fenders under the hood. Works great thanks for your right up wouldn’t have been able to get it done so easily without it.
    I did notice the switch in the instructions is little more white in back light vs others in my 2024 I didn’t try the $60 switch to compare but will some other day. But still looks and works great. Thanks again for the awesome right up.
    KClav[QUOTED] and Goobax like this.
