Timing belt replacement 'sticker'
Discussion in '1st Gen Tundras (2000-2006)' started by djm68, Jul 15, 2025.
  1. Jul 15, 2025 at 10:39 PM
    djm68
    djm68 [OP] New Member
    Dom
    When looking to purchasing a 1GT, what 'proof' do you look for to ensure they used an OEM part? My research suggest the OEM is the only acceptable replacement part.
    I found this on a 1GT I looked at recently. Trying to educate myself.
    Thanks!
    Bought2Pull likes this.
  2. Jul 16, 2025 at 12:24 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
  3. Jul 16, 2025 at 4:01 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    For what it's worth, that is the same exact sticker the dealership used when my timing belt was replaced a few years back.
  4. Jul 16, 2025 at 4:14 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    I have the big blue square Aisin one.
    djm68[OP] likes this.
  5. Jul 16, 2025 at 4:22 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    That sticker comes in Toyota timing belt pkg.
  6. Jul 16, 2025 at 6:34 AM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    The Aisin sticker is 'The sticker' I look for. If it is not one of those, may not be OEM. Of course, even if they did use Aisin, the sticker could have come off and they replaced it. You really want to see a receipt for the parts.
    Also, other stickers can just be bought off eBay.
    However (and this is just my PERSONAL opinion), even with an Aisin sticker, without a receipt showing a qualified shop doing the work, I'd always be wary. It's quite a long job and the DIY'er may not know exactly what they are doing or may cut corners as thet are running out of time and it's their daily driver.
  7. Jul 16, 2025 at 7:39 AM
    Only a quick PSA or note to say: The presence of that sticker is not concrete evidence you're good-to-go with the timing belt. The sticker (or replicas) can be purchased online if you look in the right place. Not only that, but as Bubba shows above, someone can simply buy an OEM belt to get the sticker too, there's no guarantee they also replaced the tensioner, pulleys, water pump, etc. so potentially a partial job. Always loosen a timing cover to at least inspect for chafing/cracking/oil-staining/coolant-residuals/etc.
    The Black Mamba likes this.
  8. Jul 16, 2025 at 6:02 PM
    Coastal_Tundra
    Coastal_Tundra New Member
    2003 5vzfe 5spd manual 2wd
    Pop the cover and put eyes on the belt. Fastest way to figure out how paranoid you should be. ...Also like shifty says, just cause there's a sticker doesn't mean any work was done. Similarly, just because work was done doesn't mean it was done right. And just a note, the actual belt that comes with the Aisin kit is a Mistuboshi, which I think is the OE supplier.
  9. Jul 18, 2025 at 9:26 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    OP,
    If you buy the truck, just go on and get the belt, pulleys, tensioner, water pump, radiator, etc. plus lower ball joints replaced immediately anyway. That's what I did. In fact, I was so OCD I parked my truck the day of the buy and had it roll backed to a stealership for exactly that (plus a lot more).VideoCapture_20250320-154434.jpg
    I was just too scared to try and drive it down there. Could you imagine losing your engine on the way to the shop?
    (My truck had no stickers, no receipts, and no logbook of maintenance. I'm the 7th. owner).
    Rsmallw2 and djm68[OP] like this.
