Toyota OEM TRD Front Recovery Hooks
Discussion in '3rd Gen Tundras (2022+)' started by RatPanda, Nov 12, 2024.
  1. Jul 7, 2025 at 9:59 AM
    #421
    G8Santini
    G8Santini New Member
    25 Tundra SR5, 4x4, PremCnv, Blackout, TRD 3”Lift, 20”TRD rims
    Cat back TRD exh, Heritage grille, fog lights, 35x12.5x20” Nitto, low profile toolbox
    Possibly you’re correct. My perspective is the bolt itself will be the weak link if tow hook was overstressed. My Toyota bolts were marked as a Metric Class 10.9 (around same as SAE Grade 8) hardened bolt, and they’re mounting into the crossmember with a bunch of thread.
    When I look at how I expect the torque of a straight forward pull will be, most stress would be on the rear bolt. It appears as a strong mount as the TRD sway bar spacer is substantial and a welded box, and the bushing and sway bar are ‘in between’ & are going to prevent the crush. Have know idea how these AFE might work with another brand suspension lift. I will add that purposefully used a floor jack right after I installed on each hook to test, and saw zero issues. They’re on solid.
    I don’t see using these but for pulling a rolling vehicle out of a pickle, or occasionally dragging downed tree off our road. IMG_7389.jpg IMG_7387.jpg
    MAC25Tundra and Calif-Tundra like this.
  2. Jul 7, 2025 at 10:01 AM
    #422
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    The skid plate has a small tab on the driver side at the rear mounting position (where the cat shield is). Assuming this was bent flush for yours? Reason I ask is I have the same cat shield and noticed it would be a slight problem when I got under there but glad to see the bolts were at least long enough on the cat shield to use at the rear of the skid plate
  3. Jul 7, 2025 at 11:09 AM
    #423
    Observer
    Observer New Member
    Hey G8Santini. Your set up looks good! In no way was my observation meant to undercut your install. When I ordered my AFE hooks my thinking was this is not the best set up as the front bumper on these things gets in the way but in a pinch it was better than nothing, which is what someone at Toyota decided to give to us. I'm by far not the sharpest pencil in the bunch but sometimes when I look at some of the things Toyota added and left out I find my self wondering "What the hell were they thinking". :confused:
    Calif-Tundra likes this.
  4. Jul 7, 2025 at 11:17 AM
    #424
    G8Santini
    No problem. I was also worried about the AFE install.
    Different subject, but as risk adverse as Toyota seems, I’m amazed they are selling the new Tundra tow hook mod. Seems like it would affect the crash absorption front bumper/facia.
  5. Jul 7, 2025 at 11:24 AM
    #425
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I can tell you that it has no effect at all in my accident. They will actually fall off if theyre pushed in (Front impact accident). They actually fell off in my case with the "swipe" impact in my video.
  6. Jul 7, 2025 at 4:10 PM
    #426
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Any spacers involved? I have the Gulf States cat shield. However, no hardware. I assume the longer bolts are the ones that go towards the rear of the truck?
  7. Jul 7, 2025 at 4:56 PM
    #427
    G8Santini
    No spacers on TRD skid plates I’ve installed. Those long black bolts with smooth head look like cat shield security bolts. TRD skid.plates I’ve done used normal head bolts on rear location - like the 2 bolts to the left in your pic.
  8. Jul 7, 2025 at 5:30 PM
    #428
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    So is that tab I pictured flattened down or did you remove it?
  9. Jul 7, 2025 at 8:31 PM
    #429
    G8Santini
    The tabs are used to ‘hang/hold’ the skid plate while you’re positioning it to install. The front holes on the skid plate have elongated slots so you can loosen the front bolts, leave them in, and shift the panel to unsecure it. So those rear hooks hold up the rear of the skid plate once the rear bolts are removed. IMG_0582.png You’re probably removing it every time you do an oil change
  10. Jul 7, 2025 at 8:53 PM
    #430
    G8Santini
  11. Jul 7, 2025 at 9:39 PM
    #431
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I’m aware of what the tabs are for but there’s no way to have the rear tab (pictured in my photo) lock in if you have the OEM GC cat shield. Hence the question, what did you do to the rear mounting tab on the skid plate?
  12. Jul 7, 2025 at 11:03 PM
    #432
    G8Santini
    I didn’t do anything to the tab. Left it intact. Sounds like you may need to knock yours flat w/hammer.
  13. Jul 11, 2025 at 5:24 PM
    #433
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    :worthless:
  14. Jul 11, 2025 at 5:27 PM
    #434
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    Very high quality! I was about to ask if you hired a professional!!! lol
  15. Jul 11, 2025 at 5:40 PM
    #435
    Johnny89
    Johnny89 New Member
    Friday
    Glad you noticed! Didn’t think you’d recognize quality if it hit you.
  16. Jul 11, 2025 at 5:41 PM
    #436
    az 3rdGen
    Arizona
    woah... watch the shade. I wasn't the one who missed the pic.
  17. Jul 15, 2025 at 11:38 AM
    #437
    Demar002
    Demar002 New Member
    Frank
    2022 Toyota Tundra
    Can anyone comment on the cost to have the OEM recovery kit installed by toyota
  18. Jul 15, 2025 at 1:04 PM
    #438
    sudobash
    sudobash New Member
    Best to call your dealer and ask them what they'd charge.
    eddiefromcali likes this.
  19. Jul 15, 2025 at 1:07 PM
    #439
    eddiefromcali
    Eddie
    100% Stock
    this...prices vary by dealer, seen them from $350-$500+.
    sudobash[QUOTED] likes this.
