2025 Tundra Engine is down!
Discussion in '3rd Gen Tundras (2022+)' started by Tarikah, Jun 26, 2025.
Thread Status:
Not open for further replies.
  1. Jul 14, 2025 at 5:06 PM
    #691
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Or, the stacked tolerance evaluation did not cover the manufacturing flow extremes.
    PermaFrostTRD[QUOTED] likes this.
  2. Jul 14, 2025 at 5:51 PM
    #692
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    No, We know motors are being replaced because of a bearing failure. The symptom is a knocking motor lol
  3. Jul 14, 2025 at 5:58 PM
    #693
    PermaFrostTRD
    Northern NY
    Wrong again. Plenty of failures that happened without “knocking”.
  4. Jul 14, 2025 at 6:09 PM
    #694
    Breathing Borla
    Northern Illinois
    Good lord boys, do we even know what we are arguing about ? Lol
  5. Jul 14, 2025 at 6:15 PM
    #695
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
  6. Jul 14, 2025 at 6:34 PM
    #696
    LionsFan20
    Josh
    24 Tundra
    Well the sky isn’t technically blue either….the motors knock, or seize from a bearing failure. The symptom is the knocking or locked up….is that better.
    sudobash likes this.
  7. Jul 14, 2025 at 6:37 PM
    #697
    sudobash
    sudobash New Member
    Are they the Teenage Mutant Ninja kind?
    GODZILLA and AZBoatHauler like this.
  8. Jul 14, 2025 at 6:49 PM
    #698
    AZBoatHauler
    So.Arizona
  9. Jul 14, 2025 at 6:52 PM
    #699
    PermaFrostTRD
    Northern NY
    Toyota’s ambiguity continues to be justified
  10. Jul 14, 2025 at 6:57 PM
    #700
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    That's the only kind
    sudobash[QUOTED] and GODZILLA like this.
  11. Jul 14, 2025 at 7:47 PM
    #701
    yakeng
    yakeng 3URFE Apologist
    Stacked tolerances is something I’ve been dealing with consistently as an engineer as we push the envelope for efficiency. I don’t think this is something that is well taught in engineering anymore, if it at all. I wouldn’t be surprised if that is it.
    sudobash and PermaFrostTRD like this.
  12. Jul 14, 2025 at 9:21 PM
    #702
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Relatively recent mechanical engineering grad here. University of Colorado didn’t really touch on tolerance stackups. Only a tiny bit in my senior design class. It’s much more complex than it seems when you have so many components working together. I remember thinking “oh well you just min max the tolerances” but I didn’t consider pin/hole clearances until I had to do a stack up at work. Now, add in rotating assemblies with harmonic frequencies / non-straightness across bearings… that’s when it probably becomes FEA time using different high/low tolerances… but if you make one wrong assumption, you could be missing something huge. Add in time constraints, lack of resources during covid, confidence/reliability calculations, and of course money. There could’ve been an assumption/calculation made long ago that hasn’t been questioned yet.
    sudobash and raylo like this.
  13. Jul 15, 2025 at 12:07 AM
    #703
    C150 driver
    C150 driver New Member
    2024 Tundra TRD OR
    Lol, what are you talking about? That wouldn’t solve a main bearing failure due to contamination. You would see an upper rod bearing failure and piston/cylinder damage if the actual tune was the problem, multiple people have posted pics of their spark plugs at the 40k interval change and they look perfect. You’d see damaged spark plugs if the tune was an issue. Stop peddling nonsense. Also multiple videos showing the engine swap being done on YouTube, you wouldn’t need to swap the ecu, just upload new software. Modern engines have knock sensors, the ecu would pull timing on its own if it sensed any pinging or misfire. Modern engines will literally go into a limp mode annd self limit if any misfire is detected for a certain period. This was demonstrated when people installed the TRD intakes without the performance tune. The truck went into limp mode and wouldn’t make power, every word of what you posted is just flat wrong.
  14. Jul 15, 2025 at 4:12 AM
    #704
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
  15. Jul 15, 2025 at 5:49 AM
    #705
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    you haven’t been paying attention to the engine tear downs or this thread have you?
  16. Jul 15, 2025 at 5:55 AM
    #706
    C150 driver
    2024 Tundra TRD OR
    Yes I have, none of the failures indicate an issue with the tune. The rod bearing issue would be secondary to piston/cylinder damage. Once again you don’t know what you’re talking about. The majority of the issues are spun main bearings, from the oil system being contaminated, specifically main bearing number 1. The contamination has caused spun and damaged rod bearings, but where is the cylinder and piston damage? All I’ve seen is excessive skirt damage from metal being in the oil system, no damage to piston crowns, no metal missing from the combustion chambers, zero indication of detonation and pre ignition. The reason some engines have main bearing failure and some have rod bearing failure, is get this, machining debris being left in seemingly random areas of the oiling system, just like Toyota said.
  17. Jul 15, 2025 at 6:38 AM
    #707
    2wheelsforfun
    2wheelsforfun New Member
    Foothills AB Canada
    Not being an engineer, I went down the "stacked tolerance" rabbit hole and I believe I now have the definitive answer as to why the V35A is blowing up. Toyota is using AI to design their motors. That's it, we can all quit trying to figure it out. Your welcome, now go drive whatever truck you own, to your favorite past time.
    Seriously though, as I was reading and trying to understand the principles behind the tolerance thingy, I was thinking that I have always had (and especially since Covid) a rather healthy skepticism towards "modelling", and how flawed it truly is. Think "climate" modelling etc.
    And how engineering has become I would suspect increasingly dependent on modelling. Not all models are bad or inherently wrong and without it, you engineers would have a hard time designing the crazy things we get to enjoy in our daily lives. But my skepticism comes from maybe young, inexperienced engineers blindly trusting their modelling software without ever really knowing what it is calculating behind the scenes, and never questioning the results they are seeing.
    It's a long time ago, but we weren't allowed to use calculators in school until we could prove through testing that we knew long division etc. Modelling use today is taken to the extreme of that example but the principle applies.
  18. Jul 15, 2025 at 8:01 AM
    #708
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Agreed. Especially since the real world difference between the two is 3mpg and they went with lighter/narrower tires on the new truck (265/70R18).
  19. Jul 15, 2025 at 8:26 AM
    #709
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    I wonder how many of these engines were put through dynamic testing in their development? I would have to assume in the hundreds. This would be the step used after modeling was taken as far as it could in order to validate the variables and constraints used in the model.
    Deficiencies in either the design or part fit up (stack up tolerances) should have been addressed. I am now of the belief this really is an assembly issue, especially if human hands get in there.
    Matt2015Tundra and sudobash like this.
  20. Jul 15, 2025 at 9:10 AM
    #710
    DFS
    DFS New Member
    2022 Capstone Tundra
    Can probably all be traced back to GD&T issues, ASME Y14.5 has introduced a series of problems when interfacing between design, implementation, and manufacturing because it's a different language altogether. I run into issues with it weekly. Great concept, implementation has led to some major issues.
    chrisgibbs707 likes this.
  21. Jul 15, 2025 at 9:39 AM
    #711
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    For those not jumping between two threads; went and saw my truck today; motor is torn down, it was a #5 bearing failure.
    In complete contrast to what my service writer told me last Thursday, I'm not getting a whole motor, it's simply the short block and timing cover (and gasket set, and oil filter, and oil, and coolant). All parts arrived last Thursday, and the best timeline the service manager could give me today was that it would be ready "sometime next week". Also, since it's Tuesday... Happy 3 weeks since I last drove my 10 day old truck!
    WNY PAT, BlackNBlu, hagrid and 5 others like this.
  22. Jul 15, 2025 at 9:45 AM
    #712
    #5?? Sooo..... rod bearing, not crank bearing correct?
  23. Jul 15, 2025 at 9:46 AM
    #713
    sudobash
    sudobash New Member
    So it was a rod bearing failure then. Interesting.
  24. Jul 15, 2025 at 9:46 AM
    #714
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    Correct... The block was pushed to the side and honestly I didn't peak in and take a good look, but the crank was still in place when he pointed
    woods and sudobash like this.
  25. Jul 15, 2025 at 9:50 AM
    #715
    sudobash
    sudobash New Member
    Hmm. Interesting.
    @yakeng and @chrisgibbs707 may be onto something with the stacked tolerances.
    @G3ardnut - This is a question that needs to be answered. There is no way that they didn't experience failures during the development and testing of this engine.
    @2wheelsforfun - This has been a thought in private discussions with engineers. Reminds me of Ford v. Ferrari. The yarn test for downforce and lift.
  26. Jul 15, 2025 at 9:55 AM
    #716
    WindChillYeti75
    WindChillYeti75 New Member
    2025 WCP Limited TRD Off Road iForce Max
    So should the rest of us 2025 owners be concerned then still? Lol or do you think this incident was a one off thing?
    sudobash[QUOTED] likes this.
  27. Jul 15, 2025 at 10:09 AM
    #717
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    @sudobash you may be able to speak to this... What's the reason the front timing cover (11310-F4010) is replaced in this process?
  28. Jul 15, 2025 at 10:13 AM
    #718
    jctmundra
    Northern VT
    Appears the "replace everything oil touched" does not apply here?
  29. Jul 15, 2025 at 10:14 AM
    #719
    LionsFan20
    Josh
    24 Tundra
    they will replace that because oil passes through it
  30. Jul 15, 2025 at 10:17 AM
    #720
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    Not even close :mad:
    Although, in speaking to the Toyota brand engagement rep today, and expressing my continued disagreement with just the short block, I pushed the fact that there is precedent for those with similar failures to have the short block done, and then very shortly there after, going back for another motor presumably due to debris still residing elsewhere... She agreed without hesitation that that's true
Thread Status:
