  1. Jul 11, 2025 at 7:30 PM
    Toklas
    Toklas New Member
    2023 limited TRD OR CM short bed blueprint
    Thanks kept it simple, it's a snake knot. Only a bit at the top so the rest would be flexible.
  2. Jul 11, 2025 at 8:33 PM
    OrdsTOY
    OrdsTOY New Member
    25 Tundra Limited
    TRD Package
    I just read somewhere to be aware of the fakes on Amazon.
    Thanks for the link. I'll definitely take a look at these. I was just going to fab something, but having something already done is nice!
    mach1man001[QUOTED] likes this.
  3. Jul 12, 2025 at 10:51 AM
    CappyKD
    CappyKD Older, grayer member.
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    I put my Tufskinz raised Grille emblems on.
  4. Jul 12, 2025 at 12:13 PM
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    nice little addition
    CappyKD[QUOTED] likes this.
  5. Jul 12, 2025 at 2:26 PM
    R1Style_
    R1Style_ New Member
    ON Canada
    2025 Tundra TRD Rally
    Has anyone tried mounting an aftermarket camera in the blank space by the third brake light? Where the higher level trim models have them installed...??
  6. Jul 12, 2025 at 3:59 PM
    Daedalus
    Daedalus New Member
    Added in the spacer for the cornfed kit I left off during the spring perch install.
    (ride quality improved significantly)
  7. Jul 13, 2025 at 12:11 AM
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    I have the uhd box, it works but doesn’t retain settings when I turn off the truck. If you move icons they go back to default. Apps you download do remain . Just kind of a pain that it doesn’t remember
  8. Jul 13, 2025 at 12:45 PM
    bailey bulldog
    bailey bulldog New Member
  9. Jul 13, 2025 at 2:56 PM
    Foolishfrog
    Foolishfrog New Member
    Mitch
    2024 6.5 Pearl Platinum for towing camper
    There are those here who have done this more snazzily than I did, but this is the first mod I did to my Platinum. Ran a 12 gauge wire from the pass side fuse panel, snuck a NAPA 12 V outlet in a bed slot for protection. On my truck one could just lay on the floor under the truck and see right up under there to wire it up. (Fire extinguisher for scale!?!) (Actually the only pic of the outlet I had)IMG_6991.jpg
    60centenergy, kirkb and CappyKD like this.
  10. Jul 13, 2025 at 3:07 PM
    Foolishfrog
    Mitch
    I upgraded my bed storage system from the amateurish wire method I started with. Amazon tool holders and aluminum brackets machined from Home Depot stock.
    Before:
    After:
    (The paint tool is for pulling stuff from the front to the back without climbing in. Repurposed when I retired from commercial bus driving. Used it there to pull bags out of the luggage bays.
  11. Jul 13, 2025 at 4:02 PM
    drewpweinerMD
    Jeremy
    2024 Limited TRD OR
    So good. This is my next color.
  12. Jul 13, 2025 at 7:41 PM
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Finally got around to installing my AJT oversized cupholders and an orange start button ring since I have some other orange bits inside my truck. No broken clips, didn’t have to disconnect any wiring. Life is good.
  13. Jul 13, 2025 at 8:17 PM
    G8Santini
    G8Santini New Member
    25 Tundra SR5, 4x4, PremCnv, Blackout, TRD 3”Lift, 20”TRD rims
    Cat back TRD exh, Heritage grille, fog lights, 35x12.5x20” Nitto, low profile toolbox
    I added some tool box lights today. Inside the tool box lid added LEDGlow 2pc white led lamps off of Amazon. I wired it from the Toyota accy bed light harness that was bundled under the bed. The kit offers a accy switch & magnetic door opening switch option, but I hard wired the lights to come on when the bed lights come on from door or tailgate opening. The mounting base has 3M tape and cut at a 45 degree angle so they give some bed lighting, but do a great job of illuminating the inside of the tool box.
    Also added 2 bed lights just under the tool box latch. They’re from Harbor Freight and $29/pr. Really liked that they’re armored up a bit and the housing made of aluminum, & mounting on a rubber mount. Comes with a flat mount & curved for rollbars, I used the flat on the outside, and inside sandwiched the curved behind the locknuts as a spacer to prevent gear from snagging on bolts. I put all these lights on the same circuit. When you open a door the cab cargo light comes on, along with factory bed lights, new rear facing bed lights & tool box lid light. Makes the bed very usable at night.
    I thought it worked out pretty well!IMG_0600.jpg IMG_0601.jpg IMG_0603.jpg IMG_0605.jpg IMG_0608.jpg IMG_0612.png IMG_0611.png
  14. Jul 14, 2025 at 3:33 AM
    60centenergy
    60centenergy I'm not superstitious, but I am a little stitious
    Zack
    GVL
    ‘24 Lunar Rock SR5 TRD Sport
    I’ve got mine in the box from AJT waiting for a good time to install. Looks good!
  15. Jul 14, 2025 at 4:27 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Agreed.
    But reversed color order (red over yellow) is the way, even if it's technically wrong. :D
    Especially with the red "TRD".
    (See avatar pic)
    Bulldog6 and CappyKD[QUOTED] like this.
  16. Jul 14, 2025 at 6:06 AM
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    Technically yesterday but it was interior TLC day. Ironically, while giving some TLC, I knocked my radio knob off. Just shy of 30k and nothing but super soft usage over two years. Does anyone know if that part has been improved from Toyota, or should I just get a 3rd party knob?
  17. Jul 14, 2025 at 6:16 AM
    CappyKD
    Kirk
    I went back and forth and decided to go with the technically correct order. I do like the look when reversed as well. I think it will look better once I do the Tufskinz raised matte black and red outline Tundra in the valance.
    BlackNBlu[QUOTED] likes this.
  18. Jul 14, 2025 at 7:52 AM
    G8Santini
    Few daylight pics
    astrength22 and CappyKD like this.
  19. Jul 14, 2025 at 9:02 AM
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    The new knob seems to be more robust. It doesn't flex like the original, when trying to move it side to side. I've got a 3rd party in my console, if the new one breaks, I took off when they put the new OEM on.
  20. Jul 14, 2025 at 9:49 AM
    astrength22
    astrength22 New Member
    2023 Silver Tundra Platinum
    My first knob broke at 35K. Ordered OEM replacement, P/N: 86128-AN020 for $9. It is definitely redesigned and WAY better. Don't expect it to break again, I would be surprised if others are experiencing that.
  21. Jul 14, 2025 at 11:09 AM
    g4waldo
    Thanks. I went ahead and opened the wallet for the AJT knobs, mostly as an excuse to add some red highlights. I might still ask the dealer to replace it with OEM since it's almost due for the 30k service so I have a spare.
  22. Jul 14, 2025 at 11:29 AM
    astrength22
    I want to do the AJT radio+ drive mode knobs, shifter, oversize cupholder kit, center console panel, etc. all with the blue screws to match the platinum interior, but seems a little ridiculous to spend ~$500
    CappyKD likes this.
  23. Jul 14, 2025 at 12:52 PM
    Toklas
    Toklas New Member
    I'm doing just that, but spacing out the purchases. already did the center console swap and the cup holder a while back. today the 2 knobs should be arriving. I did go with the yota expedition versions as i wanted to add a little more visual change witht the topo engraving on the knobs. I'll post some picks if/when they arrive.
  24. Jul 14, 2025 at 1:04 PM
    CappyKD
    Kirk
    I agree on the wanting something more, though I like the look I'm not so sure that I will go down the AJT rabbit hole with this build yet. (I did on my 21 Tundra) For now I'm going to go this route:
    https://www.tufskinz.com/collection...tun091-drive-mode-selector-dial-toyota-tundra
    I may just rock the stock knobs until they break off. There are too many other mods to spend money on.
  25. Jul 14, 2025 at 1:55 PM
    Toklas
    Toklas New Member
    heh, yeah the suspension/wheel/tire/roof rack/front and rear bumper/light bars/accessory panel/bed cover or rack or both/audio upgrade fund is a bit thin.
    CappyKD[QUOTED] and astrength22 like this.
  26. Jul 14, 2025 at 6:53 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Worth it ...
    Screenshot_20250714_204516_Gallery.jpg Screenshot_20250714_204541_Gallery.jpg Screenshot_20250714_204636_Gallery.jpg Screenshot_20250714_204716_Gallery.jpg
  27. Jul 14, 2025 at 7:39 PM
    mrlittlejohn
    mrlittlejohn New Member
    Michael
    2022 Toyota Tundra Limited
    I took mine into the shop to replace the SOS module in the overhead console. It has been giving random "communication module failure" messages on me and would never do it at the dealer. Except when I had it in last week, when I went to leave, it did it 4 times in a row. The service advisor observed it twice. It has not done it since. The part came in and I am looking forward to ending that issue.
    chrisgibbs707 likes this.
  28. Jul 15, 2025 at 7:29 AM
    mikev25
    mikev25 New Member
    Kansas
    2022 MGM SR5
    TRD lift, wheels, tires, AlphaRex headlights
    Finally got my Form Lighting taillamps in. Went with smoked, and then blacked out the red "C" reflector on each side just to add a little touch and reduce the amount of red. Love the additional reverse light that these add, as well as the complete plug-and-play sequential animation.
  29. Jul 15, 2025 at 8:56 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Looks good on the dark grey. Glad I went smoked as well. Took a while for me to adjust to it but happy with the purchase
    mikev25 likes this.
  30. Jul 15, 2025 at 11:08 AM
    Daedalus
    Daedalus New Member
    Can confirm, Tundra does good donuts.
