OTT Tune for stock NA Tundra
Discussion in 'Performance and Tuning' started by nasher75, Nov 1, 2023.
  1. Jun 5, 2025 at 7:45 AM
    #91
    armygreentundra
    armygreentundra LIVIN'
    Desert SW
    2021 TRD Pro MGM
    Dirty Deeds TRD Replacement
    Wanted to chime in since it's been silent here for a bit to give a shout out to John Brewer in Albuquerque for tuning my 2021 yesterday. The tune definitely woke the truck up, shifts make more sense, and it chirped the tires, where before at the same throttle input, it never would have. That caught me by surprise. This has really made the truck more enjoyable to drive.
    DPF88130 and JustDSM like this.
  2. Jun 7, 2025 at 3:44 AM
    #92
    steezy
    steezy New Member
    2021 Tundra TRD Pro
    @JustDSM is Kaleb still the only option for Houstonians? That’s what it says on your website, but you had indicated otherwise on here.
    Waco is pretty inconvenient, and I’d assume there’s a shitload of 4Runners, tacomas and Tundras/200s in Houston…
    LonestarYotaTuning and JustDSM like this.
  3. Jun 7, 2025 at 9:34 AM
    #93
    JustDSM
    JustDSM New Member
    Justin
    Kaleb does travel and I believe he has an affiliate there in the Houston area.
    I've made him aware of your inquiry, and he should be in touch shortly. If he hasn't yet, you can coordinate with him by:
    Phone: (254) 301-5965
    Email: lonestaryotatuning@gmail.com
  4. Jul 11, 2025 at 11:17 AM
    #94
    Boneskull420
    Boneskull420 New Member
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Looking to have the ott tune done, Anyone have any experience with the OTT tune specifically the spicy/extra spicy....(I think) settings compared to the medium/spicy settings and drivability? Speed and fuel mileage isn't a big issue just wondering how much of a difference there is and others opinions! Thanks in advance also mine is N/A not supercharged
  5. Jul 11, 2025 at 11:44 AM
    #95
    nasher75
    nasher75 [OP] New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    I think you will quickly find that the throttle response from a stop in 1st gear will be way too sensitive, but you always have the option of going back and asking them to lower it. Even people who chose medium/spicy often went back and asked to have it tamed.
  6. Jul 11, 2025 at 12:00 PM
    #96
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I was one of those people who needed to get it turned down.
    At medium and I would chirp the tires if the intersection was bumpy. Also if I got on and then off the throttle from a stand still like at a slow moving intersection the truck would jerk too much. Went down a setting and the drivability improved considerably.
    I did, however, keep a stronger throttle response when the tow haul mode is active. When towing +7k lbs it's nice and smooth.
    Boneskull420 likes this.
  7. Jul 11, 2025 at 12:37 PM
    #97
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Is there any point doing this tune if I don't want my throttle sensitivity changed?
  8. Jul 11, 2025 at 12:49 PM
    #98
    Boneskull420
    Tn
    Thank you
  9. Jul 11, 2025 at 3:09 PM
    #99
    JustDSM
    JustDSM New Member
    Justin
    There is still a pretty sizable torque increase and shift schedule updates that can improve the calibration even with OE throttle settings.
    Worth it? Everyone’s idea of worth it varies. What are you trying to accomplish with a tune if you don’t want the throttle touched?
  10. Jul 11, 2025 at 3:55 PM
    #100
    blenton
    blenton New Member
    Yes, IMO. The lower mid-range power band (2000-3500 RPM) feels stronger and more responsive. Shifting feels better - the shift is smoother, shifting logic feels smarter and better timed, and it feels like it carries more power through the shift. I'm not talking about WOT shifts only; even puttering around town below 2500 RPM feels much improved. I'd wager it's a combination of minor throttle adjustments and fine-tuning the shift logic, but the end result is fantastic. At least, I felt it was. My throttle settings are somewhere between medium and extra boring on one truck, and I think regular old Medium on the sequoia (but I don't really know as it drives just about perfect compared to the Ok stock tune).
    Boneskull420 and JustDSM like this.
  11. Jul 11, 2025 at 4:29 PM
    #101
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I haven’t read back through, but if a fella wanted a normal “mild/medium” throttle response tune that still nets the other positives, get that. Then add a spicy one in place of the OEM tow/haul mode.
    Assuming OTT’s preferred software works anything like HP, it should be simple. Copy and paste the values into T/H mode and then change the throttle response segments.
    Best of both worlds!
    JustDSM likes this.
  12. Jul 11, 2025 at 4:30 PM
    #102
    Boneskull420
    Tn
    So after reading all the responses one question I have is can you do a tow tune for the normal drive and a spicy drag type tune when you hit the tow/haul button? Or does one tune have to coincide with the next step up? For example can you have a medium tow type tune for normal drive and an extra spicy tune with tow/haul if I'm making any sense
  13. Jul 11, 2025 at 4:42 PM
    #103
    MadMaxCanon
    Looking for improvement in shifting and transmission in general
    JustDSM[QUOTED] likes this.
  14. Jul 11, 2025 at 4:42 PM
    #104
    blenton
    blenton New Member
    Not to answer for Justin, but yes. Some guys do exactly that - regular tune is tame for every day driving, tow haul button switches to a completely different tune/throttle setting for getting rowdy. You could even do the opposite - spicy tune for regular driving, tow haul button to tame it down for low-traction situations like inclement weather or Offroad where throttle sensitivity can be a bad thing.
    JustDSM and Boneskull420[QUOTED] like this.
  15. Jul 11, 2025 at 4:43 PM
    #105
    MadMaxCanon
    This is pretty much what I am looking for, thanks.
    blenton[QUOTED] likes this.
  16. Jul 11, 2025 at 4:44 PM
    #106
    blenton
    blenton New Member
    From personal experience, that was one of the best things about the tune. Speaking with some other speed-parts guys, they say the same thing about OTT - if for no other reason, get an OTT tune for improved transmission shifting.
    JustDSM and MadMaxCanon[QUOTED] like this.
  17. Jul 11, 2025 at 4:52 PM
    #107
    Boneskull420
    Tn
    Thanks for your response, i don't do alot of towing but would like to set it up for tow and go without having to remember to push a button and then set up tow/haul for having fun! I like getting rowdy from time to time, like having a bad day at work and wanting to let the frustrations out:devil:
    JustDSM and blenton[QUOTED] like this.
  18. Jul 11, 2025 at 4:59 PM
    #108
    Boneskull420
    Tn
    I know its no replacement for a supercharger but if it makes normal driving better and opens it up a little at the same time it sounds like a win win to me!
    JustDSM likes this.
  19. Jul 11, 2025 at 7:26 PM
    #109
    JustDSM
    JustDSM New Member
    Justin
    We can configure the drive modes (Normal & Tow-Haul) to be setup however you like. If you were to schedule with us/a retailer of ours, please be sure to mention your specific configuration/setup preferences, as a configuration like what you describe would require us to build it.
    That said, each drive mode can/does have unique throttle, shift schedule, and TCC settings. So you can configure them how you'd like based on how you want to use the truck. It'll probably be easier for us to send you a standard configuration file so you can experience/feel the settings before we go on a science experiment, configuring things in a custom way, and you've not even decided on the final settings yet.
    In short, just let us know when you schedule/order that you'll eventually like things configured a specific way. We'll be happy to work with you once you've settled on your throttle/trans mapping.
    blenton and Boneskull420[QUOTED] like this.
  20. Jul 11, 2025 at 7:53 PM
    #110
    Boneskull420
    Tn
    I understand completely, and I have been talking to Appalachian offroad here in tennessee and will hopefully have somthing scheduled in the next month or so. I have an S&B cold air intake and dual exhaust so from what ive been told I need a custom tune from the get go. He also told me we can set things up one way and try it to see if I like it or if not we can adjust from there. I am looking forward to working with you all!
  21. Jul 11, 2025 at 8:02 PM
    #111
    JustDSM
    JustDSM New Member
    Justin
    Whenever we tune a truck that is fitted with an aftermarket intake, we verify if the MAF needs to be scaled to correct the fueling error that can occur in some aftermarket intakes. Most end up requiring at least a clean-up. Some require a complete rework, but we custom scale each intake/truck combination individually to ensure accurate fueling among other things.
    Appreciate your interest and business!
  22. Jul 11, 2025 at 8:10 PM
    #112
    Boneskull420
    Tn
    I appreciate you taking your time to educate and inform us/me on how the system works:thumbsup:
  23. Jul 14, 2025 at 10:45 AM
    #113
    DPF88130
    DPF88130 New Member
    2018 1794 Edition CMSB
    8 inch lift 37x12.50/20 ARE topper
    I am on the eastern side of the state and have been texting with John to meet up with him in ABQ to have a tune done. what tune did you go with?
