STravis Go Anywhere, Camp Anywhere Build
Discussion in '2.5 Gen Builds (2014-2021)' started by STravis, Jun 28, 2020.
  1. Jun 13, 2025 at 9:25 PM
    #721
    STravis
    STravis [OP] SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    Here is a screenshot of the wire diagram.
    CaptRussia253 likes this.
  2. Jun 13, 2025 at 9:50 PM
    #722
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
    Is it the red/yellow? I hate wiring...
  3. Jun 13, 2025 at 9:53 PM
    #723
    STravis
    Travis
    Ruidoso, NM
    I think the red/yellow is for ignition power when using their provided switch. I think you can bypass the entire harness and switch and run to a spod/switch pro style controller with just a signal wire. Looking at it now I think it's the lt blue wire.
  4. Jun 13, 2025 at 10:00 PM
    #724
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
  5. Jun 13, 2025 at 10:13 PM
    #725
    STravis
    Travis
    Ruidoso, NM
    That's the old style twin and old harness. But looking at the old wire diagram and new diagram the Gen 1 harness goes from purple to red and then ties into the isolator switch at terminal 3 and the Gen two stays red and all the way to terminal 3. I think the red wire is what I need.
  6. Jun 14, 2025 at 8:34 AM
    #726
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Same!
    n0rth[QUOTED] and STravis[OP] like this.
  7. Jun 14, 2025 at 2:39 PM
    #727
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Red is the main trigger for the pressure switch, which if it is under the maximum pressure will power dark blue and turn on the compressor, but, I have no idea what light blue is contributing to the detection pcb. Can you put a multimeter on the main isolation switch and figure out which other pin on the switch has continuity with the light blue wire pin 7? Is it a ground? A power? A switched power? That is the only gap for me right now.
    CaptRussia253 and n0rth like this.
  8. Jun 21, 2025 at 8:10 PM
    #728
    STravis
    Travis
    Ruidoso, NM
    I finally got a legit air system permanently mounted in the truck. I went with the new brushless ARB twin. The compressor is mounted in one of the rear boxes under the bed and then I plumbed in air lines to each wheel and built 4 hose whips to air up and down with. Just a note for anybody in the future, the red wire in the main harness coming from the compressor can be used as the trigger wire for a switch pro style controller.
    PXL_20250619_203304239.jpg PXL_20250621_230840749.MP.jpg PXL_20250621_230624305.jpg PXL_20250621_230628145.MP.jpg PXL_20250621_230636032.jpg PXL_20250621_230632531.jpg
  9. Jul 8, 2025 at 8:58 AM
    #729
    STravis
    Travis
    Ruidoso, NM
    I finally had a chance to get the remainder of the camper insulated. I glued 3/4" foam into the flip up doors and then glued the wood panel to that. I ended up needing slightly stronger struts to keep the doors open with the added weight but a quick call to OVRLND got me the info I needed to get some new ones installed. I also insulated the top of the camper and rear doors but I just glued some indoor/outdoor carpet to those sections of insulation and glued them in.
    PXL_20250624_003647772.jpg PXL_20250624_003650701.jpg PXL_20250624_003640241.jpg
  10. Jul 8, 2025 at 9:04 AM
    #730
    STravis
    Travis
    Ruidoso, NM
    Another change I wanted to make prior to our summer trip was swapping to the snorkel upgrade pre cleaner.
    I want to trim the snorkel just a bit to make the pre cleaner sit just a little lower but that will be an easy change.
    PXL_20250626_231513675.PORTRAIT.jpg PXL_20250626_234611957.PORTRAIT.ORIGINAL.jpg
  11. Jul 8, 2025 at 12:12 PM
    #731
    CaptRussia253
    Ruslan
    Looking good.
    Wife and I were just talking about getting a flatbed and camper to travel more once the kiddos are older. We’re on an Oregon road trip and I keep showing her your build to get the “bank” approval. :rofl:
    Mdl, BreyTundy and RobertD like this.
  12. Jul 8, 2025 at 6:37 PM
    #732
    STravis
    Travis
    Ruidoso, NM
    Nice! I love this setup, but I am definitely going to be building a new bed if I can catch up in the shop. I want some more external storage to keep the camper less full. It's not a problem for good weather but we had a night/morning with some crazy rain and had to put a ton of stuff in the cab to keep it dry. Just chairs and that kind of stuff. The new camper interior worked incredibly well to just hang out in, even with the two kids.
    What camper are you thinking about?
  13. Jul 8, 2025 at 6:40 PM
    #733
    CaptRussia253
    Ruslan
    Man I’m all over the place with the camper idea. FWC, OVRLND, some older style that doesn’t pop up. Nothing set in stone, just thinking about future adventures and wanting the right setup for just me and the wife.
    RobertD likes this.
  14. Jul 8, 2025 at 7:08 PM
    #734
    STravis
    Travis
    Ruidoso, NM
    I don't know what I would replace mine with if I were to change. We built a bed for a long bed ram 3500 a while back that got an OVRLND camper put on it. I really liked the larger footprint of the 3500 camper. If I were to go any bigger I really like the flatbed 4 wheel camper or a bundutec flatbed version but I would go to a 3/4 or 1 ton at that point.
    A hard sided non pop up camper would be really nice, but I like not having as many overhead height restrictions. And knowing me it would be on big tires again and make it even more important to try to keep a smaller profile camper. If money wasn't an issue I'd get a Supertramp or one of the new crazy high end campers that are coming out weekly.
    This is the ram we built, it has tons of storage and not even touching the 3500 payload.
  15. Jul 8, 2025 at 7:13 PM
    #735
    CaptRussia253
    Ruslan
    The more we think about the more we feel a diesel truck is in our future. But if we can keep the camper light we’re going to definitely keep the Tundra since it’s paid off, low miles, and reliable. Our minds are all over the place haha. We go back and forth with the build which is keeping things slow right now. Not in a hurry for sure.
    STravis[OP] likes this.
  16. Jul 26, 2025 at 9:22 PM
    #736
    InfernoBoyz
    InfernoBoyz YoutubeTech
    Reno, NV
    2016 Inferno Tundra Double Cab OR
    build is nuts man nice work !
  17. Jul 27, 2025 at 2:38 PM
    #737
    STravis
    Travis
    Ruidoso, NM
    Thanks! We have been incredibly happy with it. I've been tossing around the idea of selling it and starting over with a bigger platform, but I don't know how much I could sell it for and I have absolutely no idea what I would swap for. Seems like every truck brand has major issues with something. I like the idea of a mega cab with a Cummins or an F-250/350 but I don't know if I would go with the diesel or the big 7.3 gas. I hate to ditch the reliability of the tundra, this one is getting close to 170k hard miles but I wouldn't hesitate to take it anywhere.
  18. Jul 29, 2025 at 4:17 PM
    #738
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    I’ve got 2 neighbors one has a company runs dodge and the other has 2 ford king ranches all new stuff and they are constantly breaking them left and right. I’ll always stick to tundra u can go hundreds and thousands of miles with no issues
  19. Jul 29, 2025 at 5:39 PM
    #739
    STravis
    Travis
    Ruidoso, NM
    That's my train of thought as well, but I'm just getting heavy for the tundra. I did find a 2014 deleted manual Dodge 2500 today that would be sweet but I'd have to get a handful of cash for the tundra to even consider doing it. It seems like everything now is a ticking time bomb for reliability and I spend way too much time out and about to worry about that kind of problem.
  20. Jul 29, 2025 at 6:17 PM
    #740
    Trdwillie14
    Billy
    2014 trd off road
    Yah or not to mention the price of a tundra I could get 3 for the price of 1 king ranch and the tundra will outlast it all day long lol. But I get the weight issue for sure
