General Supercharger Thread
  1. Jul 6, 2025 at 8:13 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yikes! No wonder no compression.
    I forgot about the fuel multiplier since it's basically turned off like you stated.
    @Jowett mentioned about the oilers spraying super hot oil under the piston combined with inefficient cooling of the cylinder causing possible failure. Reason I added an engine oil cooler. Plus the added protection of W/M for cylinder cooling. I'll probably move to straight water and ditch the Methanol.
    I'll be hopefully installing the lexus 570 windshield washer in the driver's fender this week. It arrives tomorrow.
    https://fiinterchillers.com/tech_articles/water-injection-gains-50hp/
    Wynnded, ARES35, bflooks and 6 others like this.
  2. Jul 6, 2025 at 8:16 PM
    centex
    centex New Member
    Let me know how that goes. It’s not high on my list but it’s definitely there.
    bflooks and Mdl[QUOTED] like this.
  3. Jul 6, 2025 at 8:19 PM
    blenton
    blenton New Member
    Have you been able to monitor engine temps with your oil cooler installed? Any noticeable difference? It’s been on my back burner list for a while but haven’t mustered the gumption to figure it out yet. Honestly, I wouldn’t expect much of a difference at the gauge except maybe in high load situations like summer towing on grades, but I’m sure it would help even if only behind the scenes.
    Mdl[QUOTED] likes this.
  4. Jul 6, 2025 at 8:19 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    @snivilous
    The crank looks normal to me, manufacturing discoloration..
    My first thought was squirter plugged. We've had an old supra where one of the squirters fell out and it torched the piston from the bottom side..
    Overheating and very hot oil burned the piston? But why not the others?
    I assume all the Dots on the top of the piston were facing forward.. I've seen techs put them in backwards and it doesn't end well usually ..
    Definitely got hot, all the scratches on the cylinder wall... not a common issue
  5. Jul 6, 2025 at 8:21 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I have a separate oil temp gauge on my sandwich t-stat plate. Oil leaving air cooler is about 180 deg. It probably 200 plus entering.
  6. Jul 6, 2025 at 8:23 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Hopefully it fits. Initial impression is it should. I got a 2 gal intercooler tank coming and needed to switch it up.
  7. Jul 6, 2025 at 8:48 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Built motor lower compression more boost nothing crazy, address the elephant in the room on why this happened. If it was oil squirter plugged how do we prevent? Add an oil cooler as mentioned.
  8. Jul 6, 2025 at 8:54 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    No way the oil squirter caused that, oil doesn't have that kind of heat. How would it get plugged? Anything that is big enough to clog the oil squirter would cause bearing damage. That's from running too lean, or severe detonation, or both.
    Wynnded, ARES35, HulkSmurf14 and 3 others like this.
  9. Jul 6, 2025 at 8:56 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Oil comes from the filter to the squirter (oil jet), so shouldn't be any warmer than what's in the pan.
    Wynnded, ARES35, e30cabrio and 4 others like this.
  10. Jul 6, 2025 at 8:58 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    But interesting how the top of the piston shows no detonation
    ARES35, HulkSmurf14 and Mdl like this.
  11. Jul 6, 2025 at 9:02 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Probably not detonation, I'm leaning more towards heat from running lean and the piston rings expanding until they lifted the ringlands and broke the piston.
  12. Jul 6, 2025 at 9:25 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    This is what sniv and i concluded too but not the lean aspect. I think it happened same time as the trans. Hard day at the dunes in the truck, wet thick sand tons of load and hard runs
  13. Jul 6, 2025 at 9:31 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I forgot who, but was it Matt Smith, having fuel routing supply to front cylinders and exiting the rear for equal fuel distribution. Doing the crossover as 4firemandan did on the regular stock fuel lines before re-doing his AN 8 supply.
  14. Jul 7, 2025 at 8:49 AM
    bflooks
    bflooks New Member
    Metrowest MA
    As I was adding fueling option information to the turbo thread, I realized XAT speaks to additional issues/limitations with the stock fuel rails. I can't recall who is using stock vs upgraded, but given the discussion about possibly running lean, I figured I'd share their link with the details. Choose your poison on which brand you go with if you upgrade, sharing just for the data. https://xatracing.com/XAT-3UR-Fuel-rails.html
    Jego, HulkSmurf14 and armyoffoo like this.
  15. Jul 7, 2025 at 9:00 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I think making the modifications to the stock fuel rails to cut/enlarge the barbs and run the feed/return in parallel instead of in series would be sufficient for most builds, but I'm currently running the XAT rails with 8AN lines.
    Jego, ARES35, mustang67408 and 4 others like this.
  16. Jul 7, 2025 at 9:01 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm still on stock rails. I did remove the bevels on supply/return tube end and it opened the up. I noticed I hit 94% on injector duty cycle with the Five O 750cc injectors. Granted it was it 6-6400rpm. Majority was 85%idc.
    6AN supply/return.
    Jego, ARES35, mustang67408 and 3 others like this.
  17. Jul 7, 2025 at 9:20 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Viktor G has a video on the stock rails being good for some serious flow. But the old while you're in there motto could be applied
  18. Jul 7, 2025 at 9:58 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    If anyone needs some 750cc injectors let me know. Most likely moving up in size
  19. Jul 7, 2025 at 10:03 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Viktor's video is actually included in the Turbo thread since it talked about lines, pumps, injectors, etc.
  20. Jul 7, 2025 at 11:51 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    So I'm beginning to do some digging into the piston options. Interesting find is no one offers an off the shelf piston for 9:1-9:5 to 1. Only 10:1 off the shelf mfg. JE is the only option for that as a custom piston starting at $2500.
    ARES35 and HulkSmurf14 like this.
  21. Jul 7, 2025 at 12:36 PM
    bflooks
    bflooks New Member
    Metrowest MA
    XAT shows CP and JE as being the 9.0:1 options, both only a $250 upgrade over the Manley base price. That's under their long block build page.
    They also have JE 9.0:1 and JE 9.5:1 for $2000'ish. https://xatracing.com/JE-3UR-Pistons.html
    I'm sharing the differences in pricing because they're pretty good at working to ensure you're paying the appropriate price, which surprisingly, they have proven to be fair about.
    Manley also has a 10.0:1 (what is standard in their built long block): https://xatracing.com/xat-manley-3ur-forged-pistons.html
  22. Jul 7, 2025 at 12:40 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I went directly to JE so I’m assuming XAT price would be adjusted for the custom order of pistons from JE lol
    HulkSmurf14 likes this.
  23. Jul 7, 2025 at 12:41 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yep all pistons out there for the platform only go down to 10:1 Manley, diamond, BC etc for an off the shelf piston..
    Mdl, HulkSmurf14 and bflooks like this.
  24. Jul 7, 2025 at 12:42 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Maybe? Not sure what discounts they do/don't get that you wouldn't. Regardless, it's on their webpage, so I'd try to secure the $500 discount. :)
    Mdl and HulkSmurf14 like this.
  25. Jul 7, 2025 at 1:14 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    And confirmed with XAT the custom piston is more than shown on the website. lol
  26. Jul 7, 2025 at 1:18 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Where is the dislike button?
    It was worth a shot.
  27. Jul 7, 2025 at 2:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I believe there was a built engine where he had the crank ground down to accommodate...ummm...Chevrolet rods and believe pistons to get a 9.0 compression. I had some pm over on tundratalk but that was back in 2013-2014.
    Nevermind. It was just the rods.
    ARES35, blenton and HulkSmurf14 like this.
  28. Jul 7, 2025 at 2:53 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Brian Crower will do it also just FYI. Lead times are 6-8 weeks though. So leaning towards the available units at 10:1 since we see these holding well. More to come.
    mustang67408, ARES35, Mdl and 2 others like this.
  29. Jul 8, 2025 at 3:35 AM
    HappyDad38
    HappyDad38 New Member
    2014 Black Tundra TSS SC 4x4
    6" BDS Lift Fox Coils and shocks 35x12.5r20 nittos
    A member ^^^^ Reywcms, had recommended that I post these DeatschWerks 650CC fuel injectors on this thread as they are a go to for supercharger builds. Little information on them. Ordered them not knowing they are 650 CC or anything about them "my mistake". After receiving I realized that they are a higher displacement Injectors and that is not the route I wanted to take as I just wanted stock fuel injectors. DeatschWerks won't take them back so I am stuck with them, but they are brand new still sealed in the packages. I paid $650 for them but willing to take $400 shipped to anywhere in the USA. I also have them on eBay as well, thanks guys!AISelect_20250708_053227_eBay.jpg AISelect_20250708_053241_eBay.jpg
  30. Jul 8, 2025 at 7:42 AM
    ssmokedz
    Shelton CT
    I couldn't get rid of a PO420 or a PO137 for over 2 years. Tried every defouler imaginable without success. I just ditched my OTT tune and went with Sniv so I can play around on my own. Plus I needed to pass emissions. It seems the newer trucks are a little more finicky than the older ones. The tune he provided is equally as impressive as my OTT. I was able to successfully pass emmsions and I've put over 500 miles on the truck with no check engine light. If you want I can PM you about it.
