General Supercharger Thread
  1. Jul 5, 2025 at 8:48 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I’ll try those if these don’t work but heard good things on these
  2. Jul 5, 2025 at 8:57 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    They look pretty similar and the vibrant has I think 3 different sizes to control the amount of exhaust to be read by rear O2.
    bflooks and reywcms[QUOTED] like this.
  3. Jul 6, 2025 at 3:16 AM
    Backroadgee
    Backroadgee Well Known Member
    west
    Missouri
    SDHQ BAJA ADD PRO SKID PLATES
    Sweet, ty for the info.
    Saltyhero13 and HulkSmurf14 like this.
  4. Jul 6, 2025 at 5:44 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    New PML transmission pan installed.
    New filter installed.
    Took 9qts WS and it clears my converter shield...
    Drilled and tapped for the temp sending unit.
    Jego, Saltyhero13, bflooks and 10 others like this.
  5. Jul 6, 2025 at 10:26 AM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    What’s the consensus on these in terms of cooling? I suppose additional fluid capacity never hurts. The fins should also help. Anyone with evidence these are helping decrease pan/converter temps?
    Also, did you use the gasket it comes with? Or seal with something else?
    mustang67408[QUOTED] likes this.
  6. Jul 6, 2025 at 10:31 AM
    centex
    centex New Member
    Don’t expect 100* drops. I wasn’t monitoring the tundra but my last Cummins I saw ~15-20* drop fairly consistently with a similar pan. I attributed it more to the additional capacity and not the fins.
  7. Jul 6, 2025 at 10:43 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I have the PML and have temps 165-180, occasionally 190 with some wot pulls. But I don't have the warming puck or factory T-stat. I have a 165 deg t-stat.
    Hopefully someone who has it with the traditional setup will chime in.
    Seals with cork gasket or RTV. I used the gasket. Can't use factory gasket unless using B&M large pan.
  8. Jul 6, 2025 at 10:59 AM
    mustang67408
    Victor
    I used the cork gasket with a fine coat of the toyota FIPG (orange).
    I'm a modaholic and love to tinker. I figured since we tow, it cant hurt. My t-stat is pinned open.
    I'll start watching the trans temp soon.
  9. Jul 6, 2025 at 1:46 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    @snivilous checked out the motor out of the tundra pistons look damn good for 80k+miles and many of those miles with hard use. Compression test confirmed cylinder 7 being dead while all others showed great compression still.
  10. Jul 6, 2025 at 2:47 PM
    mustang67408
    Victor
    What Happened to #7 cylinder? sorry if I missed it
    Mdl likes this.
  11. Jul 6, 2025 at 2:52 PM
    centex
    centex New Member
  12. Jul 6, 2025 at 2:56 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If history proves correct than most likely ring let go. No 5 and 7 seemed to fail...
  13. Jul 6, 2025 at 2:58 PM
    mustang67408
    Victor
    The S/C I acquired for my truck....#5 was the culprit
    HulkSmurf14 and Mdl[QUOTED] like this.
  14. Jul 6, 2025 at 3:02 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Likely rings failed. Hurt the motor during my Vegas trip.
  15. Jul 6, 2025 at 3:04 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    We also confirmed the TRD spec motor unfortunately is no good. So this will likely mean we’ll be doing the built motor with my engine sooner than later.
  16. Jul 6, 2025 at 3:07 PM
    mustang67408
    Victor
    DAMN! I found out from SOL, that 2 of the injectors I acquired were plugged. They had to spend extra time cleaning them, but so far so good. The tune in that truck was also a box, not a superduper @snivouls amazing tune. I'M so thankful for him and this site. I just love all the feedback and positive attention everyone gives everyone and the willingness to help.
    e30cabrio, HulkSmurf14, Mdl and 2 others like this.
  17. Jul 6, 2025 at 3:19 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Is 7 at the back left of the engine? Seem to remember reading that one dying the most after boost
    Mdl and mustang67408 like this.
  18. Jul 6, 2025 at 3:20 PM
    mustang67408
    Victor
    Yes, Drivers side rear
    Mdl likes this.
  19. Jul 6, 2025 at 3:42 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Wow! That's too bad. I thought it was pulled before the race. What was buggered?
    mustang67408 likes this.
  20. Jul 6, 2025 at 3:45 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Only had test miles on it.
  21. Jul 6, 2025 at 4:03 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    What scope is that? Great picture quality.
    Mdl likes this.
  22. Jul 6, 2025 at 4:17 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    That’s for @snivilous to confirm
  23. Jul 6, 2025 at 4:23 PM
    bflooks
    bflooks New Member
    Metrowest MA
    IIRC, there were a few cylinders that has extra fueling in the factory tune. Wonder if that plays a last in the same cylinders burning up.
    Envious of the build, though! Can't wait for you to share more details about it.
    Mdl, HulkSmurf14 and e30cabrio like this.
  24. Jul 6, 2025 at 4:30 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    That sucks, what happened to the motor, why is it no good? I thought it was supposed to be a stout race motor?
  25. Jul 6, 2025 at 4:41 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    pistons look smoked and compression test no bueno. Yep was a spec’d motor so new oem for the class. Guessing during them running it hard in test runs/truck it was hurt unknowingly. Not sure what engine management system they ran or tuning etc. My source was extremely surprised as well. Interesting since this was from a major known team.
    ARES35, Mdl, HulkSmurf14 and 3 others like this.
  26. Jul 6, 2025 at 5:09 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Feed each fuel rail individually with their own return.
  27. Jul 6, 2025 at 6:39 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    This is a fun game :rofl:
    Initial thoughts????
    This is #7 which was the only cylinder to read low (as in zero) compression.
    And from the top side the piston seems fine? The dot I think is right next to where the skirt is melted.
    Also is the crank supposed to look this hot around the bearings? Or is this from manufacturing???
    @reywcms and I are utterly baffled what happened to this engine. Our initial thoughts is the #7 squirter got clogged and that's why it melted? But weird it's on the bottom. We also suspect that when he was having issues in like January or February and the plugs were all nasty, it was already hurt and straight pumping oil into the combustion chamber and full blowby shoving oil down the intake and that's why the plugs have looked so "rich" is there really "oil rich".
  28. Jul 6, 2025 at 6:48 PM
    snivilous
    SW UT
    Some $30 Amazon one :rofl:
    Yes, almost every N/A factory tune I've seen has modified fueling per cylinder, but it's rpm/load dependent what the increase is. It's a table called Injector Multis. The N/A factory files vary IMMENSELY in what the injector mutli values are. The TRD tune sets them all to 1 (ie turned off) so that's what I do with all tunes, plus imo it makes it easier to ensure the fueling is correct because you don't get random outliers. And sometimes values are even leaner. Additionally there are cylinder specific timing tweaks, usually only on 1 and 2, which I again always turn off.
    The bore scope on all cylinders of the "good" engine was nasty. It looks like insane detonation since the surface is so pitted, but hard to say. You can't even tell where the pistons were machined like on Reys and our other engine. Additionally lots of surface rust, maybe the rings are seized since I tested compression on 2 and 4 and for 70 and 85psi and didn't bother testing more. For comparison Reys (OG) engine tested 151-175 compression with #7 being the outlier and totally dead. Fairly large spread, but the lowest compression was higher than the highest on my old engine and other ones I've tested so not a huge worry. But 70-85 right off the bat even with seized rings is pretty bad, and check out the look of some of the pistons from the "good" engine.
  29. Jul 6, 2025 at 6:48 PM
    bflooks
    bflooks New Member
    Metrowest MA
    That's wild! I'd almost rather a hole in the block so you know it's done vs something like that.
  30. Jul 6, 2025 at 7:02 PM
    e30cabrio
