General Supercharger Thread
  1. Jul 3, 2025 at 7:48 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Maybe...you did have a shop install it. Hopefully they can do something.
    ARES35, Wynnded and e30cabrio[QUOTED] like this.
  2. Jul 3, 2025 at 8:06 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Nothing looks off with AFR, fuel trims are at like 2% across the board.
    That's not a bad idea. Still doubt that fixes it. I've done times with 85 octane and you don't even have to pull this much timing.
  3. Jul 3, 2025 at 8:26 PM
    bflooks
    bflooks New Member
    Metrowest MA
    For the overall small increase in pricing, it's one of those "while you're in there" decisions. For what has become a 1k HP build, the valves and springs were the only "upgrade" done over their standard build. Looking forward to seeing the block come together, too.
    Wynnded, e30cabrio, Jego and 2 others like this.
  4. Jul 3, 2025 at 8:45 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yea I don’t think it will either but helps rule out one thing lol
  5. Jul 3, 2025 at 8:48 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Something loose and rattling around? Drop a tool or bolt down in the valley that's bouncing around close to the knock sensors?
    ARES35, Wynnded and Mdl like this.
  6. Jul 3, 2025 at 9:31 PM
    snivilous
    SW UT
    He says the chain tensioner makes a lot of noise and is going to send me a video. That sounds like a plausible source to trigger the knock sensors...
  7. Jul 3, 2025 at 10:04 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Crazy! But makes sense.
    ARES35 and Wynnded like this.
  8. Jul 4, 2025 at 6:53 AM
    ARES35
    ARES35 New member for life
    Mile high
    But it's pulling timing during the knock events?
    HulkSmurf14 likes this.
  9. Jul 4, 2025 at 8:04 AM
    snivilous
    SW UT
    All the red is timing being pulled. The difference from -3 is how much is pulled. My goal is the whole table reads -3, worst case -4 meaning one degree is pulled. This truck is pulling like 7-11deg all over the place constantly.
  10. Jul 4, 2025 at 10:48 AM
    ARES35
    Mile high
    Ah I understand. I always think of the knock retard reducing the timing and knock feedback detecting knock. But I'm easily confused.
    Highest I've ever seen was -7.5 at partial throttle on new tune, nothing over -4 on wot though.
    snivilous[QUOTED][OP] likes this.
  11. Jul 4, 2025 at 11:26 AM
    snivilous
    SW UT
    No you're right, I just tend to group them together since from my understanding knock retard is more or less slaved to knock feedback. So while they're not necessarily one and the same, they change together, so you're always getting timing retarded if the knock feedback is below -3.
    ARES35[QUOTED], Mdl and armyoffoo like this.
  12. Jul 4, 2025 at 12:29 PM
    ARES35
    Mile high
    That makes sense. And then thats when I'd usually add some fuel in PE if trims are good. You said Air fuel is good but wonder how fuel pressure looks, which you've may probably already checked.
  13. Jul 4, 2025 at 3:46 PM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    If yours and the stock Magnuson tune are showing the same exact issue, I would have to point at something going on beside tuning. I seen fuel quality mentioned already. So I’m sure the owner has made an attempt to get the correct fuel in by now. So at this point, if the correct fuel is in, it is def something mechanical. How is the truck running with both yours and the Magnuson tune minus the spark issue?
  14. Jul 5, 2025 at 12:24 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    This Harrop is still available if anyone wants me to look...good price-ish:
  15. Jul 5, 2025 at 12:28 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    A) how is this similar?
    B) what is it/ why am I thinking Breaking Bad meth lab?
    HulkSmurf14[QUOTED] likes this.
  16. Jul 5, 2025 at 12:34 PM
    HulkSmurf14
    2014 Tundra Limited
    Haha, man, "trying times" make great deals for those whom are patient! Imagine what you could make with a $130k machine at 70% off! Also, boost!
    Honestly not sure what's going on with that CNC...perhaps he works there...also, perhaps it's a scam...not sure, but I'm educated on both items and have lived in this valley for 30 years...I could root.it out if interested...
    armyoffoo, reywcms and e30cabrio like this.
  17. Jul 5, 2025 at 12:40 PM
    e30cabrio
    I have no need for whatever it is and my supercriminal island lair is fully accesorized so for those reasons, I'm out.
  18. Jul 5, 2025 at 12:46 PM
    HulkSmurf14
    2014 Tundra Limited
    :rofl::santa:
    Tripleconpanna likes this.
  19. Jul 5, 2025 at 1:11 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That is soon tempting! If I weren't planning on a move I'd jump on it! I've already spent too much on small items.
    I finally got my timing and afr's sorted out plus MAF. Where MAF is maxxed right at 6000-6400 rpm and afr's bounce between 10.9 and 11.5. Seems to be pretty peppy...
  20. Jul 5, 2025 at 1:47 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Boomslang firewall mount completed, waiting on the rain to stop then I'll mount it, figure out how to mount/secure the stock ECU under the dash and then begin wiring accelerator pedal, throttle body and sensors...this weather sucks but at least it's not 110+
    It's not pretty, but it's good enough for who it's for. Original M6 bolts mount it to the firewall, M4 bolts mount the sandwich plate to the firewall adapter. I also re-pinned the injector harnesses with the ID 1050x plugs, so they are ready to install.
  21. Jul 5, 2025 at 1:50 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @armyoffoo looking good! The wiring would drive me crazy and take 3x's as long. I'd be triple checking and re-checking.
    HulkSmurf14, armyoffoo and e30cabrio like this.
  22. Jul 5, 2025 at 2:18 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    What's the giant red button?!?! I just wanna slap it lol
  23. Jul 5, 2025 at 2:19 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    It's a cover for the bulkhead wiring pass-through.
  24. Jul 5, 2025 at 2:31 PM
    Backroadgee
    Backroadgee Well Known Member
    west
    Missouri
    SDHQ BAJA ADD PRO SKID PLATES
    I'll be contacting Magnuson soon..Need some supercharger tuning.
  25. Jul 5, 2025 at 2:37 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    OTT or @snivilous can give a much better tune than what the canned tuned offers.
  26. Jul 5, 2025 at 2:44 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    THIS!!!! ^^^^^^^^^
    ssmokedz, snivilous[OP] and Mdl like this.
  27. Jul 5, 2025 at 3:53 PM
    centex
    centex New Member
    I second this.
  28. Jul 5, 2025 at 5:36 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Defaulers arrived we’ll see how they work.
  29. Jul 5, 2025 at 6:45 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Mmm...steak for dinner. I used the Vibrant ones before with good results for p0420's from LT headers.
  30. Jul 5, 2025 at 8:48 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I’ll try those if these don’t work but heard good things on these
