What have you done to your 2nd Gen Sequoia today?
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by SprinterAE86, Sep 7, 2020.
  1. Nov 19, 2024 at 5:29 AM
    #181
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Doesn't seem as likely as the receiver or related ECU. But I suppose someone could be so unlucky to have all of them fail at once.
  2. Nov 27, 2024 at 8:50 AM
    #182
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Washed her yesterday.
    But FINALLY did the rear differential breather mod.
    Had to rush since I'm doing it with the kids at home out of school, but at least did it.
    Bought the union off Amazon a while back I think. The hose was left over from when I did the same mod for my tundra.
    bntly likes this.
  3. Dec 16, 2024 at 8:34 PM
    #183
    bntly
    bntly New Member
    2021 LR TRD Pro Sequioa
    Removed cargo boxes, gave Bertha a wash, lifted and fitted with some new shoes
    Poke anyone?
    Florida AF, occruiser and Fotnot like this.
  4. Dec 16, 2024 at 8:35 PM
    #184
    bntly
    bntly New Member
    Sweet ride!
    Fotnot[QUOTED] likes this.
  5. Dec 17, 2024 at 12:32 AM
    #185
    Johnsonman
    Austin
    Sequoia
    Body or suspension lift?
  6. Dec 17, 2024 at 11:12 AM
    #186
    bntly
    bntly New Member
    Suspension Sorry wasn’t clear.
    - Westcott Designs collar lift about 1.5/1 inch lift front/rear
    - BFG ko3 (295x70x18) about 2inch taller than stock tires
    - 1.5in spidertraxx wheel spacers
    Asolodolo38, Peeeheeuuu and Fotnot like this.
  7. Dec 17, 2024 at 5:25 PM
    #187
    Johnsonman
    Austin
    Sequoia
    Nice & Beefy !!
    bntly likes this.
  8. Jan 27, 2025 at 7:41 AM
    #188
    ScorchedTaco
    ScorchedTaco New Member
    Az
    2012 Sequoia platinum 2012 Tacoma trd or
    Installed the Tundra transmission cooler . Smooth install , everything just bolts right up.A1274D10-F8B4-43A1-B023-2676CFD43045.jpg
  9. Jan 27, 2025 at 8:08 AM
    #189
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Good deal.
    got links to parts ordered or anything?
    also, what's your towing situation? issues before? something push you to get this? or was this just a pre-emptive thing?
  10. Jan 27, 2025 at 10:10 AM
    #190
    ScorchedTaco
    Az
    It’s for pulling an rv camper . I have the tow package , but that didn’t include the transmission cooler on 2012 Sequoias , which I think is wild. so parts :
    Tundra cooler - 32910-0c010 ( get it used on ebay)for $250 vs $600 new .& make sure it has the plastic surrounding.
    Thermostat - 32970-34030
    Inlet hose -32941-0c030
    Outlet hose 32942-0c040
    Hard line - 32907-0c020
    Hose clamps x8 -90466-16004
    Flange bolts x2 - 90080-10400
    Lastly for the hardline to the cooler I just picked up a couple feet of 3/4 hose from autozone ……
    sudobash, Rodtheviking and Fotnot like this.
  11. Feb 19, 2025 at 5:40 AM
    #191
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    brought the sequoia into the dealer this past week. had 3 things for them to look at under my extended warranty (covers everything except maintenance items with $0 co-pay)
    1. Passenger front window was making a grinding sound like the motor was going out. Ordered new regulator and motor for it. On backorder for a few weeks it seems.
    2. Both front ball joints had oil/grease leaking out the boots. Seemed possibly normal, but wanted to make sure since I was already there. Checked and said it's normal leaking, but no worries. Checked rear shocks and saw the seals were leaking. Ordered 2 new ones for them. Said they could be in their hands in about a week. I didn't see anything, but I'm almost positive they're trying to get some extra money since it's just 2 bolts for each one and they're straight forward to change. Hell, they said they charged it for 8 hours for the 2. I put an entire 6" lift kit on my last truck in about 10 hours.o_O
    3. My driver's seatbelt female end was making a clicking noise for a little while while driving. It'd make clicking sounds when buckled and driving over bumps or even if i repositioned and/or took a deep breath. It wasn't a big deal, but considering it was the seat belt, I didn't wanna risk something being wrong with a safety component. They were barely able to replicate it and are replacing the part. Back-ordered and should be here in a few weeks.
    Also changed brake fluid this past weekend with my pops.
    Florida AF likes this.
  12. Apr 13, 2025 at 4:14 PM
    #192
    Cthulhu
    Rear wiper stopped working on my 2016 Sequoia. Could not for the life of me find where the fuse was, but kept searching and found a guy on the 4runners site, whose rear wiper stopped working. Turns out at some point he hit the rear power window switch a smidge, and there’s a safety feature that doesn’t allow the wiper to work if the window is down just a little. Same thing exists on the Sequoia…me or my wife must’ve accidentally hit our rear window switch…problem solved. :facepalm:
  13. Apr 13, 2025 at 6:22 PM
    #193
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    That's good to know!
  14. May 21, 2025 at 8:17 AM
    #194
    ScorchedTaco
    Az
    So , I’m currently replacing front struts & springs on my 2012 Sequoia …Had 2 minor problems …
    .. 1. Sway bar end link broke loose at the welded nut in the LCA . No problem - just cut the strut out of the way ( 20 seconds tops with a brand new Diablo blade! ) then I was able to get a wrench on it and remove.
    …2. I bought 2 new toyota coil springs , however while using the “widow maker” spring tool to disassemble the old coils I realized that they have different “ paint marks” and sure enough they mean something …… the driver side spring has a higher # to make up for the weight of driver & fuel tank . So on my 2012 platinum - driver front has red & orange dots , passenger front - orange & orange dot .
    so lesson learned ……
    Fotnot likes this.
  15. May 24, 2025 at 7:37 PM
    #195
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Long story short, I FINALLY got my rear shocks in and replaced (under extended warranty). They let me keep originals since it wasn't factory warranty and didn't need to send back cores. It's been a pain to find, but they got them.
    Both right and left rears are the same part number
    20250524_175158.jpg 20250524_175256.jpg 20250524_175232.jpg 20250524_175310.jpg 20250524_175427.jpg
  16. Jun 12, 2025 at 5:59 AM
    #196
    Dan McBoost
    Dan McBoost New Member
    2014 Sequoia platinum and more.
    New here, but glad to finally be.
    Picked up my 2nd gen (end of April) after a 7 year love affair with my 1st gen. Simple stuff yesterday but more is brewing, black mirror caps:
    ScorchedTaco and Fotnot like this.
  17. Jun 12, 2025 at 6:29 PM
    #197
    ScorchedTaco
    Az
    Nice 2nd Gen! Welcome to the club!
    Dan McBoost[QUOTED] likes this.
  18. Jun 29, 2025 at 6:37 PM
    #198
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Ball season wrapped up, so I finally had time to wash her. Got a roof rack in from bezo's mart to help bring stuff to functions. With 5 kids, there's not much room in the back for canopies, chairs, ice chests, etc. Plus it'll be helpful for other stuff here and there too without having to use the hitch carrier.
    Also got in, after waiting 4 years to order, the weathertech rear liner that'll cover the 3rd row as well as go under the 2 middle seats and cover down the middle between the 2 middle seats. The part in the middle was always just exposed carpets making it fun with kids and cleats. Both of these should be helpful for my family and I.
    20250627_150019.jpg 20250628_185955.jpg 20250629_124957.jpg 20250629_124714.jpg
  19. Jul 2, 2025 at 6:04 PM
    #199
    sudobash
    sudobash New Member
    What do you plan on doing with the old ones? Any interest in selling them?
  20. Jul 2, 2025 at 6:18 PM
    #200
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I wasn't really considering selling them. I was considering holding them since only one slowly leaked and the other was fine. That way if they go out, I have others to swap out until I get the new ones in.
  21. Jul 4, 2025 at 5:33 PM
    #201
    GreatBallsOfFire
    GreatBallsOfFire "I wanna go fast" - Ricky Bobby
    Seth
    Fairbanks, AK
    2017 Pyrite Mica Sequoia Limited
    Started with trying to fix the rear blower motor and then found dog food under the carpet in the back (I don’t own a dog) then then transitioned into me disassembling the interior and vacuuming out every corner of the car including under the carpet. Not included in the picture but I currently have drivers seats and center console removed too.
  22. Jul 7, 2025 at 9:05 AM
    #202
    Dan McBoost
    I continued on the removing chrome other than badges. I picked up a newer sequoia rear hatch garnish that holds the plate lights. Yes, I need to clean this yet again. The joys of a black car, ugh.
    Fotnot likes this.
  23. Jul 8, 2025 at 6:56 PM
    #203
    tahoe
    tahoe New Member
    2013 RW, 6112 @1.9” front, 5100 rear
    What company did you use for the extended warranty? I’m about to buy an out of warranty sequoia with 49k miles.
  24. Jul 8, 2025 at 7:24 PM
    #204
    Johnsonman
    Austin
    Sequoia
    At 10 yrs and 115K it was time for some power steering maintenance - Used a small hose to siphon out the old (twice) and replace with Maxlife - came out light brown so no big deal yet I will sleep better. Did the trans D/F also - done for another 30K - ahhhh.
    Fotnot and omgboost like this.
  25. Jul 8, 2025 at 8:06 PM
    #205
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    It was bought at the dealership. I'll have to look at my papers in the glovebox tomorrow for the name of the company. Don't let me forget
  26. Jul 9, 2025 at 6:21 AM
    #206
    tahoe
    tahoe New Member
    thanks for looking. It sounds like they are holding up their end of the bargain.
  27. Jul 9, 2025 at 7:31 AM
    #207
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    ooooo....nice reminder!
    i went out to the truck and remembered i didn't have a "hard copy" of the warranty, but they put it all on a USB for me. it's called Toyota Extra Care and it is their "Platinum" coverage. now, i bought it new, so i don't know if they'll offer it, but on the agreement, it had a checkbox for either new or used. mine is for 96 months or 125k miles. i pay $0.00 deductible for it. i do have a separate wheel & tire package as well that just covers damage to the wheels n tires. i did it cuz tires are expensive and so are the TRD PRO wheels. it was about $1k i think. but hell, a set of tires exceeds that....let's not talk about the price of the wheels. :eek2::spending:
  28. Jul 9, 2025 at 12:23 PM
    #208
    tahoe
    tahoe New Member
    Thanks! I’ll look into it
    Fotnot likes this.
