Backing with trailer(s) & BRAKE!!! Any way to turn off??
Discussion in '3rd Gen Tundras (2022+)' started by CwickStylz, Jun 17, 2023.
  1. Jun 3, 2025 at 12:23 PM
    HerdManager
    HerdManager New Member
    Stephen
    2023 Limited Hybrid Crewmax
    My truck does the exact same thing. EVERYTHING is disabled, I am in tow mode, etc, and it will still sound crazy alarms and slam on the brake. And not just the emergency brake, it will somehow lock the drive train so I have to shut down the truck and restart it. I have a 7-pin connector so don't think this is the issue. Drives me insane.
  2. Jun 3, 2025 at 12:36 PM
    DRP
    DRP Old Member
    Dave
    There was one report of this where the dealer found one of the sensors on the rear bumper was bad. Replacing the sensor solved his issue.
  3. Jun 12, 2025 at 4:40 AM
    Surfsup
    Surfsup New Member
    Chicagoland
    2024 Tundra
    No, I have it as well. First Toyota I've owned. I was told in the test drive the sensors can all be disabled. I was NOT told this was only disabled per drive and must be done every time. The backup sudden BRAKE is insane. Been driving 40 years zero accidents and my vehicle thinks it needs to brake for me. Stupid. I park in my garage. I have only 4-5 inches clearance front and back to squeeze the truck in. I get this BRAKE 95% of the time (sometimes it doesn't trigger). Very disruptive and I feel like it may damage the braking system over time. I've disabled to OFF all the settings as well. Still does this, no trailer.
    This is another poorly thought out safety item. I back with my door open a lot. This Toyota doesn't let the truck move. Insane. All these sensors. I also drive in rush hour. The piercing beeps when someone slows and turns to the right in front of you and you totally have room to go behind them is terrible.
    There has to be a trick to turn these incessant beeps off. This is the main reason I joined. Such a nice truck aside from these beeping sensors.
  4. Jun 12, 2025 at 4:42 AM
    Surfsup
    Surfsup New Member
    Chicagoland
    2024 Tundra
    I back up so slow that i touch the brake and the truck is just barely allowed to move. Still does it.
  5. Jun 16, 2025 at 4:23 AM
    Rat Fink
    Rat Fink New Member
    Alabama
    25 Silver 1794
    I run into this with the tailgate down. Moving some stuff long enough to need tailgate down and she won't let you do it. Turned EVERYTHING off except the AC and nothing helped. Tried to fool it by rolling back in neutral and whiplash! No trailer, just tailgate down. This is stupid. Can I please back up to my garage with the tailgate open?
  6. Jul 3, 2025 at 4:32 PM
    Surfsup
    Surfsup New Member
    Chicagoland
    2024 Tundra
    So I was able to solve this. I didn't see this in the manual but it was in the info card. There's a button left bottom of the steering wheel. IIRC last button on right on top row 2024 tundra that disables the brake sensor. It's been a few weeks and with this off it only triggered once, and i was backing up quickly. Sonit may engage if you're backing up quickly.but the other 40 times in reverse parking in my garage the brake slam and loud noise has not happened. Hope this helps
    Tunrod likes this.
  7. Jul 3, 2025 at 4:57 PM
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    For eff's sake....:
  8. Jul 3, 2025 at 8:19 PM
    Surfsup
    Surfsup New Member
    Chicagoland
    2024 Tundra
    Yeah. That one LOL. Again, I still got the slam twice but that's it. The nice thing is it stays off unlike the autostart.
