Howdy! Come watch me polish a turd.
Discussion in '1st Gen Tundras (2000-2006)' started by Nimitz_, May 30, 2025.
  1. May 31, 2025 at 5:21 PM
    Nimitz_
    Nimitz_ [OP] Ballin Outrageous
    Sam
    Seattle-ish
    06 DC LTD 4X4 4.7 V8
    Thanks looks like the closest one is like 50 miles away. FB and OfferUp it is!
  2. Jun 1, 2025 at 4:41 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
  3. Jun 1, 2025 at 9:45 AM
    Nimitz_
    Sam
    Seattle-ish
    I have so much love to give
  4. Jun 1, 2025 at 6:20 PM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    I dont see nothing wrong there ??
  5. Jun 1, 2025 at 8:10 PM
    Nimitz_
    Sam
    Seattle-ish
    Retired...finally likes this.
  6. Jun 2, 2025 at 10:23 AM
    Nimitz_
    Sam
    Seattle-ish
    Ok so one thing that’s holding me up is I want to make sure there’s nothing leaking from the back of the engine, but there’s so much oil all over everything it’s hard to get a good eye on it. The steering rack bushings were a colossal pain in the ass, I kept dropping tools on my face because there was so much oil everywhere. Anyway, how common are rear main seal leaks and such? I don’t want to pull this bad boy apart and then need to do it again because I missed something. I spray everything down with simple green and power wash it, but I can’t do it with the engine running since it just makes it worse. I don’t need to worry about anything below the valve covers getting wet as long as I’m using a 40 degree nozzle, right?
  7. Jun 2, 2025 at 12:54 PM
    Rear main seal failures aren't common at all. You said your valve covers were leaking? If bet dollars to pesos that's your problem.
    Nimitz_[QUOTED][OP] likes this.
  8. Jun 2, 2025 at 1:01 PM
    Nimitz_
    Sam
    Seattle-ish
    I mean it’s PISSING oil while it’s running. Valve covers are first on the list and I’ll see where that gets me, but for some reason it seems like way too much for just that, but I’m new to any kind of issues like this.
  9. Jun 2, 2025 at 1:03 PM
    Clean up the back of the heads and block as best you can. That'll get you pointed in the right direction.
  10. Jun 2, 2025 at 5:42 PM
    Nimitz_
    Sam
    Seattle-ish
    Alright halfway through the first half. Are these fel pro gaskets decent or should I hit the dealership on the way to work tomorrow?
    Looks like the bottom front corner is our culprit, but like everyone else some of the bolts were less than finger tight.
    FirstGenVol, Bmktw2 and G_unit3000 like this.
  11. Jun 2, 2025 at 6:07 PM
    FelPro is about the only other company I'd trust.
    Yeah, leaking from corners, be sure to hit all surfaces with Brakleen after you clean out the old sealant, to remove any oil residues, before FIPG.
    Someone else has potentially been in there before, the half-moons at the back of the head look like someone have a wrench on them (normal).
    You have FIPG already, and plan to do the half-moons, right?
    Be sure to check for random little bits of FIPG down in the head before you put the cover back on (and probably before FIPG).
    Having a larger sized socket makes it easier to drive in the spark plug tube seals, be sure to install the correct way, the inner ring's ridge I believe faces toward you (will be pointing down in toward the engine).
    You went with the easy side first, I see :rofl:
  12. Jun 2, 2025 at 6:56 PM
    Nimitz_
    Sam
    Seattle-ish
    Yep have FIPG in hand and am planning on doing the half moons. Just got it all cleaned out and ready to install but will save that for another day.
    I just did the side the guy on YouTube did first, I didn’t even know there was an easy side. I’m very comfortable working on cars so I’m not too worried about it, you guys just have a granular knowledge about these things I’ve never seen before so I’m asking a billion questions.
    Hutcheson likes this.
  13. Jun 2, 2025 at 7:13 PM
    No prob.
    Other side is more difficult, more shit in the way. Dipstick tube, evap/fuel hoses, etc. But at least you have a “pull handle” with the oil filler tube. Consider zip-tying any obstructive lines out of the way so you have a clear path of exit and entry. I don’t even bother disconnecting the coil packs, just unbolt, slide out of the tube and lay on the intake, install the bolt back in the cover so it’s not lost. One less plastic harness clip to break.
  14. Jun 2, 2025 at 7:16 PM
    Nimitz_
    Sam
    Seattle-ish
    Cool thanks for the tips man. I’m going to poke at this thing on my lunch breaks so it’ll be slow going but damn it’s nice working on something I don’t need to drive to work in the morning.
    G_unit3000 and shifty`[QUOTED] like this.
  15. Jun 6, 2025 at 12:54 PM
    Nimitz_
    Sam
    Seattle-ish
    Alright I finally got more time to work on this. The easy half is back together and the driver side is pulled apart. Lots of wet oil on the mating surface of the old gasket and tons of caked dirt and oil all over the top and back of the block. Also a concerning amount of gunk on the bottom of the cover. Feels like dirt. I’m guessing I need to do a few back to back oil changes with some seafoam or something.
  16. Jun 6, 2025 at 3:36 PM
    Back half of the driver head/bank1 is always caked and dark. Inherent to the design for some reason. And for the cake inside cover, scraper and Brakleen worked great for me.
  17. Jun 6, 2025 at 5:00 PM
    Nimitz_
    Sam
    Seattle-ish
    I cleaned out what I could and buttoned it back up then changed the oil, but it’s leaking from the crank shaft seal like there isn’t one in there. Like a drop of oil ever second or two. It’s pretty bad.
    The valve covers needed to be done for sure, I was just hoping that was it. The timing belt looks like it’s a year or two old which sucks.
  18. Jun 6, 2025 at 5:08 PM
    Nimitz_
    Sam
    Seattle-ish
    also, my oil pressure is like halfway, which seems kind of high for these trucks.
  19. Jun 6, 2025 at 5:13 PM
    Always? Even after it’s warmed up? It should only be like that on startup and later if you go over 2k rpms.
  20. Jun 6, 2025 at 5:18 PM
    #50
    Nimitz_
    Sam
    Seattle-ish
    Ah not sure, it sits at 2k at startup but I didn’t pay attention to it when I was driving it. Good to know, thank you.
  21. Jun 6, 2025 at 5:25 PM
    #51
    Nimitz_
    Sam
    Seattle-ish
    Oh sorry I meant to ask, is that normal inside the cover? I was freaking out thinking there was a ton of grit in the block. I just changed the oil and it was DARK but there was no clumps or glitter in it.
    G_unit3000 likes this.
  22. Jun 6, 2025 at 6:18 PM
    #52
    Dude. The inside of my covers, at 70k original miles, looked like someone poured maple syrup in them, let it dry 3-4mm thick, then took a torch and blasted it until it was black and flaky. There are pics in the megathread, I believe.
    Yours are mild in comparison.
  23. Jun 6, 2025 at 6:20 PM
    #53
    Also, I wouldn’t doubt if there’s a resistance test for the oil sender. I’d need to look in the FSM. But I’d be interested to see what the gauge reports for resistance after sitting overnight, totally cold. I think that gauge, like the fuel level gauge and many others, works on resistance?
    Im out of pocket with only periodic internet the next couple weeks, in and out of semi-remote areas. So I can’t dig in the FSM For you to look.
  24. Jun 6, 2025 at 7:09 PM
    #54
    Nimitz_
    Sam
    Seattle-ish
    I can fish for myself. Thanks for the help and have fun!
  25. Jul 2, 2025 at 4:56 PM
    #55
    Nimitz_
    Sam
    Seattle-ish
    Alright, crank seal replaced. No leak from cam shaft seal so that was good news. Timing belt, wp, thermostat, fan bracket and LBJs done too. Next up is unfucking whatever is going on with this brake line, replacing the unbranded radiator and trying to find a donor vehicle in a yard.
    Bmktw2, bmf4069, Pig Rig and 3 others like this.
  26. Jul 3, 2025 at 3:55 AM
    #56
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  27. Jul 3, 2025 at 6:12 AM
    #57
    Leojin
    Leojin New Member
    Illinois
    2004 Tundra Limited DC 4x4 4.7L V8
    Following, good luck with the donor vehicle. Maybe if the frame is clean we will see a frame swap? :rofl:
    Nimitz_[OP] likes this.
  28. Jul 3, 2025 at 7:25 AM
    #58
    Nimitz_
    Sam
    Seattle-ish
    bmf4069, Pig Rig and JasonC. like this.
  29. Jul 4, 2025 at 6:33 PM
    #59
    woodamsc
    woodamsc New Member
    New Hampshire
    2003 Tundra v8 4.7l 4wd sr5
    if your's is a turd then mine is afterbirth lmfao
    Looks great my man don't sweat it. I need to post pics of mine some day.
  30. Jul 4, 2025 at 8:01 PM
    #60
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    I'm tired of looking in the manuals:
    What is the small light on inner bottom of headlight assembly of these trucks?
    I've never gotten mine to work.
