Having a misfire but can't locate anyone with same problem
Discussion in '1st Gen Tundras (2000-2006)' started by Chris.m, Jun 19, 2025.
  1. Jun 28, 2025 at 7:20 PM
    #61
    Dustdog
    Dustdog New Member
    01, 05 AC 4wd
    stockers
    resistance is going down as temp goes up.
    A good trick is to also test it in a bowl of ice water as you know that will be 32F. Its possibe for thermistors to be good at a particular temp but be out of whack compared to their design curve. So having multiple readings is a good idea.
    Although Im not sure how the coolant temp is leading to a misfire on only one side.
  2. Jul 1, 2025 at 2:42 PM
    #62
    Chris.m
    Chris.m [OP] New Member
    Socal
    2004 toyota tundra double cab trd
    2004 double cab v8 trd package 2w drive bone stock
    I couldn't locate a denso coolent temperature sensor online or at autoparts stores so I bought a delphi
  3. Jul 1, 2025 at 2:43 PM
    #63
    Chris.m
    Socal
    I don't neither bit it says in the its one of the causes for a misfire
  4. Jul 2, 2025 at 3:23 AM
    #64
    Do you have any weird pops or backfires?
  5. Jul 2, 2025 at 11:03 AM
    #65
    Chris.m
    Socal
    Sometimes I can here a pop out the exhaust if I rev it up and down fast. But I don't remember at idle or a steady high rpm
  6. Jul 2, 2025 at 5:17 PM
    #66
    Chris.m
    Socal
    So I pulled out the crank sensor and tested it. It had a like a real fine black soot stuck to it when I pulled it out. Here's the reading I get. Can you tell me if I have it set to the right ohms? I get weird readings on the others and at 2k I get nothing.
    KNABORES likes this.
  7. Jul 2, 2025 at 6:08 PM
    #67
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    Looks like practically a short to me. You've got the meter set to continuity. Is it beeping?
  8. Jul 2, 2025 at 6:15 PM
    #68
    Chris.m
    Socal
    No beeping
  9. Jul 2, 2025 at 6:16 PM
    #69
    Chris.m
    Socal
    What should I set it to
  10. Jul 2, 2025 at 6:24 PM
    #70
    It might be right. Set it to 200; you should see the same value if it’s correct.
    If those are commas in the spec, put it to 2k ohm reading instead.
  11. Jul 2, 2025 at 6:31 PM
    #71
    Chris.m
    Socal
    I put to 2k and it quickly flashes 1,800 the goes to 1. And won't read anything. This was yhe black stuff that was stuck to when I pulled it . Turns to like black ash when you rub it between your fingers
  12. Jul 2, 2025 at 6:33 PM
    #72
    That means you’re not getting good continuity for the reading. Try cleaning it with some q-tips and 90% alcohol (the contacts). That is just metal, right?
  13. Jul 2, 2025 at 6:34 PM
    #73
    Chris.m
    Socal
    If the alligator clips touch it beeps
  14. Jul 2, 2025 at 6:36 PM
    #74
    Chris.m
    Socal
    It's like fiber stick to your finger but turns to black powder
  15. Jul 2, 2025 at 6:36 PM
    #75
    Fragman
    Fragman New Member
    That's what it should do in continuity mode, so that's good. a -1- with no other digits usually means Open, as in no continuity at all, infinite resistance. Try cleaning the contacts as Jack suggested.
  16. Jul 2, 2025 at 6:38 PM
    #76
    Chris.m
    Socal
    Alright thanks
