  1. Jul 2, 2025 at 5:52 AM
    Not to be confused with “beef curtains”
    bmf4069, BroHon and Jack McCarthy like this.
  2. Jul 2, 2025 at 5:58 AM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    So many pictures come to mind but i dont think i can copy/paste any of them here for a visual effect.
  3. Jul 2, 2025 at 6:00 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Some of the big box stores around here have those
  4. Jul 2, 2025 at 6:07 AM
    badass03taco
    found one, maybe two
  5. Jul 2, 2025 at 6:09 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    FOXTROT!
  6. Jul 2, 2025 at 6:21 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  7. Jul 2, 2025 at 6:26 AM
    Really somewhat age dependant. Don’t want beef too young or beef too old.
    BroHon likes this.
  8. Jul 2, 2025 at 6:34 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  9. Jul 2, 2025 at 7:33 AM
    matkes77
    matkes77 New Member
    2002 4.7L AC 4x4
    I've been searching, I promise.......but can't find any thread where someone put a 6x9 in an AC rear door. Any idea if its worth the mods to put one in there?
  10. Jul 2, 2025 at 7:51 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    matkes77[QUOTED] and BroHon like this.
  11. Jul 2, 2025 at 7:52 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I put 6x9s in mine. I modified the stock speaker brackets to hold them. Can’t remember the exact details now. But I promise it’s possible.
  12. Jul 2, 2025 at 8:04 AM
    shifty` You can call 1 (800) PP5-1-DooDoo
  13. Jul 2, 2025 at 8:08 AM
    Definitely know it'll fit; I'd just love to find a plug-and-play bracket. I need to pull specs on all Scosche and Metra 6x9 brackets made for Toyotas, and see if any bolt holes happen to line up with the measurements I took on my rear cab doors.
  14. Jul 2, 2025 at 8:24 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    455h0le_dachshund likes this.
  15. Jul 2, 2025 at 8:26 AM
    455h0le_dachshund and matkes77 like this.
  16. Jul 2, 2025 at 8:30 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Yeah, sounds like the Fulton County Commission has you tied up
  17. Jul 2, 2025 at 8:39 AM
    Fortunately I never deal with Fulton or Dekalb, I think I'd go f'n nuts if I did. Things are wild enough at the city level.
  18. Jul 2, 2025 at 8:47 AM
    matkes77
    matkes77 New Member
    2002 4.7L AC 4x4
  19. Jul 2, 2025 at 8:51 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    shifty` and matkes77[QUOTED] like this.
  20. Jul 2, 2025 at 8:52 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    I have never really been a part of a "steering comity" or decision making group... I've taken part in some community things, "KABOOM" playground builds, Neighborhood cleanups etc...
    I've have sat in on quite a few Planning dept meetings when I was in inspections, and it's hard to explain the pretentious air that fills those rooms, such a shit show Shifty... bunch of idiots burning money.
    Question is, is the juice worth the squeeze?
    I really don't care for groups where you can't tell someone how retarded they are, or their thinking or idea is :rofl:
    EDIT: except for my marriage, definitely and exception to that rule... o_O
  21. Jul 2, 2025 at 8:53 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  22. Jul 2, 2025 at 9:02 AM
    No thanks! Dre is seriously kicking f'n ass at the moment doing the mayor thing. Very happy with what he's managed to make happen here.
    (PS - thx for the new avatar!)
  23. Jul 2, 2025 at 12:12 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I tried to quote somebody, but I can’t find it… “you don’t need less cars, you need more driveway”
  24. Jul 2, 2025 at 12:45 PM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    IMG_6758.jpg Quick ask for FGT Nation, I had my AC fixed (along with timing belt, water pump, compressor etc..) and the upper rad hose was slipping on the lower end. My mechanic used screw clamps in addition to stock ones to secure the hose and the upper rad plastic cracked. Anyone have any recommendations for radiators?
    OEM junkyard rads? New stock rads? Cheap but totally functional aftermarket rads? Fancy extra cool ones that still fit perfectly with stock brackets/Air Conditioning parts? I’m sure some members have gone down this rabbit hole and I just don’t have time to right now as I’ve got to get it up and running again soon.
    side note, is there anything that could happen during the water pump change that could cause higher pressure than usual on the upper rad hose? Maybe the hose is just worn and needs replacing but I’m curious if there could be higher pressure than before (New oem rad cap also installed).
  25. Jul 2, 2025 at 12:48 PM
    New Denso radiator is the way. If the hose was put on reverse then it could have been in an unusual orientation and not sealed well. Chances are though, the factory clamp has just worn out like mine did.
  26. Jul 2, 2025 at 12:56 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Who’s got a link to the aluminum radiator @BUSTYSLUTS used?
    Bed Tundy likes this.
  27. Jul 2, 2025 at 1:17 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  28. Jul 2, 2025 at 2:25 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I did, and you answered. The search button is for newbs that havent learned the lingo yet.
  29. Jul 2, 2025 at 4:23 PM
    So what’s the best way to get these timing belt cover nuts off? Are they cap nuts? (Hard to tell what they were)
    Will heat melt anything other than the cover it passes through? (Although those wires are pretty close)
    I’m thinking a weeks’ soaking of penetrant, propane heat and some back and forth wiggling.
    I’m not sure of the implications of snapping them off since applying heat may not work given the proximity to the wiring.
  30. Jul 2, 2025 at 4:28 PM
    Order new ones? A few are caps, one or two are cap nut with a stud I think
