  1. Jun 20, 2025 at 3:18 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    Hauschm76[QUOTED] likes this.
  2. Jun 23, 2025 at 10:19 AM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Custom bed rack to go along with the tracks in the new cover.
  3. Jun 25, 2025 at 6:36 AM
    Wwilson01
    Wwilson01 New Member
    Will
    09 Toyota tundra
    Added this 13 sequoia grill today. Had to do some minor configuration to get the top four brackets. ( just used different bolts ) it rides fine but there is gapping at the bottom. I’ve read into some other forums on here about lower brackets for needed for the 07-09 that come on the 10-13. Have yet to find them anywhere but as of now it rides fine. Going to paint match soon.
  4. Jun 25, 2025 at 8:14 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    I know when I swapped my 07 grill I had to replace both brackets. I found some knock-off brackets on ebay that worked with a little persuasion.
    joseph_womack likes this.
  5. Jun 25, 2025 at 2:56 PM
    aelarson
    aelarson New Member
    AZ
    2021 1794 Tundra (Silver Sky Metallic)
    Swapped a bunch of parts off the new to me 2021, got it cleaned up, and . A bitter sweet moment for my Toyota resume!
    She still cleans up nice for 173K miles - someone will have a well equipped Tundra!
  6. Jun 25, 2025 at 3:03 PM
    aelarson
    aelarson New Member
    AZ
    I have used 80/20 for so many projects, your imagination is the limit.
    80/20 is the best...until you need to click "pay now" lol
  7. Jun 25, 2025 at 3:25 PM
    APalmTree
    Brandon
    SW Washington
    True, I was going to buy from them, but I shopped it around after I built my cart and found tnutz.com. It cut the price almost exactly in half which definetly made my wallet happy :thumbsup:
  8. Jun 25, 2025 at 10:15 PM
    aelarson
    aelarson New Member
    AZ
    Good to know, I’ll keep that in mind for my next wild concept I try to make a reality.
    Not Tundra related, but my last 80/20 project was building a freight elevator in my garage!
  9. Jun 26, 2025 at 5:35 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    Ill be cleaning the engine bay but figured I would share the latest thing I did in/to my Tundra.
  10. Jun 27, 2025 at 4:43 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Yeah, luckily the shop I was recommended to managed to get the water out of the engine and she’s running without issue. Only problem now is the transfer case motor needs to be replaced, she’ll go into 4WD when in neutral but not when the transmission is in gear.
  11. Jun 27, 2025 at 4:48 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    At least the motor is good, did you check the diffs and tranny for water as well?
    OldGuy03 likes this.
  12. Jun 27, 2025 at 11:08 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    With the motor being good to go, if it were me I'd be quite relieved. sounds like you came out better than first expected.
  13. Jun 28, 2025 at 4:46 PM
    82nd Airborne
    82nd Airborne New Member
    2012 SR5 DC
    Gave it a makeover. I didn't do the painting.
  14. Jun 28, 2025 at 6:09 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    Looks great!
    Did you go with VLEDs or OEM? I did VLEDS.
  15. Jun 28, 2025 at 6:19 PM
    82nd Airborne
    2012 SR5 DC
    Went with the vlands. How has yours held up?
    07 Tundie[QUOTED] likes this.
  16. Jun 29, 2025 at 6:36 PM
    grant318is
    grant318is New Member
    Connor
    07 RCSB 5.7L 4x4
    Found a topper on my way from GA to VA
    Had to get creative to load it!
  17. Jun 29, 2025 at 6:45 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Replaced snout bearings and coupler in the tvs 1900. Installed Snow W/M direct port injection with nozzle at intake for rotor cooling. Installed Mitch Made billet carrier bearing. Oil change Mobil1 0w-40 Euro spec oil. Antifreeze change with new T-stat.
  18. Jul 1, 2025 at 12:56 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I filled up with gas in Ohio @ 2.69/gal vs 3.59/gal here in Pa., a mere 13 miles to cheaper fuel. Saved almost 20.00 and got an ice cream cone on the way back.
  19. Jul 1, 2025 at 2:13 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    Still holding up great! Hope you like them!
  20. Jul 1, 2025 at 4:03 PM
    RealTruck
    RealTruck New Member Vendor
    Sweet lookin' rack! When you say custom, do you mean you had this fabricated specifically for your setup or you found this from a vendor? It appears to be super lightweight, and by the looks of it your cover works perfectly underneath it.
    APalmTree[QUOTED] likes this.
  21. Jul 1, 2025 at 5:27 PM
    Rexr
    Rexr New Member
    Sam
    Bay Area, CA
    2018 MGM SR5 CrewMax
    Build Page https://www.tundras.com/threads/stage-1-of-my-build-complete-37s-are-on.157611/#post-3916395
    Just bought my 2018 crew max rock sliders from RCI! Today is the day to do it! They are running a 4th of July sale with everything on their website being 20% off. I also got an addition 5% off since the order was over $1000. Cant wait for them to arrive and go onto the rig
  22. Jul 1, 2025 at 6:06 PM
    APalmTree
    Brandon
    SW Washington
    Custom is a bit of a generous description of what I did:rofl:. Basically, it is just generic aluminum extrusions that you can purchase from many different vendors. The most popular and well-known being 80/20 (https://8020.net/), or Tnutz.com that I bought from, and many others. I just needed a tape measure and a bit of imagination to come up with what I wanted it to look like, and then I ordered sections cut to whatever length I specified and picked connectors to go with it.
    My inspiration was the Xtrustion Overland XTR1 rack, but they did not have an option to do the low rack that I wanted, their starting price is $1,500, and any options just go up from there. I also was not convinced that any angle on the rack would work with the roll-over design of the Bak Revolver, so I opted for straight vertical legs on the one I built. My final out the door price, after the painful $90 shipping fee, was $415 and the shipping weight was only 26 lbs :eek:
  23. Jul 1, 2025 at 7:43 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    2008 Double Cab 5.7L
    I had some minor damage that happened a few weeks ago, so I had to replace the lower valance on my front bumper. I liked the look of the 2010-13 valance but couldn't find any confirmation that it would fit my '08. The bumper part number was the same even though the valance wasn't, so I rolled the dice. Discovered that it's a direct bolt-on replacement, so if you ever want to upgrade your early 2nd gen with the later 2nd gen valance, it will work. Bumper removal was necessary, headlights were not. But I took them out because I'm also planning to sand off all the yellow, do a full restoration and clear coat on them. Also want to replace my grille since it has some cracked off chrome. Replacing one part has turned into a larger facelift project...
    Medicineman and RealTruck like this.
  24. Jul 1, 2025 at 8:15 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    At least you had some change for ice cream. WA just hiked another .06cents a gallon for their gas tax. 3rd highest in Conus. Gotta love it!
  25. Jul 4, 2025 at 4:07 AM
    sctomfar
    sctomfar Chasing 700RWHP
    Tom
    Bluffton, SC
    Supercharged Reg cab
    Harrop 2650 supercharger TRD suspension TRD intake Custom exhaust Dirtydeeds cross pipe Fully built bottom end motor Manly Rods Crowder Pistons ARB Stud Kit National Speed Tuned Redesigned fuel system XAT Fuel Rails Twin Demon Fuel Pumps 83cc Injectors Morimoto Headlights
    Just got put bell tech kit on and track bars
  26. Jul 4, 2025 at 4:07 AM
    sctomfar
    Tom
    Bluffton, SC
  27. Jul 4, 2025 at 4:08 AM
    sctomfar
    Tom
    Bluffton, SC
  28. Jul 4, 2025 at 3:11 PM
    joseph_womack
    Joe
    Louisiana
    That thing is slick!!
  29. Jul 4, 2025 at 4:58 PM
    Jjclamdips
    Jjclamdips New Member
    Wichita, Ks
    2008 Limited Double Can 2WD
    Just bought an 08 Limited and removed the plastic bed liner. Ended up cutting it with a razor knife and took it out in three pieces.
    koditten and French Avocado like this.
