General Supercharger Thread
  1. Jul 1, 2025 at 8:37 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    Current : Magnuson S/C 5.7 FFV, Tundra CM, SNIV tuned w/HP Tuner, SG-1 Wide band AF w/gauge, TRD cat back, slotted and drilled rotors, stainless brake lines, TRD pads front and rear, front OEM Sport sway bar, rear TRD sway bar, 38 gallon OEM fuel tank, Tesla screen, ham radio, 2.5 Icons w/ res front and rear. X2 battery w/Voltage Booster Pro 2014 OEM wheels. 17.2 MPG on road trips https://drive.proton.me/urls/Y8739Z14BG#HCVT8AowG9fl ---------------------------------------------------- Previous: 2002 Tundra AC 2wd... Converted to OEM 4wd , S/C 4.7, TRD exhaust. 35's w/4:88's, too many other mods to list. https://drive.proton.me/urls/SWEWY4AFMC#eC7zX57Ex6pI ---------------------------------------------------- Other: 1967 mustang , Blown 408, 671Mike Kuhl 12.5% overdriven, 300shot NOs 5 speed TKO600, 4:11's Ford 9", Detroit Locker (real) Evans Coolant, Twin 12" Spahl fans https://drive.proton.me/urls/ABBVY3TQ3M#OT9LceyNwbTy ---------------------------------------------------- 2015 4runner TRD drop in filter Prinsu 1/2 roof rack, Nfab side steps, TRD FJ lift kit. ---------------------------------------------------- 2007 Prius 45mpg+ ... It's the only way to afford fuel for these Beasts!
    I only have the TRD cat back..
    My PSB-1 sensor we located right near the OEM sensor, this picture is the passenger side exhaust pipe.
    e30cabrio, Wynnded, Jego and 6 others like this.
  2. Jul 1, 2025 at 8:40 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Passenger side by the heater block on the trans
    e30cabrio, Mdl, snivilous[OP] and 3 others like this.
  3. Jul 1, 2025 at 8:41 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Easy access above the cat shield to the cab via plug grommet
    e30cabrio, HulkSmurf14, Mdl and 2 others like this.
  4. Jul 1, 2025 at 8:47 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Nice, thanks for the detailed pictures! Assuming the right way to do this is to remove that Cat Pipe assembly and just bring it to my welder of choice.
  5. Jul 1, 2025 at 8:49 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Best way yea- some have been able to get it welded while on the truck but not ideal. Also be sure to sink the bung in slightly to ensure the sensor is in the airstream since the exhaust there is double walled.
  6. Jul 1, 2025 at 8:53 AM
    mustang67408
    Victor
    Yes, removing the pipe gives you good access and your able to clean the pipe for a good weld. I cut the bung in 1/2, that way the sensor went deeper like @reywcms said.
    Mdl, snivilous[OP] and reywcms like this.
  7. Jul 1, 2025 at 10:06 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Yeah, I think they make stepped bungs to get better insertion into the pipe
    e30cabrio and HulkSmurf14 like this.
  8. Jul 1, 2025 at 10:09 AM
    JohnWhicker
    JohnWhicker New Member
    This is exactly what I was looking for. I may just go with the GCS kit since is bolt on, I hope. This is a high risk job and I want to make sure it gets done right so paying the extra $$$ is worth it for me.
  9. Jul 1, 2025 at 11:00 AM
    AZTundra
    Paul
    Phoenix, AZ
    Here is the gasket part number if removing the mid pipe for the bung installation. I was getting some lean readings which could have been coming from a slight gasket leak at the front flange. Toyota says they are a one time use item. I’d recommend throwing two new gaskets in if you are pulling the pipe.
  10. Jul 1, 2025 at 11:23 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Great, thanks!
    e30cabrio likes this.
  11. Jul 1, 2025 at 11:58 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    About 10” will clear the double wall…. Don’t recall how close this was to the converter. I always wondered if the insulated dual wall pipe also offers some anti reversion.
    e30cabrio, Mdl, mustang67408 and 2 others like this.
  12. Jul 1, 2025 at 12:01 PM
    centex
    centex New Member
    Helps keep velocity up to keep exhaust flowing and not backing up and hurting power. Probably what you meant but my spreadsheet weary brain can't define complicated words like anti-reversion at the moment.
    Tripleconpanna, e30cabrio and Mdl like this.
  13. Jul 1, 2025 at 12:15 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    Yes, anti reversion keeps things from going back up the pipe.
    e30cabrio, Mdl and reywcms like this.
  14. Jul 1, 2025 at 12:26 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I've put a few sensors in through the double wall and didn't have issue. As I recall some trucks are single wall and some are double wall in that area. I like clocking it right next to the stock sensor, it's easy to reach, easy to mark where to cut with the exhaust on, and you can be confident the stock and wideband read the same so the results can be correlated. Regardless of the wall setup, I cut the bungs in half (at least the one included with the Innovates) since the bung shields the end of the sensor at full length not including any wall thickness from the exhaust. This picture is an Innovate bung cut in half:
    Which results the sensor well into the airflow like the stock sensor:
  15. Jul 1, 2025 at 12:30 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's what Keith mentioned back on Tundratalk when he was going over the exhaust setup.
    Man too many bookmarks from 13 years ago... he talks about true duals, x-pipes and pipe diameter to help keep the torque lost with some setups.
    ZPhilip, mustang67408 and HulkSmurf14 like this.
  16. Jul 1, 2025 at 1:23 PM
    mustang67408
    Victor
    Feels like Christmas :bananadance::bananadance::bananadance:, Damn that was fast
    Mdl, bflooks and HulkSmurf14 like this.
  17. Jul 1, 2025 at 1:28 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    did a shop custom fab that shroud for you?
    I'm interested in one if you have a link, I've had the fans sitting around for awhile to do something like this but that shroud is sweet.
  18. Jul 1, 2025 at 1:47 PM
    mustang67408
    Victor
    No, a very good friend who is a fabricator did this for me.
    Ryuu[QUOTED] and Mdl like this.
  19. Jul 1, 2025 at 1:51 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    a few
    oh that's cool :fistbump:
    If he'd be interested in fabricating another one to sell do let me know :)
    mustang67408[QUOTED] likes this.
  20. Jul 1, 2025 at 1:51 PM
    mustang67408
    Victor
    I'll ask him... And let you know.
    Is your intercooler the stock Magnuson one?
    M3Tundra-JK, Ryuu[QUOTED] and Mdl like this.
  21. Jul 1, 2025 at 1:51 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Guess I really needed a new carrier bearing. Out cruising and driveline is smooth with the Mitch Made carrier bearing.
    ARES35, HulkSmurf14, ZPhilip and 10 others like this.
  22. Jul 1, 2025 at 1:53 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Boom!
  23. Jul 1, 2025 at 2:49 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  24. Jul 1, 2025 at 5:23 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    Sweet..finally. Reached out to my vendor as well and he got a few Whipple kits in, so I'm assuming mine is in too. Thanks for posting!
    No Whipple for me until after the 4th.. so close.
  25. Jul 1, 2025 at 9:55 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    7.3 test tow. Said things a beast. They’re going to haul the trailer to Tennessee next week. They ran the truck up to Cali and back already got a 1000miles to break in the gears before the long haul.
  26. Jul 2, 2025 at 12:22 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I've been debating running engine hood louvers or just a screen for out flow of hot air just above the radiator. I saw tracspec has a louver for the Honda civic which is 7x22 and fits nice between the tundra radiator and supercharger. Which is a perfect area to draw hot air out. I can keep the major hood supports. Just need to see about fabbing a rain diverter in winter to keep it to clear flowing at the radiator opening above the e-fan in winter.
    M3Tundra-JK, Jego, reywcms and 2 others like this.
  27. Jul 2, 2025 at 6:37 AM
    nags
    nags New Member
    So apparently the first person on the waiting list for the new Whipple via XAT has received it. Crazy that it wasn't my dude as he's at a year of waiting this week. Can't imagine how long the other dude has been waiting.
  28. Jul 2, 2025 at 6:42 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    That's a rough deal...I'd be seriously considering other options on principle, alone!
    ZPhilip, Mdl, Tripleconpanna and 5 others like this.
  29. Jul 2, 2025 at 7:06 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    That’s wild.
    nags[QUOTED] likes this.
  30. Jul 2, 2025 at 9:47 AM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    I am in a similar debate. I found on Ebay some custom size vents that I think can be installed between the hood supports using 3 custom size vents.
    https://ebay.us/m/WBtC30
    mustang67408 and Mdl[QUOTED] like this.
