Transmission Temperatures on 2019 - 2021 Tundras
Discussion in '2.5 Gen Tundras (2014-2021)' started by TRDSport888, Jun 28, 2025.
  1. Jun 28, 2025 at 7:31 AM
    TRDSport888
    TRDSport888 [OP] New Member
    Ivan
    Tint
    I know people ask this all the time, but I recently purchased a 2021 Tundra TRD Sport. I don't tow, but go to the mountains about 2x a year. I know this one does not have a transmission cooler. Just curious for those who don't tow what the average transmission temperature you get and the highest transmission temperature you've seen.
    Thanks!
  2. Jun 28, 2025 at 7:49 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Depends but people report as high as 230 unloaded. I would just do the upgrade for peice of mind and longevity. Plus....mods are fun lol.
  3. Jun 28, 2025 at 8:00 AM
    My max readings while towing 8k# in S4 through hilly Arkansas terrain in my 2019 CM Limited TRD OR on stock tires no lift.
  4. Jun 28, 2025 at 8:26 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    This is all not towing, but these are max pan temps I saw loaded up to max payload at a 95F or higher degree day or so.
    Before cooler, 220F-ish in the mountains. It would float between 210-220F on average.
    Then put a cooler on at about 500miles on the odometer.
    With cooler, 201F.
    With cooler and pinned thermostat, 185F. Can do 85mph into a 20mph headwind and it won’t budge over that temp.
    Stock wheels/tires and bed cap that’s about 6” higher than the cab roof.
  5. Jun 28, 2025 at 8:31 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    i was 230 unloaded in houston all the time
    175 now
    pinned open
  6. Jun 28, 2025 at 10:40 AM
    Unloaded 6th gear cruising
  7. Jun 28, 2025 at 11:25 AM
    Fitzf15E
    Fitzf15E New Member
    2021 Limited DC TRD OR Cement
    Henry1jg and Tripleconpanna like this.
  8. Jun 28, 2025 at 2:40 PM
    TRDSport888
    Ivan
    Tint
    Thanks everyone. Has anyone heard of any transmission failures in the 2019 - 2021 Tundras? I'm hesitant to get a cooler if she's gonna run good without. I can't find anything on the transmissions actually failing.
    MadMaxCanon likes this.
  9. Jun 28, 2025 at 2:47 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Cooler is always better. Fluid breaks down. Why not have it run better and not worry about temps at all? Get a cooler.
  10. Jun 28, 2025 at 2:51 PM
    Tundrav82019
    Tundrav82019 I have all the duckies
    Leo
    2019 Tundra Limited TRD Off Road
    I have a 2019 tundra Crewmax. I tracked temps around town no towing, 225 F very common.
    put in the cooler by nick advertised in here, barely break 190 now. Fantastic upgrade, almost all OeM parts. Came with a free cooler tracker like the pictures you see above. Couldn’t be happier with it!
    Had a local shop install since I am not mechanically inclined.
    expensive but thought worth it for long term and I plan to tow so it was a easy choice for me
    Here is link to item I bought
    https://genuinecoolingsystems.com/
    y
    ou can build one yourself, but I was not inclined to
  11. Jun 28, 2025 at 3:30 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    I haven't heard of any failures let alone a trans over temp lite. Once you start monitoring transmission temperatures you can make your own decision or just send it as is. Cooler will make a remarkable difference and I have one.
    I've seen 240 TC temp up Utah mountains towing but cools rapidly to pan temp when TQ locks back up usually 20-40 degrees lower depending on distance up grade.
  12. Jun 28, 2025 at 6:26 PM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
  13. Jun 28, 2025 at 6:42 PM
    Tundrav82019
    Leo
    I think if you plan to keep it a long time then do it. If you’re gonna change it out in 5 years don’t worry about it.
  14. Jun 28, 2025 at 7:31 PM
    MadMaxCanon
    Too early to tell. But it can only be worse than having one.
  15. Jun 28, 2025 at 8:25 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Watched this the other day.
    I tossed a huge cooler on mine soon after purchasing, with the thermostat I usually max out at 195-199f. I just pinned it open, will find out this weekend what it looks like now ;).
  16. Jun 29, 2025 at 12:44 PM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    I typically see 195-205 depending on outside temp in my day to day driving from work. 22 miles each way backroads and interstate. No cooler
    NyCSnEaK and TRDSport888[OP] like this.
  17. Jun 29, 2025 at 1:47 PM
    yakeng
    yakeng 3URFE Apologist
    Same, 220-230 in H-Town traffic. After cooler, 185-195.
  18. Jun 29, 2025 at 2:22 PM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    2021 with a 3/2 lift and 35” tires, i was seeing 220+ just driving around town. Now i do S4 in town and S5 on the highway which keeps my temps way down, i don’t plan on towing so this strategy works for me. I’ll get a cooler if i ever do need to tow.
  19. Jun 29, 2025 at 7:12 PM
    Tundrav82019
    Leo
    At the end of the day, if you’re asking us about it, I would just say do it. Pay the money for a quality part and have it professionally done unless you can do it and feel confident
    _none_ and Tripleconpanna like this.
  20. Jun 30, 2025 at 8:15 AM
    Rakkasan
    Rakkasan New Member
    NorCal
    2020 Tundra- cement-crew max 4x4
    Spray in Bed liner, 2-10”subs/400w.amp, tailgate shock, Tinted windows, seat covers, dash cover, CatShield, Fuel D538 20”wheels, Husky custom floor mats, TSC tool chest, leather seat covers. Genuine Cooling systems transmission cooler, scan gauge OBD2
    I added a cooler to my 2020 SR5 CM, I haven’t towed anything yet but I had seen temps over 200 which isn’t bad at all but I figured it’s the smart play for the transmission. I don’t believe I have seen over 200 after I installed the cooler but I only drive the Tundra a couple times a month. That will change after my F250 diesel sells. Here is a pic of the instal and also post cooler temps.
  21. Jun 30, 2025 at 9:28 AM
    TRDSport888
    Ivan
    Tint
    Thanks everyone for the info! Greatly appreciated. Still haven't decided if I'm gonna get the cooler yet. I got a scangauge 3 coming this week. And I'll see what the temperatures are when I go to the mountains then I'll make a decision.
    Tripleconpanna likes this.
  22. Jun 30, 2025 at 11:10 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Driving habits, especially paying attention to TC lockup has a big impact on temps too.
    2019 no cooler yet, I think the highest I've seen was 239º while towing, that was pushing it pretty hard on I-8 West coming up out of the desert at the Imperial / San Diego County line. Those of you familiar with this grade know what I'm talking about. It's a nasty one. Two lanes, steep and curvy, you either stay with the flow or get stuck behind someone struggling at 35MPH.
    Normal towing on flats in S4/TH she settles in at around 210º-212º. Will get up in the 220's on most grades than drop back down once I crest.
    Daily driving it's rarely higher than 205º-210º
    So far the temps I'm seeing are not too alarming. My trailer is only 5,500 lbs. and we don't go as far or as often as I'd like.
    If temps or travel frequency changes I may add one, but for now I'll do drain/fills on a "severe duty" interval every 30K and continue to monitor.
  23. Jun 30, 2025 at 12:39 PM
    TRDSport888
    Ivan
    Tint
    Thanks
    Love the view!
    SD Surfer[QUOTED] likes this.
  24. Jun 30, 2025 at 1:37 PM
    SD Surfer
    Bruce
    So Cal
    Yeah, that one was pretty epic.
    Between my wife and I we probably took 40-50 pictures of that sunset as it changed from red to orange to purples.
    Pictures of her taking pictures of the sunset. :rofl:
  25. Jun 30, 2025 at 3:43 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    Last year, I was running the same set up as below and my temps were upwards of 238-246ish. I didn't feel too good about this so I took the advice of the Car Care Nut (YouTube) and had my transmission fluid changed out at 57k miles.
    We tow a travel trailer all over the north & south east of Texas. Our trailer is about the right size for the Tundra (IMHO) which sits at 6995 lbs max though we currently sit at 6180 lbs loaded. Our towing temps via a scan gauge is around 211-221ish in S4 & tow haul mode activated.
    Now, our main use of the Tundra is towing our trailer with the exception of a couple of runs around the property when the truck is needed. I tossed the idea of a cooler since '21, but I figure if I keep an eye on the temps and do regular maintenance, I should be fine. Maybe when the warranty ends, I will consider a cooler, but for now....I am running naked. lol
  26. Jun 30, 2025 at 6:26 PM
    TRDSport888
    Ivan
    Tint
    Maybe more frequent drain and fills on the transmission is the key maybe every 20000 to 30000 miles. That might do the trick. I don't know why I keep trying to find a reason not to get a cooler lol....
  27. Jun 30, 2025 at 8:20 PM
    SD Surfer
    Bruce
    So Cal
    I bought mine as a CPO (1 lease turn in) w/20K miles. No idea how it was driven or if it towed.
    I did the first drain and fill at 30K miles, having towed some. My mechanic said the fluid was discolored but by no means burnt.
    KingsAustin likes this.
  28. Jul 1, 2025 at 6:25 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I'm essentially mirroring these temps with my 8000lbs trailer on the opposite coast. Your daily driving mirrors a lot of what I see as well, specifically with highway speeds since anything under 60MPH really drops the temps down to the 180s & 190s, but highway or towing puts me at 200-210. This truck has historically run about 10-20* warmer than everyone else posts about. Glad to see someone else with a 19 is seeing similar temps.
  29. Jul 1, 2025 at 7:07 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    My transmission runs so hot my employer has asked me to heat treat some of their mat'l as a side job.
  30. Jul 2, 2025 at 8:32 AM
    mgrs
    mgrs New Member
    '20 OR
    Makes a big difference. Keeping it in S4/TH keeps it manageable even with a 30ft/5600lb dry travel trailer. Usually 210 or so.
    Even with no tow, temps can climb alarmingly pulling mountain grades at highway speed in D. Up to 260TC/230-240 at the pan. Drop it in S4 and it will settle back to just over 200.
