  1. Jun 30, 2025 at 6:41 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    I'm needed to get back in the woods like that!!
  2. Jun 30, 2025 at 7:21 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    Sound deadening makes a huge difference. I wouldn't pay $400 for a kit unless there was a reacharound leading to a happy ending. I think I had less than $200 in my deadening of all four doors, and the back of the cab.
  3. Jun 30, 2025 at 8:27 AM
    COTundra23
    COTundra23 New Member
    how were the temps?
  4. Jun 30, 2025 at 8:33 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Ranged from high 70s to low 80s during the day, high 60s at night. Perfect weather
  5. Jun 30, 2025 at 8:44 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    New o2 sensors ordered, new SPD muffler being sent. Need to order the new Wideband sensor. Hopefully the rear suspension stuff arrives soon and then consolidate all the items for the next pallet shipment.
    Also want to give a shout out to LSK. RCV is delayed again so LSK is sending their axle shafts out at no charge in the meantime. Those shafts should arrive today.
    Corndog123, Mdl, bulldog93 and 6 others like this.
  6. Jun 30, 2025 at 12:23 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Installed a spacer on the carrier bearing today to try to squash some small vibrations at speed and when taking off from a start with a trailer. Had fun as one of the welded nuts broke free...a 15mm open end wrench and an impact gun and it came off without much fuss. Replaces the square welded on nut with a regular 17mm nut and went on with life. When the other side breaks loose ill do it there as well.
  7. Jun 30, 2025 at 1:40 PM
    Fergie
    Fergie New Member
    Both of mine broke loose when I was doing the same project. Same fix and the drop got rid of the vibration. Eventually replaced the carrier bearing too.
  8. Jun 30, 2025 at 3:11 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    RCV axle shafts arrived. Be nice have spare axles laying around once they send the full units.
    Tripleconpanna, SAGE63, BR73 and 5 others like this.
  9. Jun 30, 2025 at 8:04 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Did the vibrations stop?
  10. Jul 1, 2025 at 6:04 AM
    birdman076
    Chuck
    Montana
    It didn't stop entirely, however it did improve. I have multiple issues going on. Long story short I had tires mounted at Walmart ( I know, but there aren't many options here that aren't a 2+ hour drive for me). They installed the tires all wrong, heavy side on the same side as the valve stem, etc. Getting new tires shortly so i'll deal with that then. The driveline vibration I attacked in multiple ways.
    1. Greased the Drive shaft (it looks like it was never done and I bought it at 68k and now have 118k on the clock). Wasn't aware it was serviceable until recently.
    2. Carrier bearing drop (this took out what I would call the "Annoying vibration". More noticeable when towing anything, even an empty trailer. Vibration anywhere from 10-30mph when going from dead stop). Slight vibration at 70mph which moved to 50mph and less severe after the carrier bearing drop. I would say its worth doing, took all of 10 minutes even with breaking the welded square nut loose on the one side. I used a lug nut and 2 lock washers on both sides to give me 3/4" of space. I can't abide spending good money on overpriced metal when I have free metal laying around...
    Other suspension issues i've dealt with recently:
    1. I blew the passenger shock over winter so I replaced both front and rear shocks and dumped the spacer lift. (this helped immensely with the tire issues above, a band-aid albeit a damn good one).
    2. Sway bar bushings went out about a month ago. I swapped to poly bushings and am working on replacing the end links with heim joints.
    3. Warped front rotors. I tow a lot and we live in a mountainous region. The warped rotors were contributing to the front end shake as well. I replaced them with Bendix Fleet Metlok rotors and couldn't be happier.
    Each of the steps took care of a little of the drive line vibration(s) as well as the front end shimmy, wobble, shake(s). Still plugging away at it and I think i'm about there in terms of once the new tires go on with a road force balance it will be smooth as it can be.
  11. Jul 1, 2025 at 6:48 AM
    thetastelingers
    thetastelingers Master Baiter
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    You crossed that log. Right? Cause that's the first thing I would have done.
  12. Jul 1, 2025 at 6:53 AM
    Unbound
    Unbound New Member
    2021 Toyota Tundra SR5
    Just put in the order for RCI rock sliders, full steel skid package (engine and trans), and cat guards. Wasn't sure i'd see a better discount from them so pulled the trigger.
    I waffled back and forth on steel vs aluminum, figured I couldn't go wrong with steel.
    TacomaTRD4x402 and BR73 like this.
  13. Jul 1, 2025 at 7:05 AM
    300BLK
    300BLK New Member
    You'll be happy with that setup. I love mine. One of those things that you don't really notice until you hear a rock slamming into them and think "thank God I had those".
  14. Jul 1, 2025 at 12:13 PM
    Cane Pazzo
    Cane Pazzo New Member
  15. Jul 1, 2025 at 12:16 PM
    JohnWhicker
    JohnWhicker New Member
    You're not missing anything. With that safe you will be dead by the time you manage to open it :) bang bang BANG :)
    HulkSmurf14 and BR73 like this.
  16. Jul 1, 2025 at 12:47 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    HulkSmurf14 likes this.
  17. Jul 1, 2025 at 12:49 PM
    centex
    centex New Member
    I'd love to hear the explanation for why there are two part numbers depending on flex or non-flex for a PCV.
  18. Jul 1, 2025 at 1:34 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Same here :popcorn:
    I ordered the -38030 one for my non flex. Truck hasn't blown up yet. Hope it doesn't.
    HulkSmurf14, BR73 and RobertD like this.
  19. Jul 1, 2025 at 1:49 PM
    koditten
    Kirk
    Midland of the Mitten
    It's so you can't go full send on the plug and strip it. .5 ugga, duggas. No more!
  20. Jul 1, 2025 at 2:28 PM
    TreeCat
    TreeCat New Member
    2017 White Limited 4x4
    Replaced the inner and outer tie rod on my passenger side. Neither tire shop nor dealer could break loose the jam nut to complete an alignment. Dealer wanted $960 to replace it. Nope nope nope. Tried my hand at replacing it myself, first time. Used OEM parts. Dealer had good price on the outer tie rod (45046-09560) the inner was expensive. Found it on Amayama (45503-0C030) which was way cheaper even with overnight shipping from Japan (any Fast and Furious 1 fans here?).
    Because the outer part was stuck, I couldn't remove the inner's boot and had to just pull it back while trying to grip it with a pipe wrench. Thankfully it broke free pretty easy. Still had to get the boot off though if I wanted to reuse it. Used cutoff wheel to cut the outer part off and slide the boot out. New parts went in easy. Took it back to the dealer the next morning and had them finish the alignment. Thankful it's done!
  21. Jul 1, 2025 at 2:51 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Did the exact same thing a couple of weeks ago. Such a pain in the ass.
    Edit: I heard Hector is gong to be running 3 Honda Civics with spoon engines.
  22. Jul 1, 2025 at 3:13 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    and on top of that, he just went into Harry's and bought three T66 turbos with nos, and a motec exhaust system.
  23. Jul 1, 2025 at 3:40 PM
    Apohl17
    Apohl17 New Member
    AJ
  24. Jul 1, 2025 at 3:47 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    :fistbump:
    Corndog123 likes this.
  25. Jul 1, 2025 at 5:28 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Swapped out this crusty SOB today and got a coolant drain and fill in at the same time, it was fun
  26. Jul 1, 2025 at 5:33 PM
    Rexr
    Rexr New Member
    Sam
    Bay Area, CA
    2018 MGM SR5 CrewMax
    Build Page https://www.tundras.com/threads/stage-1-of-my-build-complete-37s-are-on.157611/#post-3916395
    At how many miles on the odometer did you notice the leak?
  27. Jul 1, 2025 at 5:37 PM
    Yota303
    Washington
    Probably right around 85k if I remember correctly, I had been putting it off for a while and just rolled over 100k
    rdiddy5 and BR73 like this.
  28. Jul 1, 2025 at 5:55 PM
    Corndog123
    Sam
    Tennessee
    Nice!!
  29. Jul 1, 2025 at 6:17 PM
    Bowzer
    Bowzer New Member
    After tempting incentives on some new RAMs, Gladiators, and Tundras...Made the call to hold on to the 2019 SR for another year. Grabbing some parts and new set of tires over the 4th of July sales.
    (Yes...actually considered the RAMs and Gladiators as replacements. I've had a couple of RAMS without issues (just gotta know what to watch and do) and a Gladiator cause...well, just dang fun and I don't need the heavy pickup capacity that much anymore. I have resisted the urges to live another day!)
  30. Jul 2, 2025 at 2:37 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Who makes the flatbed? Rough cost? I'm wanting to do this but I think its above what I want to spend to do it.
