  1. Jun 29, 2025 at 7:20 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    I'm contemplating the same.
    HulkSmurf14 and BR73 like this.
  2. Jun 29, 2025 at 7:23 AM
    Corndog123
    Sam
    Tennessee
    Oh man....
    HulkSmurf14 and reywcms[QUOTED] like this.
  3. Jun 29, 2025 at 11:11 AM
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    Out with the old, in with the new. Can absolutely tell a difference in airflow
  4. Jun 29, 2025 at 11:19 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    hell yea!
    Corndog123 likes this.
  5. Jun 29, 2025 at 11:25 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
  6. Jun 29, 2025 at 11:34 AM
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
  7. Jun 29, 2025 at 12:06 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Update. Let’s play a game. In the picture attached, is that engine oil or 103k transmission fluid? I’ll give you all a hint, it’s not engine oil. Pulled out about 3.5 quarts. Put in 4 quarts and realized when I got to temp, my check plug is rusted and round so I can’t get it off. Any ideas? Or send it.
    Tripleconpanna, bulldog93 and BR73 like this.
  8. Jun 29, 2025 at 12:20 PM
    Corndog123
    Sam
    Tennessee
    Spray it down with PB blaster and let it set for a minute. Clamp a set if vice grips on the as tight as you can get them. Use a hammer on the vice grip to break the rust loose. If you have a blow torch, heat around the bolt of course being careful not to start any fires. It may take several applications of each to get it loose.
  9. Jun 29, 2025 at 12:25 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I’m an idiot. It’s a 5mm Allen :anonymous:
  10. Jun 29, 2025 at 12:33 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
  11. Jun 29, 2025 at 1:29 PM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    Installed the FRAC harness today. Took longer than expected since i had to extend the wires for the switch and the local home improvement stores don’t carry 20awg wire . So the interior was torn apart for a day while i awaited my Amazon shipment of wire.
  12. Jun 29, 2025 at 1:49 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    That’s what I’m going to do. Even after spraying it with pb and letting it soak then using an alley key, it’s rusted and rounded with barely any pressure.
  13. Jun 29, 2025 at 2:04 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    You may can get a pair of vise grips on it enough to get it off
    Corndog123 and bulldog93 like this.
  14. Jun 29, 2025 at 2:05 PM
    Backroadgee
    Backroadgee Well Known Member
    west
    Missouri
    SDHQ BAJA ADD PRO SKID PLATES
    Did you ever figure this out?
    Jaypown likes this.
  15. Jun 29, 2025 at 2:05 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Yep just got it off that way. Worked since it wasn’t super tight. Just an awkward angle. Ended up draining about a half quart through it.
  16. Jun 29, 2025 at 3:27 PM
    Corndog123
    Sam
    Tennessee
    Yaaaaay!!! I've had the same problem, that's how I know it works!
  17. Jun 29, 2025 at 3:39 PM
    It's the stealth spare tire mount.
    HulkSmurf14, Corndog123 and BR73 like this.
  18. Jun 29, 2025 at 3:57 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Nice! I’m definitely doing another DnF soon so I’ll replace that plug then
  19. Jun 29, 2025 at 4:03 PM
    Bowzer
    Bowzer New Member
    Figure I'm headed this route before end of year. OEM fan bearings are making a bit of noise this past month.
    woods, BR73[QUOTED] and Patch999 like this.
  20. Jun 29, 2025 at 4:09 PM
    Corndog123
    Sam
    Tennessee
    Sounds good buddy!!
    Jaypown[QUOTED] likes this.
  21. Jun 29, 2025 at 4:55 PM
    COTundra23
    COTundra23 New Member
  22. Jun 29, 2025 at 6:51 PM
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    Looks great with a red body!
  23. Jun 29, 2025 at 8:09 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    For good reason!
  24. Jun 29, 2025 at 8:18 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Didn’t get any pictures but I did the 200ish mile bolt check on all my new suspension components. I felt a little clunk while driving, and it turns out that my UCA bolts need a couple more turns after settling. With everything torqued back down to spec the front end feels super tight, in a good way. Now I just gotta paint mark all the nuts to make it look super extra race truck official.
    bulldog93, Corndog123, woods and 3 others like this.
  25. Jun 29, 2025 at 9:18 PM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    NSB
  26. Jun 29, 2025 at 10:39 PM
    pkeawe809
    pkeawe809 New Member
    PK
    Westside, Oahu
    2018 Super White TRD 4x4 CrewMax
    ~Chrome Delete interior AJT/Tuff skins ~Driver side Grab handle OEM ~Revesol Leather Steering Wheel ~Front Console upgraded to Limited Leather Trim ~Switched Center Instrument panel from silver to black ~Switched black molding trim pieces to Wood grain ~Wood grain Shift Knob ~LED interior lights- meso customs ~Husky X-act Front Driver and Passenger Floor-mats ~Clazzio Seat covers ~Pedal Commander ~Front Windshield heat protection clear film ~VLEDS Footwell LED light kit-driver and passenger sides ~ESP Under Rear Seat storage bins ~4- Door Speakers- JL C1-650 component speakers ~Front Dash Hertz Speakers ~Zapco ST-4X DSP III 100Watt Component Speaker Amp ~Zapco ST-500XM II 500Watt Subwoofer Bass Amp ~1-Rear 10” Subwoofer and Box enclosure ~Sail panel speakers-Hertz tweeters ~Noico 80 mil Sound deadener on all 4 door panels ~Morimoto Headlights-amber DRL ~Diode Dynamics SS3 Pro Foglights ~OEM Tail lights Hot Tails” option A upgrade by Hot Shot Offroad ~Anytime Front and Rear Camera-Trail Grid Pro ~Precision LED lights-rear bed light, lic plate light ~Retrax Pro XR Bed cover ~Auto Rear tailgate lock OEM ~Repaired rust spot and Repainted Roof 7/22 ~De-badged and removed Stickers ~TRD Dual Exhaust w/black chrome tips ~Valhalla Cat Security Shields-Black powder coated ~Black powder coated TRD skid plate ~Red powder coated front Tow Hooks ~Coachbuilder +2 Shackles 1.25” lift ~TRD Pro Grille ~TRD Pro Skid plate ~TRD front/rear Sway Bars ~Bilstein 6112 front shocks ~Bilstein 5160 rear w/resi ~Nitto Ridge Grapplers 35x12.50R17 ~Icon Alloys Rebound Rims 17x8.5 ~Window Tint
  27. Jun 30, 2025 at 5:58 AM
    Corndog123
    Sam
    Tennessee
    BR73 likes this.
  28. Jun 30, 2025 at 6:28 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    I finally, got to the point where I was able to install my modified rear fog/"dust" lights by using the HotTails kit. In typical dad fashion, I didn't take any pictures of the process.
    It involved a modified fog light harness I got off Amazon, a rear fog switch from Air On Board USA, the HotTails kit, and some LED bulbs. I will take some pictures of the function. It's not as clean as Rainman would have done, but with a looming wife and limited electrical knowhow, I think it came out alright. My only issue is I can't get the switches to function the way I want. This is in conjunction of the heated steering wheel switch.
    Ideally, I would like the switches to light up with the dash light, then have the indicator light turn on when the accessory is active, but I don't think I have the right amount of folds in my head or tools to make that happen.
    Edit: Oh, and I had to JB one of the metal stays on the tail light since it had broken off at some point of me messing with them numerous times over the years. I'm waiting for that to cure/harden to complete the assembly.
    Tripleconpanna and Corndog123 like this.
  29. Jun 30, 2025 at 6:39 AM
    Corndog123
    Sam
    Tennessee
    You did a good job! I like that sort of thing! :)
    Tripleconpanna likes this.
  30. Jun 30, 2025 at 6:39 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Did another trip to the Chattahoochee National Forest over the weekend. Found an awesome site right on a stream.
