Having a misfire but can't locate anyone with same problem
Discussion in '1st Gen Tundras (2000-2006)' started by Chris.m, Jun 19, 2025.
  1. Jun 28, 2025 at 7:20 PM
    #61
    Dustdog
    Dustdog New Member
    01, 05 AC 4wd
    stockers
    resistance is going down as temp goes up.
    A good trick is to also test it in a bowl of ice water as you know that will be 32F. Its possibe for thermistors to be good at a particular temp but be out of whack compared to their design curve. So having multiple readings is a good idea.
    Although Im not sure how the coolant temp is leading to a misfire on only one side.
