2025 Tundra Engine is down!
Discussion in '3rd Gen Tundras (2022+)' started by Tarikah, Jun 26, 2025 at 2:49 AM.
  1. Jun 28, 2025 at 4:46 PM
    #211
    Breathing Borla
    Northern Illinois
    just drive and be happy man
    if you have any worries, hit up the warranty thread here, it’s cheap and just go
    boost on
    WindChillYeti75, Mallcrl and GODZILLA like this.
  2. Jun 28, 2025 at 4:50 PM
    #212
    guru
    guru the one and only
    thanks man. that's what i finally told myself. i'm lucky enough to work from home so its not even a huge issue for me to be down on transportation during a swap out. i have the hybrid engine, so I'm hoping that one fails less, I heard originally it wasn't part of the recall, although I don't know if that's still true.
    i been sitting on the sidelines since 2022 watching people drive these trucks just being jealous. time to jump in the deep end.
  3. Jun 28, 2025 at 5:28 PM
    #213
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    This is the way
  4. Jun 28, 2025 at 5:29 PM
    #214
    18" TRD Off Road Wheels
    This is where I am at. Stressing about it when it's not doing anything wrong is pointless. Lamenting over what I wish Toyota had done instead is pointless. It can be cathartic to get in a bitching session, but at some point reality has to prevail and none of that matters.
    Drive the truck you like. There is no wrong answer here.
  5. Jun 29, 2025 at 6:05 AM
    #215
    szabo101
    szabo101 New Member
    ED
    2018 MGM Platinum 4WD
    You're right it makes no difference currently. However, it was in direct response to another claim that the 3rd gen is superior to the 2nd gen (more capable as a towing, hauling vehicle, and at altitude) based on the improved engine torque and HP, supplied by forced induction.
    While we can disagree about what determines "capable". What we can not disagree on is that from '08 through '15 a stock 5.7L forced induction engine was available that exceeds those defined capabilities of the 3rd gen. That's it, end of story, 3rd gen is not more "capable".
  6. Jun 29, 2025 at 6:10 AM
    #216
    Breathing Borla
    Northern Illinois
    whatever makes you feel good man, go with it
    WindChillYeti75 likes this.
  7. Jun 29, 2025 at 8:52 AM
    #217
    bowhuntercoop
    bowhuntercoop New Member
    2025 limited off road
    Have you towed with both? It’s not even close, 3rd gen is far superior imo. I’ve had a pile of trucks, mostly 3/4 diesels, but compared to my 16 tundra I had my 25 tows circles around it.
    Also tows better then my 2.7 ecoboost I had, different strokes for different folks but I don’t get the 5.7 hype. I get they are reliable, so was the 4.0 I had in all my second gen tacos and 4.0 in the 4Runners we owned, all gutless compared to the 3.4 tt in the tundra.
  8. Jun 29, 2025 at 9:09 AM
    #218
    WindChillYeti75
    WindChillYeti75 New Member
    2025 WCP Limited TRD Off Road iForce Max
    “BuT mUH V8 sOunDS kEwL……..”
    bowhuntercoop[QUOTED] likes this.
  9. Jun 29, 2025 at 9:15 AM
    #219
    WindChillYeti75
    I’m not talking about a modded 5.7 V8 compared to a stock 3.4 TTV6. Stock for stock, the new powertrain IS more capable than the NA 5.7 is. I owned both and have towed with both. Have you?
    bowhuntercoop and sudobash like this.
  10. Jun 29, 2025 at 2:21 PM
    #220
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I’m doing all I can in hopes of my 24 lasting a long time. Changing the oil every 5K. One by me and the other buy the dealer since I prepaid for maintenance till 85K. That way it gives me a chance to look things over. Every 10K I filter out the used oil to see if I find metal. So far there’s isn’t any. 15K currently.
    Retired...finally likes this.
  11. Jun 29, 2025 at 2:59 PM
    #221
    2wheelsforfun
    2wheelsforfun New Member
    Foothills AB Canada
    Not sure oil changes have any effect on failures as many failures on the spreadsheet have done break in oil changes as well as frequent oil changes, oil analysis etc.
  12. Jun 29, 2025 at 3:08 PM
    #222
    guru
    what if i stick a strong magnet to the outside of the oil pan
