New to me 02, questions
Discussion in '1st Gen Tundras (2000-2006)' started by MobileTundra, Apr 14, 2025.
  1. Jun 24, 2025 at 11:42 AM
    #61
    MobileTundra
    MobileTundra [OP] Camry Connoisseur
    Mobile, AL
    '02 RC SR5 V8 4WD
    Yours is excellent, nice to see a sibling truck! Mine’s currently getting plenty of use as I’m working to clear out all the overgrowth on my dad’s property:
    M14 EBR[QUOTED] likes this.
  2. Jun 24, 2025 at 11:58 AM
    #62
    Glad to see those damn Mimosa ("air tree") branches in the back hanging over the tailgae and brake light. Cut down every one of those invasive SOB's you find down!
  3. Jun 25, 2025 at 9:03 AM
    #63
    MobileTundra
    Mobile, AL
    '02 RC SR5 V8 4WD
    Are there any upgrades or changes that can be made to improve the HVAX blower motor cfm? All four fan speeds work, the mode selector cable is switching into each position correctly (no or minimal bleed-over to other vents), and the temperature control cable is working as it should - what I mean is the air coming through the vents is weak even at full speed. Normally I just close the right-most vent to increase airflow to the closer vents, but mine like most just whistles due to the foam surround around the door having rotted away, and it doesn’t meaningfully restrict airflow. As well, in this case, I don’t feel like it would make enough of a difference even if it did, as the overall airflow is just particularly anemic compared to my Camry. I searched and saw this is a common issue on Gen 2.5 and Gen 3, but I didn’t see any common issues with our generation aside from some fiddly mode selector cable issues and the occasional burnt-out resistor.
  4. Jun 25, 2025 at 9:19 AM
    #64
    M14 EBR
    M14 EBR Oh No, Rex Kramer!
    Pull and inspect the blower motor, the hamster wheel could be full of debris.
  5. Jun 27, 2025 at 7:02 AM
    #65
    MobileTundra
    Mobile, AL
    '02 RC SR5 V8 4WD
    Okay, don’t mind me, but I am an idiot: it is in fact the mode selector. I didn’t realize until I was getting ready to see how to remove the fan from underneath the dash that I felt air coming out of the floor vents, even on the first position. So I’m going to need to do some sort of adjustment to the cable, I presume.
  6. Jun 28, 2025 at 11:30 AM
    #66
    bfunke
    bfunke Tundra Curmudgeon
    Regarding upgrades, the latter genTundra owners sometime replace their blower with the brushless Land Cruiser blower that reportedly is quieter and moves more air. I think it may fits ours but cannot confirm this.
    MobileTundra[OP] likes this.
  7. Jun 28, 2025 at 3:43 PM
    #67
    MobileTundra
    Mobile, AL
    '02 RC SR5 V8 4WD
    Alright! So! Not the cable, but rather the dial. At some point when we last had the HVAC control assembly out, we had put the dial rod back in wrong. After pulling it back out and setting the mode to floor, then reinserting the dial rod, now it’s aligned correctly and able to switch to each mode.
    shifty` likes this.
