Ball joint broke on the highway....help....
Discussion in '1st Gen Tundras (2000-2006)' started by Aerindel, Jun 22, 2025 at 8:39 PM.
  1. Jun 24, 2025 at 9:12 PM
    #91
    Aerindel
    Aerindel [OP] New Member
    Montana
    Yeah, I see that it is. New shocks in my future. Right now just want to get it home.
    The Black Mamba likes this.
  2. Jun 24, 2025 at 9:13 PM
    #92
    Aerindel
    Montana
    Cheaper than the tow truck was....
    The Black Mamba and ColoradoTJ like this.
  3. Jun 24, 2025 at 9:35 PM
    #93
    Tow trucks are very expensive.
    I know a guy in Billings that runs 5 tow trucks. Makes money like crazy.
  4. Jun 24, 2025 at 10:14 PM
    #94
    Aerindel
    Montana
    So, while I'm waiting for parts........any idea WHY toyota made so many trucks over several models like this? What was the perceived advantage of upside down ball joints?
  5. Jun 25, 2025 at 5:14 AM
    #95
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Interesting. That's what I have on my '00. :notsure:
    I'm glad you have an order placed and will get back on the road soon enough
  6. Jun 25, 2025 at 9:59 AM
    #96
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I don't think anyone on here can give an exact answer on why Toyota did what they did, but they did fix this in the next generation models for affected vehicles where the LBJ is under compression. This was the first and only generation where the LBJs are under tension, prior to that the trucks had a torsion bar setup where the LBJ is under compression.
    It was likely cheaper for them to continue using the inferior under tension design and eat recall costs until the the next generation came out, rather than spend a bunch of money to change to a compression design on a generation that will be phased out in a couple of years anyways.
    bmf4069, G_unit3000, shifty` and 2 others like this.
  7. Jun 25, 2025 at 2:40 PM
    #97
    Aerindel
    Montana
    I'm just wondering why Japanese engineer, normally brilliant folks, thought they would design a suspension joint that was always trying to tear itself apart under normal conditions, rather than trying to push itself together. I can't imagine it was arbitrary...there must have been some advantage in theory.
  8. Jun 25, 2025 at 2:55 PM
    #98
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Just out of curiosity, were any of the 4 bolts loose when you removed the LBJ?
  9. Jun 25, 2025 at 6:13 PM
    #99
    They're still bitter about ww2.
  10. Jun 25, 2025 at 7:46 PM
    #100
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    My 98 Tacoma broke down on me exactly once, and the tow bill was $600. After that I got AAA. I haven't personally needed it since, but I saved my friend probably $600-1,000 when I was with him out on the Blackfoot and he hit a tree and busted his radiator. At $100/year, well worth it for me.
  11. Jun 25, 2025 at 7:49 PM
    #101
    MT-Tundra
    Montana
    The driver I rode with went to school for engineering and worked in the mining industry for a few years, then decided he could make more and enjoy life more as a tow truck driver.
  12. Jun 25, 2025 at 7:51 PM
    #102
    MT-Tundra
    Montana
    They've made a few dumb mistakes over the years. The rust. Different places, but rust has been a Toyota truck problem since the 70s. Then the years of first gen Tacoma and Tundra frame rust. Same generation with the LBJ issue. Who knows.
  13. Jun 25, 2025 at 8:24 PM
    #103
    Aerindel
    Montana
    No. All were pretty tight and hard to bust loose.
