Show me your Gen Three amp installs!
Discussion in 'Audio & Video' started by Wtundra2023, May 25, 2025.
  1. May 25, 2025 at 3:51 PM
    Wtundra2023
    Wtundra2023 [OP] Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    Looking for inspiration/options for installing my amp in my gen 3 crew cab. I am thinking i want it to go behind the rear seat in the middle. I am planning keeping the rear plastics in place and mounting my amp and crossover to them. I am open to other locations as well and would love to see photos!
  2. May 26, 2025 at 9:01 PM
    Trdtundra77
    Trdtundra77 New Member
    Central Il
    2022 Tundra limited 4X4
    Here’s a pic of my 2 Audiocontrol altitude amps a 600/4 and a 1500/1 powering 2 JL 10tw3 subs under the seat
  3. May 27, 2025 at 7:52 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
  4. May 27, 2025 at 7:59 AM
    Wtundra2023
  5. May 27, 2025 at 8:08 AM
    JayAreIV
    JayAreIV 1st Tundra
    JayAre
    U.P. of Michigan
    24 SR5 TRD Off Road double cab
    7'6" Sno EX V-plow, BF Goodrich All Terrain KO3, Air bags for the rear axle, Tow mirrors, Tonneau cover, JL audio component speakers front doors & dash, JL 2 way rear doors, with Beat-Sonic 3T3 amp & Memphis Audio 10" powered subwoofer behind the rear seat, Rust proofed & Ceramic Coated.
    Went with simple upgrades JL component speakers front doors & dash JL 2-ways rear doors Beat-Sonic 3T3 amp 4 x 50w behind the non-JBL Stock head unit & Memphis Sound 180w 10" sub behind the seat. Major difference in sound & volume! Clean Crisp & Thump for under $1000
  6. May 27, 2025 at 10:31 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    HDPE mounted to the back wall then amps mounted to the HDPE
    dogsleds_t100_tundra likes this.
  7. Jun 1, 2025 at 11:42 AM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    Mounted to plastic panel using screws with nuts on back side.
  8. Jun 2, 2025 at 7:21 AM
    dogsleds_t100_tundra New Member
    '23 Tundra SR5 TRD OffRoad AG and '97 T100 4x4
    275/70/18 AT3, Elka IFP 2.0, Aftermarket Speakers, Sub, Amp. Ceramic Window Tint, Color matched grill surround and rear bumper panels, Orvis Backseat Protector for K9s, OEM Black Exhaust Tip, OEM Black Tailgate badge insert.
    Same. 4 micro steel bolts with nyloc nuts. And small square of HDPE behind beauty panel since this middle section of panel is less rigid and had to be firmed up.
    Soflo and Wtundra2023[OP] like this.
  9. Jun 3, 2025 at 12:28 PM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    Nice install. I really like the grommets the wire s pass through. Where did you get them?
  10. Jun 3, 2025 at 1:33 PM
    Thanks. The two small grommets used for the power and ground passthroughs from Knuconceptz, matches their flexible OFC wire. The large O-ring grommet used for all the speaker wires passthru came from an assortment pack purchased off the shelf at Harbor Freight.
  11. Jun 3, 2025 at 5:26 PM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    Gotta love that knuconceptz. I used the same wire. I will have to go out and find some grommets that fit. I used a step drill bit and never measured the diameter.
  12. Jun 3, 2025 at 6:59 PM
    For sure, great product and price (kc). Really like your D-5.1300 install. The D-5 has dedicated 500w channel for Sub, very nice. Currently i am running each (125w) channel of the D-6.1200 here to drive front and rear stage doors and dash, including midbass drivers actively driven which is very nice; however, this leaves only Line Out to feed a powered Sub (under passenger seat in my case). In the future i may purchase a separate subwoofer amp to drive a stout passive Sub and place this second amp in the cubby where you have your D-5.
    edited: *each
    Soflo[QUOTED] likes this.
  13. Jun 6, 2025 at 1:32 PM
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
  14. Jun 24, 2025 at 5:49 AM
    Wtundra2023
    Love all the installs. I finally got around to getting mine wired up and am in the process of fine tuning it now. Pics to come either on this thread or my install thread (probably both via link).
    Question for the group, what do you fuse block installations look like? Where are you putting them, how are they mounted, and what brand of fuse holder are you using? Mine is currently on a poorly hand fabricated (by me) bracket that that would make almost any welder laugh to keep from crying. I would like a nicer/cleaner solutions. No pics available of it for plausible deniability later.
  15. Jun 24, 2025 at 6:31 AM
    Went with In-line fuse holder and a Top Post battery terminal adapter from Knuconceptz; and a premade hover mount from TT. And wrapped wire in fiberglass loom. Clean, relatively simple, and easy access to everything.
    Wtundra2023[OP] likes this.
  16. Jun 24, 2025 at 6:36 AM
    SilveradoSwap
    That is 1/0 gauge ofc coming from the battery to the distro block
  17. Jun 24, 2025 at 7:03 AM
    Wtundra2023
    I attempted to buy one of those. They cancelled my order due to availability. I am still thinking I would like to get one installed especially now that I see yours. Would you be willing to send me measurements of the plate where the holder mounts? My fuse holder is a lot larger than yours it appears and not sure I want to buy a new one.
    That is clean. How easy is it to get into the fuse box with the wires attached to the top of the lid like that?
  18. Jun 24, 2025 at 7:40 AM
    SilveradoSwap
    The fuse lid pops right off. For the distro block I used screws with lock nuts so they won't come loose and fall in to the fuse area. I need to get shorter screws for the fuses so I can install them the same way. I can snap a pic of the fuse lid from the inside as well.
    In case I need to remove any of the wires throughout the entire system, I installed ferrules on the wire ends.
  19. Jun 24, 2025 at 7:54 AM
    The Top plate measures 4 1/2" x 3 1/4".
